How to Install a 60g Compressor?
/ How to Install a 60g Compressor? #1
9973720wb19
East Coast
Many
I've got a IR 60 gallon vertical compressor coming. I was wondering how many of you guys actually bolt it to the concrete floor in your shop. I really don't want to be drilling in the floor, so I was thinking about bolting it to a wooden platform instead? Or can I just stand it up and it will be fine?
/ How to Install a 60g Compressor? #2
No matter what you do consider checking access to the bottom drain. The space is limited and on the one for my brothers shop we added an elbow, pipe nipple and ball valve to make tank draining a bit easier. It also required using blocks of wood to increase clearance between tank and floor.
Bolted to floor, but not certain it needs to be.
/ How to Install a 60g Compressor? #3
Actually I wouldn't think of Not bolting it down. I 'spose you could train it to dance :laughing:
/ How to Install a 60g Compressor? #4
I have 2 IR 80 gal, both still sit on their shipping pallet.
I have never had one move even an 1/8 inch, you are supposed to bolt them down per the book. I suppose if you had a compressor that bucked like a jackhammer you would sure want to bolt it.
As moship said, plumb the drain pipe out no matter what you do.
/ How to Install a 60g Compressor? #5
I have seen comments where the owner bolted them to a pallet apparently with no issues. A proper install when bolted to the floor is to use an isolation block between the floor and the compressor to minimize stress from vibration where the legs are welded to the tank.
Isolators look like a piece of rubber about 3/4 or 1.0'' thick by maybe 4x6 inches. It's been some time but I had ordered some from Campbell Hausfield at a reasonable cost.
/ How to Install a 60g Compressor? #6
I have seen cut tire treads used for this too.
/ How to Install a 60g Compressor? #7
I just sat mine on the floor with some old conveyor belt between the concrete and the legs of the compressor. Been that way for close to 8 years and still working fine, never moves
/ How to Install a 60g Compressor? #8
When I bought a 60 gallon compressor the salesman specifically said to leave it on the shipping pallet. I did and it never moved at all. Personally, I'd not bolt one to the floor.
/ How to Install a 60g Compressor? #9
My 80 gallon compressor came on a shipping pallet. It also came with hard rubber pads to set it on if I want to bolt it to the floor. I left it sitting on the pallet.
My previous 60 gallon compressor also sat on its shipping pallet for over 30 years.
I did have to rebuild the shipping pallet my newest one came on to a smaller size. The pallet was roughly 3' x 4'. I rebuilt it using the same wood to a smaller square size and bolted the 3 legs to the wood. It hasn't moved and is high enough for easy access to the drain valves.
/ How to Install a 60g Compressor? #10
Anyone watch the news about Japan?
Vibration is only one reason to bolt it down, earthquake is another.
/ How to Install a 60g Compressor? #11
Good point!, but if I'm in an earthquake I have other problems.
Now if I lived in California, I'd have my truck bolted to the floor.:)
/ How to Install a 60g Compressor? #12
If you are planning to hard pipe any connections from the compressor and you don't want to bolt it then I would use a fexible connection between the tank and the pipe. I could see where you might have problems or leaks otherwise.
/ How to Install a 60g Compressor? #13
Mine is bolted to the concrete floor. It took me about thirty minutes to do this.
/ How to Install a 60g Compressor? #14
Please, do this to your drain, I did this and I'm glad I did.
/ How to Install a 60g Compressor? #15
At the plant we don't have a choice... everything has to meet seismic requirements.
Sometimes the manufacturer will even spec the fastener... such as a Hilti. If we don't follow manufacturer's installation instructions we need to have an engineer sign-off and the State comes out on a regular schedule to inspect all pressure vessels.
Grainger and others sell vibration isolators for compressors...
An option you might find useful is an automatic drain valve... I've installed several and they work well...
/ How to Install a 60g Compressor? #16
I left my 80 gal. Ingersol Rand compressor on the pallet that it came on. I also put the drain tube out the side of the bottom of the tank with a ball valve on it to make it easier to drain. I don't run it every day but it has stayed put where I set it. I did put some extra blocking between the two layers of boards on the pallet to make it more solid, maybe not necessary but I did it anyway, makes me feel better cause it can't vibrate as much that was my thought at the time. I would like to sometime in the future put in solid piping for it but as the other poster said I would use a flexible hose from the tank to the pipe.
/ How to Install a 60g Compressor? #17
- Leaving it on the pallet is fine. I've done it with 2 compressors with no movement or issues. I trimmed my latest pallet down with a sawzall so it wasn't so large.
- Extend the drain like Markcuda shows with extension/valve/turndown elbow. I've done the same thing. Make sure the pipe you use is rated enough for the full system pressure, but that shouldn't be hard to find as it should be under 200psi.
- IF you bolt it to the floor, you should not rigidly mount it. The tank will expand and contract as you add pressure or drain it down, and if the feet are too rigidly attached, you can stress the tank where the feet mount. Rubber pads or mounts are a good idea for both expansion allowance and vibration isolation. Manufacturer may require it in the install instructions. You can also do this by screwing one down tight (over rubber pad) and leaving the other two slightly loose with nylock nuts, for example.
- Always use a short section of flex hose from the compressor to hard piping. Makes install/maintenance a billion times easier and isolates vibration from your hard piping.
- Run horiz piping on a slight down slope with a drain leg/valve at the far end to trap moisture. Where you want to tap into the line for air hoses, tap into the top of the pipe and point them UP initially so that condensed moisture does not run down into your hoses and tools.
- Soldered copper ($$) or iron pipe work fine. PVC is a major safety hazard when used for compressed air no matter what anyone tries to tell you.
Those are the key things that are top of mind.
Many thanks for all the ideas. Really did not want to put holes in the floor because I it's ugly and I may want to move the compressor to a different spot in the future. I think I'll just leave it on the pallet its shipped with and perhaps one of those large hard rubber mats from TSC under the pallet. Also, thinking I may (depending on what the shipping pallet looks like) build a better wooden base or set more blocking in the shipping pallet. And of course, make a more accessible drain. thanks again for all of the ideas...
/ How to Install a 60g Compressor? #19
I got the same one and just left it on the small wooden pallet that came with it. Been running two years now no problems.
/ How to Install a 60g Compressor? #20
Mine is sitting on vibration pads and has not moved. i used flex conduit for eletrical and hydraulic hose to run air to the wall where the regulator is located. It has worked fine.
