How to Install a 60g Compressor?
   / How to Install a 60g Compressor? #1
9973720wb19
Platinum Member
East Coast
Many
I've got a IR 60 gallon vertical compressor coming. I was wondering how many of you guys actually bolt it to the concrete floor in your shop. I really don't want to be drilling in the floor, so I was thinking about bolting it to a wooden platform instead? Or can I just stand it up and it will be fine?
   / How to Install a 60g Compressor? #2
No matter what you do consider checking access to the bottom drain. The space is limited and on the one for my brothers shop we added an elbow, pipe nipple and ball valve to make tank draining a bit easier. It also required using blocks of wood to increase clearance between tank and floor.
Bolted to floor, but not certain it needs to be.
   / How to Install a 60g Compressor? #3
Actually I wouldn't think of Not bolting it down. I 'spose you could train it to dance :laughing:
   / How to Install a 60g Compressor? #4
I have 2 IR 80 gal, both still sit on their shipping pallet.
I have never had one move even an 1/8 inch, you are supposed to bolt them down per the book. I suppose if you had a compressor that bucked like a jackhammer you would sure want to bolt it.
As moship said, plumb the drain pipe out no matter what you do.
   / How to Install a 60g Compressor? #5
I have seen comments where the owner bolted them to a pallet apparently with no issues. A proper install when bolted to the floor is to use an isolation block between the floor and the compressor to minimize stress from vibration where the legs are welded to the tank.
Isolators look like a piece of rubber about 3/4 or 1.0'' thick by maybe 4x6 inches. It's been some time but I had ordered some from Campbell Hausfield at a reasonable cost.
   / How to Install a 60g Compressor? #6
I have seen cut tire treads used for this too.
   / How to Install a 60g Compressor? #7
I just sat mine on the floor with some old conveyor belt between the concrete and the legs of the compressor. Been that way for close to 8 years and still working fine, never moves
   / How to Install a 60g Compressor? #8
When I bought a 60 gallon compressor the salesman specifically said to leave it on the shipping pallet. I did and it never moved at all. Personally, I'd not bolt one to the floor.
   / How to Install a 60g Compressor? #9
My 80 gallon compressor came on a shipping pallet. It also came with hard rubber pads to set it on if I want to bolt it to the floor. I left it sitting on the pallet.
My previous 60 gallon compressor also sat on its shipping pallet for over 30 years.
I did have to rebuild the shipping pallet my newest one came on to a smaller size. The pallet was roughly 3' x 4'. I rebuilt it using the same wood to a smaller square size and bolted the 3 legs to the wood. It hasn't moved and is high enough for easy access to the drain valves.
   / How to Install a 60g Compressor? #10
Anyone watch the news about Japan?
Vibration is only one reason to bolt it down, earthquake is another.
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A51039)
Morooka MST 660VD...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A50657)
THIS WILL BE A...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
1992 GROVE AP-308 CRANE (A51222)
1992 GROVE AP-308...
