Plastic or metal electrical boxes?
/ Plastic or metal electrical boxes? #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
I would be interested in learning which type of box the members here prefer for new construction...when we built on, my wifes's brother who is a journeyman electrician swore by those brownish-grey plastic boxes, saying they were the best type. But when I finished off and wired our basement, and rewired my barn, I used metal boxes. The issues I have with plastic boxes are that they are nail-on, and I think for most uses, they flex too much. I am very uncomfortable using them for ceiling light fixtures. I also hate it that when you push the wires back into the box after installing the switch or outlet, the wires flop around, while if you use a metal box you can use a cable clamp and eliminate that problem. Some people say "plastic boxes need no grounding" but I actually PREFER to have a grounded box.
While on the issue, does anyone know why you can buy a square metal 4 inch junction box for a dollar, but a 2 gang metal switch box costs $6 or $7? Thanks.
A footnote...I think plastic boxes were invented to speed up wiring, no wasting time screwing metal boxes to the framing, no need to ground the plastic ones, no messing with cable clamps...yeah, slap it together fast, as cheap as possible...
/ Plastic or metal electrical boxes? #2
Ill give my thoughts for what there worth. I have rewired about 500 sqft of my house. It was built in the early to mid 50s, that part at least. I hate trying to get the hold down clamps in place, at least on my metal boxes. But on some new stuff ive done i have busted parts off of plastic easily, including the retaining tabs on the box.
Again im no pro, what i know is from books and the internet and my own limited experience. But i think metal does not need grounding as it is grounded to the house as its is a conductor. They were uses with the old non grounded wire. The box is where the ground was. Plastic is non conductive so it needs the ground wire. Like they say electricity will take the path of least resistance, so if your going to arc its more likely to hit the metal box and go into the wall vs plastic faulty grounded going to you then ground.
Overall i like plastic for the cheap and ease of things. Would i hang a 28lb ceiling fan off a $0.65 plastic box, probably not. But again those things have weight ratings on them so i guess as long as you stick to them you should be ok. Just a thought, the ceiling boxes will be in the hot attic, are these plastices that wont get brittle with age. Think 10-15 years and plastic that has been in the attic and how it can crumble?
/ Plastic or metal electrical boxes? #3
I use plastic boxes all the time, exept for cealing fixtures where a fan will be used or a hanging light. There fine, "IMO"
Army Grunt
/ Plastic or metal electrical boxes? #4
I don't believe electrical code will allow the use of plastic boxes for ceiling lights. I believe they must all be "fan" rated.
Plastic outlet boxes: Use care when tightening the screws that hold the outlet or switch in. They crack or strip fairly easily. They are much quicker to wire since their is no pinch bolt/strain relief to mess with.
Another problem with plastic boxes is the drywall crew can chew them up with their roto-zip. had an addition put on last summer and had two boxes covered by dry wall and two destroyed by drywall crew. Fortunately the contractor had to deal with it and not me.
Plastic has its place, just question like others, how well it will hold up over time.
Roy
/ Plastic or metal electrical boxes? #5
I usually use plastic boxes for normal outlets and switches, but metal boxes for ceiling lights and fans (usually use the specific-made fan boxes for fans). I've had good luck with plastic boxes - a fraction of the cost, quick to install, etc. I agree that once you get past a double-gang, the plastic is a little too flexible for my taste without being reinforced, and then you lose the economy that the plastic creates to start with, so in my opinion, metal is better for that.
However, if someone doesn't like plastic boxes, the can spend their dollars any way they see fit and put in all metal and they'll never hear a complaint from me.
Good luck and take care.
/ Plastic or metal electrical boxes? #6
I only use and prefer metal boxes. Did my house, additions, shed, etc all with metal. I just find that the metal box is more robust, and the clamps actually clamp. When pushing wires around and into the box to put the device in, the metal boxes are nice to have for the strength. I always use the 2.5" deep boxes to give me the most room in the box, to make things easy. Maybe overkill, but when you go back in a few years later to modify ot replace, it is nice to have the room.
If cost is your issue, use plastic. If a more robust, quality job is a goal, go metal.
paul
/ Plastic or metal electrical boxes? #7
When we did our house, I used metal boxes for outlets and plastic for the switches. Outlets get a lot of flexing as they get used, and I've had too many plastic boxes break at our old house. The switches get very little flexing. Only time will tell if the plastic in the boxes gets brittle and everyone discovers that at 50 years they start having problems.
Another win of the metal for outlets is you can use washers and spacers to position the outlet correctly against the drywall. A lot of loose outlets use the drywall for support, and with time the drywall flexes or crumbles and the outlet is loose. With the washers, the outlet is supported just by the box and stud. Every outlet has a rock solid feel to it. Again, more time during installation and not something the trades would do.
For the kitchen, there is a deep metal box that cost a lot ($3 or so?) but it is very good for the GFI breakers that are a too tight for "normal" outlet boxes. Instead of nails, I used 3.5" screws and put two pieces of shrink wrap on the screw where it was inside the box so that wires would not have the insulation cold flow into the sharp part of the screw. Best of all worlds, except for labor and to a much smaller degree cost of box. The down side is getting anyone in the construction business to do anything differently is a hurdle.
Note also that using the big, screwed in metal box is a win if you can identify any outlet that will see a lot of use, such as vacuum cleaner or garage outlets.
For ceiling boxes, I used metal. I put a 2x6 between the ceiling joists and screw the box into it. I messed up in the garage. I put in plastic boxes because I thought "I'll never put in a ceiling fan here". Well, 3 of them have broken where the screw for the fixture goes into them and it's been a pain retrofitting them with metal boxes. Live and learn.
Also consider outlets in the halls. They are typically not required, but you can put these night lights in them. They are also great for vacuum cleaners. A few of these are in plastic boxes in areas where I know I would never use the outlet (we have central vacuum). Others are in the big metal boxes if they are in an area where they might get used. Here's a close up of the nightlight, and a pix of how it is used in the hall. The cat door is just a bonus, don't get me started...:laughing:
Pete
/ Plastic or metal electrical boxes? #8
I've used both. I prefer plastic. However, a couple years ago we smelled something bad on our enclosed porch. Investigation revealed some old wiring inside an outlet, with the duplex outlet melted into a puddle of goo and the wiring burnt to a crisp. The inside of the metal box had apparently contained and snuffed out a fire at some point. It appeared to be caused at the point where the wire was tightened under the screw terminal on the duplex outlet. I have to wonder if the metal in the box was able to resist the fire better than a plastic box might have. We dodged that bullet. Makes you wonder some times. That's all I'm sayin'. :)
/ Plastic or metal electrical boxes? #9
Metal boxes absolutely need to be grounded. The old wiring didn't have the ground wire so the outlets didn't have provisions for the ground prong - just hot and neutral and since there was no ground conductor in the wiring, the metal boxes at that time wouldn't have a provision to connect the ground wire to them. You absolutely can not expect a metal box to ground through the house! The house is absolutely NOT a conductor! A plastic box is non conductive. It does not need to be grounded, just the receptacle ground lug needs to be connected to the ground wire.
Electricity does not take the path of least resistance, it takes the paths of all resistances. Every path is in parallel and the amount of current that flows depends on the individual resistance of each path.
I don't think I have ever seen such dangerous statements concerning house wiring as yours are.
Well stated, Mace...I hate to disagree with a poster who feels they are corrrect...thanks.
/ Plastic or metal electrical boxes? #11
ok..heres my 2 cents worth. I'm an electrical contractor..have over 30 years in the industry.
I have no problems with the plastic boxes, but their quality does vary. i've tried the blue boxes from home depot, and usually break quite a few of them while nailing them on the wall. However, the black BOWER brand boxes from my supply house, which are a little more $$$, NEVER break. you get what you pay for.
I always use plastic FAN RATED boxes for all surface mount light fixtures. they can support up to 150# stationary load or 75# fan ratings.
the above is for residential.
For commercial i always use metal boxes. Why the difference, because on commercial work i generally use metal EMT conduit, flex conduit or MC/BX metal clad wiring as per code here in Idaho. The code has loosened up some and now allows romex wiring in commercial, but i wont use that. Doesn't allow for changes later like EMT pipe does. And commercial businesses are always changing. When you use metal conduit, you HAVE to use metal boxes.
i really feel that there is no problem with plastic boxes in residential use. Most outlets have something plugged into them, and remains plugged in them forever. They don't have constant movements. That being said, i use metal boxes in all my shops and garages.
When i wire horse barns, i use metal EMT pipe and metal boxes (no rodents, horse damage).
I wired my shop and carriage barn in metal conduit. why not, its mine.
as far as bonding improvements with metal boxes go, you don't need to bond plastic, and the end result is that the outlet IS grounded, so the bonding is irrelevant.
also, as for the 1 gang vs 2 gang cost differences, im confused. i use whats called a 4 square box. its just a 4" x 4" open faced box with or without mounting flanges. cost about 1.10 here. then i can configure it for either a 1 gang or a 2 gang device by using a plaster ring (mud ring). the 1 gang costs the same as the 2 gang, about a buck. i get these at whatever depth the finish wall will be, 1/2", 5/8",etc.
i think you've been buying the 2 gang boxes with the device screws already attached....no one uses those. hence the high cost.
the boxes i use are available up to 8 gang configurations. i have included pics of the 4 square box with both covers, and also a picture of the expensive box i wont use. hope this helps
also, plastic boxes have a 2 hour fire rating. if the metal screws on the receptacle make contact with the metal box...BAMM, small explosion and tripped breaker. this is the reason to bond (ground) the metal box.
That's why you should wrap the side of the terminals with vinyl tape. I don't have this issue with plastic boxes. A commercial rated receptacle (about $4-6.00 each) have recessed screws to prevent shorting.
MossRoad's comment about a metal box that contained a possible fire reminded me of what I found after I moved here about 20 years ago. The house I purchased was an Aladdin kit house, the majority of the outlet, switch, and junction boxes were ALUMINUM, not steel. The prior owner had hired an electrician to add new wall lights to the only bathroom, when I removed the original medicine cabinet, the pictures below are what I found on a stud wall by the cabinet. The four old black wires protruding from the sides are the 50 year old 14-2 house wires, the very bottom one on the left side is a newer Romex 14-2 with a ground spliced in, and the wire leading out the top is a single #14 that led to the basement cold water pipe. I have NEVER seen that method of grounding used before. Believe me, I am SO GLAD I found this junction box, I have NEVER seen anything so hazardous, the splices inside were taped, no wire nuts, and the box is only 2X3 inches. I took it out and have it hanging by my workbench as a reminder not to do careless work.
/ Plastic or metal electrical boxes? #13
hmm, that has homeowner repair written all over it.
ive found some old work where someone ran a ground to some water pipe. absolutely useless. the ground HAS to run all the way back to the point of origin to allow stray voltage to make it back to the breaker and trip it.
that is one ugly picture there. In the old days, before wire nuts. people crimped the wires together and taped them.
Well, crud! There goes my cost savings! :laughing:
About ten years ago I was at a Home Depot, saw a guy there wearing a black T-shirt, on the back it had cartoons of stick figures, one if the figures was standing in front of a service panel getting a huge shock, the second was running down the street with his hair on fire, and a burning house in the background.
The front of the guy's shirt read:
"Electricity is not a hobby. Play it safe and
call XYZ Electric at 123-456-7890...."
I have been wiring and rewiring on my buildings for 24 years, can do just about anything but hookup to the service panel. Will work on sub panels if they are not energized. No way I could work on service panels for a living though.
/ Plastic or metal electrical boxes? #16
My :2cents:
I like the plastic for ease of use.
No need IMO for a metal box for just recepticals and switches. Overhead stuff is different though.
Unlike a previous poster, I have had good luck with the blue boxes. I got them from menards, but I believe lowes and HD sell the exact same thing.
They are dirt cheap and I have yet to break one. Even when I have had to remove and re-position them. BUT the brownish fiberglass looking type I would avoid. They break very easily. They are almost TOO hard and brittle as a result.
I have also never seen the black ones, so I cant comment there. But I also buy the deeper boxes. More room for shovig the outlet back in. I like to leave at least enough wire in the box to be able to change and outlet or receptical if ever needed in the future. If you use a metal box with the retaining rings and dont leave much wire, you may be ripping out drywall in the future if a switch goes bad.
/ Plastic or metal electrical boxes? #17
If you are using boxes on the outside walls and are concerned about making the best seal possible in the insulated wall, then the plastic ones with the neoprene seals are definitely the way to go. Otherwise the metal box should be wrapped with plastic and sealed with caulking which is a PITA. Same goes with the ceiling below the attic if it is insulated.
For inside walls and lower level ceilings it does not really matter but I have always preferred the clamp arrangement in the metal boxes versus the plastic one but that is because the plastic ones tend to work well the first time then not so well after. I have also seen a number of metal nail on boxes that look like the were hit with a sledge hammer and the sides are barely holding on. Poor work can be done with plastic or metal-- JMHO:eek:
/ Plastic or metal electrical boxes? #18
use both plastic and metal. on re-wiring house and sheds.
i tend to use metal boxes out in the shed, and also get metal face covers. for switches and outlets. this is mainly due to the face plats fit snug, and it is much hard to snag a sleeve or something on the edge of the box / face plate.
if there is going to be paneling or sheet rock or like on the wall. i will most likely go with a plastic box. due to they are cheaper, and gave a quick easy guide for how far the front of the box needs to stick out past the wall stud.
anything for ceiling = metal box.
the thing i hate about metal boxes. are the need for "plugs" more so out in the shed. when removing old metal boxes. i have found wasp nests, bee hives, and an arrangement of bugs and dust inside the boxes. just wrapping the box with tape does little good. that and the sheds are metal. so also dealing with a little drip or 2 here and there of water, from the metal sweating.
/ Plastic or metal electrical boxes? #19
naaa, come on down. ill let you work in the live 6000 amp panels at the hospital i do work at....cant shut them down. work live with hot gloves, flash guards, and a prayer.
/ Plastic or metal electrical boxes? #20
That was permitted by the NEC at one time. That was before it was common to use plastic water lines inside and underground as replacements.
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
2019 John Deere R-4038 (A61306)
2019 John Deere...
2018 Kia Soul SUV (A61574)
2018 Kia Soul SUV...
