Need help problem with a Yanmar tractor!
/ Need help problem with a Yanmar tractor! #1
Jeremy7286
yanmar
I am not sure of the model of the tractor, but I do know that the numbers on the motor are 2tr16. Now for the problem I have. We ran it out of fuel one day, filled it back up with fuel blead the fuel lines. We it started back up the motor ran wide open with no throttle control? Even though the the throttle is moving inside the injector pump. Any help would be great! Thanks in advance!
/ Need help problem with a Yanmar tractor! #2
If item 21 is moving back and forth you will need to repair/replace the pump.
Any idea whats the cost of repair or replacing the pump?
So my next question is can they be rebuilt, or would I be better off buying a new one?
/ Need help problem with a Yanmar tractor! #6
Before you go the pump route, I would pull the side covers off and check that the governor is not stuck or the spring broken.
/ Need help problem with a Yanmar tractor! #7
The governor operates the rack, item 21, which he says is moving properly. If it were mine I would have a look at it, but then, I feel like I can fix anything. Strange how this happened after running out of fuel.
/ Need help problem with a Yanmar tractor! #8
I was thinking that the governor can over ride the the throttle to some degree. It sounds like it is trying to go wide open regardless of throttle movement. If you shut the throttle down can the governor still open it up enough to cause a run away with no load on the engine or is it limited to how far it can open the pump? I don't know enough about the limitations of the governor on these.
Not sure how it would be connected to running out of diesel. I've done that before and just bled the system and fired it up. I do know you can cause some weird effects by tampering with that little screw on the front of the gear case. :eek:
/ Need help problem with a Yanmar tractor! #9
I guess it depends on what you call the throttle. To me, the actual throttle is inside the pump, operated by the slide, (rack, item 21, which he said is operating properly). If that is not the case, then you could be right. No way to know without on-site inspection.
/ Need help problem with a Yanmar tractor! #10
By throttle I was referring to the hand or foot linkage to the injection pump. The 1600 is identical to the 1900 with only a few differences. On my 1900 if the engine bogs down, the governor will kick in and try to maintain the rpm up to a point. How far it can open up the injector pump I'm not sure of but I've seen it do it enough to put out some power and start pulling. So my thinking was that if it can do that then it could also stick or go full throttle on it's own.
Ok guys, a little more information from yesterday. My brother and I took the plate thats right above the injection pump. How tight should be the spring on the hand throttle control? We could actually control the throttle by manually moving the bracket thats connected to the pump. Sorry if my terminology is off.
/ Need help problem with a Yanmar tractor! #12
Maybe this drawing will help some. Sounds like nothing wrong with the pump. Yanmar Tractor Parts: GOVERNOR
/ Need help problem with a Yanmar tractor! #13
That's what I was trying to find out, and eliminates the pump as a problem. How tight is tight:confused:?
/ Need help problem with a Yanmar tractor! #14
If you disconnect the linkage from arm #22 and move the arm all the way to full throttle it should move back when you let it go. If the spring #20 is broke or come off it will just stay where you left the arm and will not control the governor which will let the engine rev up.
Ok we took about the pump again, and corrected some errors that happened the last time we messed with. I know that probably is the reason why it was running wide open. Now my our problem is that we are getting fuel to the injectors but the motor will not run. Any ideas?
/ Need help problem with a Yanmar tractor! #16
Is the exhaust putting out smoke? What color, and how much? If fuel is getting to the injectors, at the right time and with sufficient compression, it WILL run, it has to. Does the engine sound like it's got good compression, lugging the starter as each piston cycles? There are lots of threads about trying to get these things started. Try putting the throttle in the middle of its travel. Activate the compression release, and crank the engine. It will spin a lot faster than without the release activated. Then deactivate the release and let it crank for several revolutions. Do that a couple times. It should fire right up, but if it doesn't, you should at least start to get smoke. If it's not smoking, something else is amiss.
/ Need help problem with a Yanmar tractor! #17
It sounds as if, when you originally ran out of fuel, instead of just refuelling and bleeding the air from the lines, you pulled the pump and bent the linkage or something. did you ever properly bleed the air from the lines?
Unused 2021 Ideal BB4LD 48in. Box Blade Tractor Attachment (A66734)
Unused 2021 Ideal...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2014 Club Car Golf Cart (A62613)
2014 Club Car Golf...
2009 MACK CHU613 (INOPERABLE) (A67714)
2009 MACK CHU613...
2013 Acura ILX Sedan (A66738)
2013 Acura ILX...
SOUTHERN FRAC MANIFOLD (A68842)
SOUTHERN FRAC...
