JD4020 Steering Valve
/ JD4020 Steering Valve #1
Grayson Klassen
Gold Member
Fort St John, BC
John Deere 4020
Has anyone changed one before? is it something I can do myself? My steering works great to the left but is sluggish and weak to the right. guy I bought the tractor off said to buy a rebuilt steering valve and swap it out.
Any thoughts?
:confused3:
/ JD4020 Steering Valve #2
My haying buddy is replacing/rebuilding the steering valve on his 3010. He said it's been something that has needed to be done and he's put off... and he's very handy at doing everything on his 4 JD tractors, 2 JD balers and JD disc mower/conditioner. He swapped his 245 loader out and mounted it on his 2640. With the loader off - he jumped on the steering job.
Told me the steering pump and valve assembly weighs about 170lbs on his 3010. And it's not in a real easy location to access and wrestle that hummer outta there!
Much depends upon your experience and your shop/equipment and your friends that can lend a hand!!
You'll definitely save money - likely won't save time - and you'll learn as you go! :thumbsup:
AKfish
/ JD4020 Steering Valve #3
Told me the steering pump and valve assembly weighs about 170lbs on his 3010. And it's not in a real easy location to access and wrestle that hummer outta there!AKfish
According to Abilene Machinery a similar steering valve for an early 4430 Part Number SV4430-R
Weight 64.00 lbs
Your Price: $990.00
Quantity Price Each
*Note:
/ JD4020 Steering Valve #4
Weight 64.00 lbs
Your Price: $990.00
Quantity Price Each
*Note:
I'm only going on what Jim told me.. Maybe he's taking in account the steering wheel, etc. - the whole enchilada.
He did say that he had to use his overhead hoist to pull everthing out.
That is a pretty spendy item as well.... Whatdya suppose shipping would be to Fort St. John, BC, Canada?
AKfish
/ JD4020 Steering Valve #5
I feel sure you could get your valve rebuilt for less than $990. There usually aren't too many expensive parts that needs replacing unless you have cracked or broken housings. Typical rebuild after valve is out is about 4-5 hours labor. A seal kit costs less than $100. Usually the valves can reseated and adjusted. Removing the steering valve isn't too difficult. Removing the steering wheel is usually the toughest part. Then unhook throttle linkage, wiring to dash, tach cable then lift off the dash. Then unhook all the oil lines and remove the four mounting bolts to lift it out. 64 pounds sounds right. Definitely less than 100 pounds. It is clumsy though.
I can get a rebuilt unit up here for about 600 buck plus exchange. I am sure I can do it, just wondered if there are any watch out fors?
/ JD4020 Steering Valve #7
I feel sure you could get your valve rebuilt for less than $990. 64 pounds sounds right. Definitely less than 100 pounds. It is clumsy though.
jd110
I copied and pasted that not noting the price but basically to show the weight.
/ JD4020 Steering Valve #8
I'm only going on what Jim told me.. Maybe he's taking in account the steering wheel, etc. - the whole enchilada.AKfish
AKfish
The steering wheel and associated parts doesn't weight close to 90#s extra plus to easily remove steering valve one needs to remove steering wheel so dash can be removed for easier access to valve mounting bolts & hyd lines.
/ JD4020 Steering Valve #9
Grayson;
Sent you a PM.
AKfish
2020 ASV RT65 (A60462)
(INOP) JOHN DEERE 694 CORN HEAD (A63291)
(INOP) JOHN DEERE...
2014 HYUNDAI 53X102 T/A DRY VAN TRAILER (A59912)
2014 HYUNDAI...
FORD 5 BOTTOM SIMI MOUNT BOTTOM PLOW (A63291)
FORD 5 BOTTOM SIMI...
(4) METAL DRUMS (A63291)
(4) METAL DRUMS...
2019 East Manufacturing 48ft. T/A Walking Floor Trailer (A61573)
2019 East...
