Finding Brake Light Wire
/ Finding Brake Light Wire #1
KennyG
Super Member
SW Michigan
John Deere 2320
I've got an '04 Dodge Dakota without the factory trailer wiring and I'm in the process of installing a brake controller. I've got everything sorted out except for tapping into the brake light wire. I figured I'd just look under the dash, find the brake light switch and pick out the output wire.
Shows how long I've been out of game. The brake light switch seems to have about 8 wires coming out of the connector. :confused: I haven't been able to find any definitive wire color for the brake light and I don't want to spring for a shop manual to hook up one wire. Any tips on an easy way to find the wire?
/ Finding Brake Light Wire #2
Use a test light. One end clips to a ground and the other end you use to test each wire when you find the right one the test light will light up. Worked well for me on a chevy I did a brake controller in.
/ Finding Brake Light Wire #4
er....most dodge trucks have the wiring harness already in place for a brake controller. there usually zip tied under the dash. its a 6-9 hole female plug. If your doesnt have this, find the switch that the brake bracket makes contact with, and use an electrical test light to find which leg is hot and which leg is switched (hot when brake is pressed). And there you have it.
have fun
Thanks for the ideas. This should help me along this weekend. I'll look again for a spare terminal, but I couldn't see on at first look.
/ Finding Brake Light Wire #6
If you mean the wiring pigtail for the brake controller when you say "SPARE TERMINAL", you will not have it if the truck is not tow package equipped.
Take a look at the link I posted above. I know its labeled Jeep but its Dodge. Just found it in the Jeep section of his site.
Chris
Thanks everyone. I looked today and found a white/tan wire and tested it and it was the brake light. That tip saved me from checking the other 5 or so from the switch. Looks like I can use the boot around the hood release cable to run the wires through the firewall. This is looking a lot easier now.
/ Finding Brake Light Wire #8
Glad the info we gave you helped.
Chris
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A61573)
2016 Peterbilt 579...
2001 KENWORTH W900 72" STUDIO SLEEPER (A62613)
2001 KENWORTH W900...
Pemberton Inc Komatsu Forks and Frame (A64194)
Pemberton Inc...
2015 Volkswagen Golf SportWagen Sedan (A61574)
2015 Volkswagen...
Willmar and AgChem Parts and Service Manuals (A63117)
Willmar and AgChem...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
