Ford 3000
/ Ford 3000 #1
Donovan Caro
Member
Ford 3000
My grandfather purchased a ford 3000 new and gave it to me this year. I'm looking to rebuild the motor due to burning oil and throwing it out the muffler. And also wanting to put a power steering kit on it. Plain on using this tractor to turn a 8' vicon and haul round bales around the farm. My question is the PRODUCTION CODES, SERIAL & MODEL NUMBERS on the
Right Hand Side don't match nothing I'm seeing on the net this tractor is in good shape never sleep outside in the weather the numbers or very readable unless someone didn't stamp them all this is what they or in this order if any one can tell me what they or so I can order what I need and know a little more about this tractor.
Thanks,
6L4C
L166
B*831166
/ Ford 3000 #2
\\Donovan
Information about the numbers:
FORD TRACTOR
6L4C = A production code meaning 1966, November 4, Afternoon shift.
L166 = I do not know.
B*831166 = Probably a serial number where B = Basildon, England, UK.
Best place to check the numbers are a label on the underside of hood over battery.
/ Ford 3000 #3
should be a model id code there as well.. look under the hood for a tag, and look on the other side of the bellhousing as well.
soundguy
/ Ford 3000
There's no tag under the hood there is another # on the other side c 7008.
/ Ford 3000 #5
if it's a pre 4-68 machine then you are looking for one that starts with a 3 stamped in mind you.. not raised cast in.
soundguy
/ Ford 3000
I'll look for another one that # was a stamped # it was on the left side under the hydraulic pump.
Thanks, for your help
/ Ford 3000
Not sure think meaning it could start with a # 3
I was trying to find the model#
/ Ford 3000 #10
the only place to find the model number of the tractor is on the little metal tag under the hood the numbers stamped on the trans is the build code and the serial number thats it
/ Ford 3000 #12
how u can tell if it is really a 3000 is if it has drie drum brakes the hyd pump does not have the filter on it, is 3 cyl. and has the flow control valve on the side of the rear diff. on the right side
/ Ford 3000
3000 is wrote on the hood. But yes it does have the flow control valve it is a 3 cyl. The hydraulic filter is in the rear end done changed that already.
/ Ford 3000 #14
what is the 3 for
if his date code makes it a 66 model.. which it looks like it does, then his model id will start with a 3.. if it is a 4-68+ model it will start with a C
soundguy
/ Ford 3000
Guys I never could find nothing on that only others I have found.
6L4C
L166
B831166
Engine has others production #
E
60L13
4F20C
Engine serial #
*C641228*
On transmission production code under hydraulic pump
C7008
That's about all I found
Thanks,
/ Ford 3000 #17
It looks like the engine has been replaced, it´s from 1974.
/ Ford 3000
That's what I was thinking but he said no but also his 94 years old but the engine starts with a c is that united states make if so the trans. Also starts with a c. Couldn't find a # on the rear axle.
/ Ford 3000 #19
i believe you are confusing model and serial number.
sn on the trans bellhousing will begin with an A for antwerp belgium, B for basildon england, or C for a US made one.
the Model ID number for a 3000 series will begin with a 3 if it is before a 4-1968 model, and C if it is a 4-68 or later model.
soundguy
/ Ford 3000
This is a couple of pictures
