Improvised pull mowers
/ Improvised pull mowers #1
J2E
Craftsman
Hey all, I wanted to share my current improvised pull mower setup and see if anyone has any thoughts about modifying it.
This all started when I purchased a new home with 1.5 acres of lawn. My FIL had an old Craftsman 42" rider that had been sitting unused in a shed since 98. New battery, plug, air and fuel filter, and fuel and it was in wonderful condition. First time out it took me probably 3 hours to mow it all. Off to Craigslist and happen to find 2 almost identical mowers to pull behind the mower to increase the width. Both have the same 22" deck, one's a 5 and the other is a 6hp. Total cost for push mowers = $55.
Used some scrap iron laying around to build an A frame and now I have about 78" of mowing deck that cut my time down to about 1.5 hours give or take.
I'd really love to have them both swing off the left side to avoid the discharge chute and also so I can run my front right tire up along the already cut line and not have to keep looking back to adjust based on the back right mower. I found a video of a gentleman who looks like he's solved the problem and they look like they do really well trailing.
YouTube - mobmower2
He's got quite a few more mowers than I would have but the principle is the same.
/ Improvised pull mowers #2
The safety of the approach would be my only concern.
I shudder when I see anyone around a push mower other than the one doing the pushing. Too much debris that can be shot out at by-standers and the guy on the pulling tractor is a by-stander.
Tending the running mowers while getting on and off the pulling tractor is another concern.
I see it as a fun project but a temporary solution to mowing the lawn.
/ Improvised pull mowers #3
On its face it would seem like it wouldn't be an especially fuel efficient solution to the problem. I do like the thriftiness of using used push mowers..... I've even seen them in running condition offered for free.
/ Improvised pull mowers #4
This old man at age 82 has done it like that for years.
/ Improvised pull mowers #5
Just curious, why is a push mower any more dangerous than other mowers?
To the original poster, how slow are you going that it takes 1.5 hours to mow 1.5 acers? That seems painfully slow to me. I bet you get some looks from the neighbors. :D
/ Improvised pull mowers #6
YouTube - mobmower2
That is a great setup. Yeah, he might get some looks from the neighbors, but secretly they are all jealous. :D
If you were concerned about the safety and fuel efficiency of this type of setup, I suppose you could try the same thing with reel mowers instead.
/ Improvised pull mowers #7
Hey I like it!! The fact it only cost you $55 is great. I'm building an offset mower to compliment my riding mower. I have a 16hp engine and 48" deck that I'm using. I guesstimate it will end up costing me around $250. Once I have it hooked up, I will be actually mowing 7.5' per pass.
When I get it done, I'll try to get some pics posted.
/ Improvised pull mowers #8
Don't think I said they were more dangerous.
Just that being around them is dangerous.
/ Improvised pull mowers #9
I like the setup myself. When I was a kid (MANY moons ago) we had a 2 acre front yard on our farm, and our beater riding mower's blade assembly took a major, unrepairable crap. He hooked up three (no idea where he got em) push mowers behind the rider, and pulled the blade setup off of the rider. Did this for a whole summer, till he bought a really nice rider to replace it all. People would actually stop on the road, just to watch me mow:thumbsup:.
Sure cut my mowing time WAY down. I actually got to do some fun stuff on Saturdays, beside mow and clean the barn stalls.
As for the "all on one side" idea, Consider making a multi point mount. I would connect the main pull bar with at least two holes in the rear bracket, and a third coming from somewhere up towards the front of the tractor. These two mounting points would anchor the tow bar solidly to the tractor.
I would then hook the two push mowers to the pull bar, with a single pivot point, kinda like the gut in the vider. This would allow them to swivel when you turned, making turning easier. Just a thought. not sure how well the rear bracket will handle the torque of the pull bar.
/ Improvised pull mowers #10
An Aussie road train to mow lawns with in the YouTube video. It's not for me; but if the guy is happy with it, more power to him.
/ Improvised pull mowers #11
I guess you don't like your riding mower.
If you did, you wouldn't care that it took a few extra minutes to finish mowing:laughing:
I see it is a Craftsman;)
Thanks all for the comments. I will note that in the pictures I had something that held open the bagger 'flap' on the rear so the clippings would discharge out the back instead of mulching. That is likely the most dangerous thing I did with them and have since stopped after the initial trial mow. They now mulch and I haven't noticed any significant impact on performance.
It's probably not the most fuel efficient. I would love to switch the push mowers over to electric like here: LeeMower.htm I just have to shell out more $ to get the motors, batteries, solar chargers, etc. Starting with gas was a lower up front cost to get started and I've probably mowed with it 2-3 times as I bought the house late in the year.
Rider has 6 speeds and I'm typically in 4th or 5th. The back lawn is about an acre total, rectangular with no trees or other obsacles so that's helpful with this setup. For the front I may make a few passes with this but then just go with the rider as there is a lot of trees to navigate around.
If my deck is conservatively 80" and I travel at walking speed (3.1mph, might be conservative) in a straight line, I'll cut 2.5 acres per hour. Now factor in turning around, not mowing perfectly etc and I'd probably guess I'm cutting 1.5 acres in 1 to 1.5 hours.
I looked into reel mowers as well. I wasn't sure they'd work well with my lawn and since I wanted to try to do this as cheaply as possible I went with gas power. Long run reels would pay for themselves but I have no experience with them and keeping them sharp and functional.
I've seen some very large deck offsets. I'd love to go that route but I'm hoping most of my lawn will be converted to garden and orchard so I won't be going any bigger than I currently use. I tried to go as inexpensive as possible. Look forward to seeing pictures.
I don't have a lot of confidence in the rear braket and it's torque capabilities. Pulling a couple mowers balanced out isn't a problem.
I like my riding mower just fine. It was free. I think your logic equating liking a mower with liking to spend twice as long on it is flawed. I like riding my bike, but that doesn't mean I want to ride it twice as long as I do.
/ Improvised pull mowers #13
I never said it was a problem, but it WAS your idea to put them off to one side. It was just a suggestion to help you do what you wanted. In fact pulling them balanced is the BEST way to do it.
Think there's some confusion. I was just saying that pulling 2 balanced is no problem for the rear bracket. Even though I want to put them off to one side, I do question if the rear bracket has the torque capacity.
/ Improvised pull mowers #15
I think hes getting a little testy:laughing:
Really
Nope, just trying to avoid confusion.
/ Improvised pull mowers #17
Think there's some confusion. I was just saying that pulling 2 balanced is no problem for the rear bracket. :thumbsup:
Yea I wondered about that myself. That was why the diagonal side bracket might be necessary,
Thanks for clearing it all up:D
/ Improvised pull mowers #18
I don't have a push mower rigged out to the side like you have.
But I do have a 22'' push mower attached to a 60 inch long pallet that's on the my clamp on bucket forks which puts it out in front of the front wheels of the tractor about 9 feet.
I use it to mow out over banks and ditches.
/ Improvised pull mowers #19
Oh dude, I'd love to see a picture of that!!!
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
1997 International 3800 School Bus (A64194)
1997 International...
2022 EZ-GO ELITE...
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
2025 LandHonor RGB-11-72W 72in Hydraulic Dual Cylinder Rock Grapple Bucket Skid Steer Attachment (A64553)
2025 LandHonor...
