help broke zerk fitting
/ help broke zerk fitting #21
A tapping die is tapered, there inst enough room between the axle and auger shaft for this.
You would have to look for a bottom tap. It's not as tapered as a standard tap. It's for tapping threads to the bottom of a blind hole.
8O9JK6ikrlTLVzr320ZiRLEWgkUzEBDJLZ59gcW7Moic54WWQxWVIlsXFdfEEghn-MiJJk2JDNVvn-a18D5iaT3IjEbYPEXZHI-fK9M5VcAG_EZyVaKjBSoSadrmlluWcg-XZWL-D5JLQ8B7tTB2CM7mBld-HxENnn3NVlGgcf_yEVugxbjeI46ealy00TWsGmVdzzWoTxxsY2p09b5U5e_2F4mtCIFowWzpPaAIVs5Azigme7EpXb0eg1b989UiLWL6hfDUiwlBV-7IOLSkw87aj9-Y1bQ1_9_Hwn738wQ
I just ran down to tractor store supply and picked up a rubber tipped coupler. It worked like a charm. I didnt have to push that hard either to keep the grease from squeezing out. Thank you guys for suggesting that to me. I dont see a reason to fuss with trying to put a new zerk on. I will just keep the rubber coupler handy. So easy. Great idea. Thanks again.
/ help broke zerk fitting #23
Grease zerks are tapered pipe thread. No such thing as a bottom hole pipe tap. I have ground off the end of a pipe tap when I needed to tap a shallow hole though. If he does anything, I would agree welding a threaded collar to the tube would be the easiest. There shouldn't be enough heat transfer to the shaft to hurt it. You would need to be careful not to burn though the tube and into the shaft though. I would use a series of tack welds rather than a continuous weld.
Kim
2019 Toyota Mirai Sedan (A64557)
2019 Toyota Mirai...
John Deere Lift Arms (A65640)
John Deere Lift...
(4) Hydraulic Cylinders (A65640)
(4) Hydraulic...
2019 KENWORTH T880 DUMP TRUCK (A65054)
2019 KENWORTH T880...
2012 Great Dane 53' Van Trailer (A66285)
2012 Great Dane...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
