jd790 fel curl problem
/ jd790 fel curl problem #1
omrebel
Member
SOUTH MS
JD 3038e
My 790 with 419 loader has a problem when trying to slowly curl. Instead of curling the bucket goes down(dumps slightly). If you curl more aggressivly (even slighly more) it works fine. Anyone know waht I could check? Thanks
/ jd790 fel curl problem #2
Does it "power" down or does it just fall due the gravity? If it's the later I would suspect the "load checks" in the valve (#6 in the diagram), they keep the bucket from moving until there is positive pressure.
Just gravity I think. It's worse with a load. It will hold until you try to easy-curl. Are the load-checks easy to replace?
/ jd790 fel curl problem #4
You will have to see how accessible they are...but generally yes.
Thanks again for your help.
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2022 EZ-GO ELITE...
2007 Lexus RX 400H Hybrid SUV (A64557)
2007 Lexus RX 400H...
2015 Kubota ZD221 48in. Zero Turn Commercial Mower (A64194)
2015 Kubota ZD221...
2019 CRUISE CAR INC ENCLOSED UTILITY CARGO CAR (A67148)
2019 CRUISE CAR...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
