Cutter Recomendation
/ Cutter Recomendation #1
hunting4deere
Southeastern NC
2008 John Deere 5225, 1975 Ford 3000 Diesel, 1998 NH 6610 w/forestry pkg.
Can you all recomend a heavy duty skid steer bush hog type mover/cutter. The dept. I work with is interested in purchasing one and I have seen a Davco and it looks pretty sturdy but I'm sure there are others. It will be going on a Cat 287c high flow. It will used for cutting anything from bay bushes to small trees 6"(+/-). We already have a Fecon head but looking a Bush hog cutter.
Thanks
/ Cutter Recomendation #2
Davco is the best rotary. Expensive but the best.
Ammbusher is good but the motors and bearing housing break under extreme conditions (like rocks or hidden stumps).
I also have a Bradco and it is OK in material up to 3 inches and good for field mowing. It is half the cost of the Davco.
Thanks
Thanks Qwik, with this machine there is no telling who my be running it and what they may try to cut when no ones looking.
/ Cutter Recomendation #4
I have Run an Ambusher for about four years. Quickdraw is right about the rocks and stumps. My biggest problem has been fat lighter stumps breaking blades when they get a little wear on them. It will cut an occasional six inch sweet gum, but a steady diet will ruin the shaft assembly and motor. i don't know of any except a Hydoax mower that will hold up on big stuff.
/ Cutter Recomendation #5
Davco isn't exactly a bushhog type, though. I ran a davco for a few years. It didn't chop near as fine as my Brushcat but it was built to knock down heavier woody material. Wasn't as good on high weeds and remulching cut stuff because the blades are short.
I like the newer brushcats from Bobcat. Much heavier duty gearbox and suspension linkange than any previous version and they follow the ground good.
Davco is a more simple cutter without a lot of moving linkage if you are just looking for a heavy duty rotary for taking out brush and small trees.
2018 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 KENWORTH T680...
2015 Mack CXU613 Tri-Axle Day Cab Truck Tractor (A64194)
2015 Mack CXU613...
2007 Ford E-250 Cargo Van (A64556)
2007 Ford E-250...
Front Tank Bracket (A64126)
Front Tank Bracket...
2003 Freightliner FS65 Thomas School Bus (A64194)
2003 Freightliner...
2018 Chevrolet Suburban 4x4 SUV (A64557)
2018 Chevrolet...
