Tree Puller for hard to get at trees
   / Tree Puller for hard to get at trees #81
I'd like to see a picture of that. For some reason I'm not able to grasp the concept :(
Not nearby to photograph but maybe can describe it better. Get 6" long piece of 2" id schedule 40 iron pipe. At one end on the outside weld the end link of 3-4 link piece of 5/16 or 3/8 chain. Now one end is attached with 2-3 links hanging. Construction completed. Pass the grab hook end of your pulling chain through the pipe from the same end that the links are welded to. Wrap the pulling chain around the tree & attach the grab hook to the loose end link of the chain welded to the pipe. This forms a noose around the tree. When you pull the tractor end of the pulling chain tight the noose tightens pulling the end of the pipe perpendicular toward the tree where it bites into the bark/wood. Further pullng tips the pipe parallel with the tree ( as the tree tips over) & levers the noose tighter.
Hope that helps. I tried to find a sketchpad program online but none would me save my drawing. MikeD74T
   / Tree Puller for hard to get at trees #82
Thank you. 1 more question. Is the pipe horizontal, or vertical - assuming the tree is vertical?
   / Tree Puller for hard to get at trees #83
The pipe is parallel with the pulling chain because the pulling chain passes thru the pipe. If you have a long low hitch the pipe & chain will start out horizontal, short hitch it may be angled upward to the point of attachment on the tractor.
ICC Type J-1 New England Style Cable Choker This is a cable logging choker. Imagine the pulling chain where the cable is, the pipe where the slider is, the 3 links attached to the pipe , & a grab hook on the end of the pulling chain ( where the links are on the cable) to hook to the links now on the pipe.
You could also use a grab hook welded to the pipe and just hook the bitter end of the pulling chain to it. Hope that's not even more confusing. MikeD74T
   / Tree Puller for hard to get at trees #84
Now I get it. thank you. Sorry for being so dense.
:eek:
   / Tree Puller for hard to get at trees #85
MikeD74T
I like the choker idea. It took me a while to see it too. OpenOffice.org - The Free and Open Productivity Suite includes a draw program. Chain is hard to draw. Does this fit your description?
After the earlier posts about the Weed Wrench I had to try making one this weekend. I printed the patent drawings as a guide. I added an additional pivot point where the original design seems to use the slop in the slider to compensate for the arc path of the handle pivot. The handle, fixed jaw support, and base are 1x2x1/8" tube. The slider is 1.5 x 1.5 x 3/16 and the slider sleeve is 2 x 2 x 3/16. I gobbed some hard facing on the jaws and ground it sharp to make grippers. The 5/16 SHCS (180,000psi) pivot bolts seem to be holding up in the single shear pivots. I tried one of mild steel and it bent. Oh yeah, it works really good! I was having so much fun with it I gave myself a sore back! :)
   / Tree Puller for hard to get at trees #86
   / Tree Puller for hard to get at trees #87
Except for a method to attach the chain, it seems that a 6x6 with a chain groove would work. How would it be to cut the groove in the top of the 6x6, attach a chain in the groove that extends far enough one way to wrap around the tree and far enough the other way to hook pull chain from the tractor? Again, not sure how to attach the chain in the groove, maybe with long lag bolts? Would a 6 foot 6X6 be too cumbersome to keep upright while hooking up the chains?
Just thinking out loud. Help me if this has merit.
   / Tree Puller for hard to get at trees #88
I think you really need the bipod design because like you said it will not want to stay upright and could flop over violently under tension.
   / Tree Puller for hard to get at trees #90
Have any of you tried or reviewed the portable winch web site. I own one of these winches and have pulled many a tree. Some as large as 24 inches in diameter at the base. This past year I made my own pulley block with triple pulleys. Ten thousand pounds of pulling power. Have to use low stretch polyethylene rope. A lot safer than steel rope or chain. With the block at the base of another tree you can stay out of the path of the falling tree. I think the web site is portablewinch.com
   / Tree Puller for hard to get at trees #92
Funny you should bring that up.
When I was in my teens (30+ years ago) I used to do the same at the farm as all we really had was the Farmall Cub to pull down trees. Being around a boating community I had access to many blocks and mass quantity of rope. As you mentioned what was great was you could pull to the side or opposite where your trying to put the tree, making it much safer. I still have those blocks and rope.
Going up the tree for the attachment also helped the leverage.
   / Tree Puller for hard to get at trees #93
As soon as the ground thaws a bit more I plan to try this with 5/8 double braided Polyester and a few strategically located snatch blocks to compound the pull and get me & my tractor far away from the tree & out of the line of action. Actual attachment to the tree will be with 1" nylon double braided, a big block and a nylon sling wrapped around the base of another tree for an anchor. I intend to start small and work my way up.
As jsf2292 mentioned, going the trunk up really helps your leverage. To this end I'm thinking of making a little air bazooka to cast a throwing weight over a suitable limb. That or I've seen some wrist rocket surgical tubing type contraptions that might be simpler. I dunno. I just like being able to say bazooka in casual conversation.
-Jim
   / Tree Puller for hard to get at trees #94
I've used my jeep winch to assist in felling a few pretty good sized trees, I used a climber tree stand to get up the tree to attach the cable. I use a 100 ft 1/2" wrecker cable, one end hooked to the tree and the other hooked to a snach block. The winch cable runs through the snach block and hooks to a nearby tree.
   / Tree Puller for hard to get at trees #95
I would be *very* careful using rope of any sort, steel or nylon. If something breaks or lets loose, it will be a slingshot coming back at you. There have been people killed trying this.
   / Tree Puller for hard to get at trees #96
with over 4,000 x-mas trees in the ground, I have an ongoing need to pull the dead ones so I can replant. I've been using a HD Brush Grubber, which works fine for the trees on the edges of the fields, but I can't use it in the middle of the fields because the tractor would tear up the other trees.
After reading this thread, I decided to build a weed wrench copy like Brad_Blazer - I went with the simpler design of the original, which works fine - this thing is great, works good on my trees up to about 4 foot tall - and a lot quicker than using the grubber.
Jeff
   / Tree Puller for hard to get at trees #97
This is a really old thread I'm reviving but I sure am glad I found it. I've been pulling down some trees in an area along an old creek bed where I'm building a pond. I've been doing it the hard way. First I use a subsoiler to bust as many spread roots as possible. Then I use a ladder to put a cinch chain around the tree about 8 feet above the ground, then run 40 feet of grade 70 chain to the draw bar of the tractor to pull the tree over. I am using an old tire for a damper about half way in the length of chain in case of chain failure (run the chain through the eye of the tire and let the tire hang on the chain). It has been so-so in the success rate. Of course, smaller trees with a trunk of 4 inches or less have been pretty easy since my land is sandy. However, some of the "trash" trees really surprised me. Chinese Tallow trees have pretty large spread roots as well as a major tap root. I'm going to build an A frame about 6 feet tall. I plan on making a complete triangle out of the pipe since portability isn't a necessity. The base pipe will be around 5 feet so I can haul it on my trailer. The base pipe will lay on the ground with the 2 upright pipes welded to it. That way I should get a pretty good footing but the frame will still be able to rock over as the tree comes up.
   / Tree Puller for hard to get at trees #98
Make sure you take some pictures for us!
I can't believe I've never thought of putting an old tire halfway along the length of the chain. That's a really good idea.
   / Tree Puller for hard to get at trees #99
You guys scare me.... We had a local with a large field tractor pulling a truck out of a ditch with heavy chain .. and very unlike chain, which should not stretch-and-snap like wire rope or nylon (the worst) rope ..it came back. In some respects, it's too bad it didn't kill him.
I love the idea of fulcrum and leverage, but somehow I would only do it if I was able to anchor the chain to a fixed point and pull a short distance 90deg from that anchor point.
Jim
   / Tree Puller for hard to get at trees #100
Jim
With as much force as a tractor will put on the chain, there is a possibility the chain will recoil. That's the reason I put a tire on the chain. It acts as a damper should the chain fail. I in fact intend to start using two old tires thus splitting the length of chain into thirds. That should give me an even greater safety margin.
I'll post some pics of my fulcrum frame as soon as I finish it. I pretty much have it finished but I changed the way I made it from my original plan. I thought I was finished with it but I see a week point I want to reinforce.
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A59823)
KNOW BEFORE YOU...
LEEBOY 8510 ASPHALT PAVER (A60429)
LEEBOY 8510...
2016 CATERPILLAR 349FL EXCAVATOR (A60429)
2016 CATERPILLAR...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
2020 CATERPILLAR D5K2 LGP CRAWLER DOZER (A60429)
2020 CATERPILLAR...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
