practicing with my new mig Question ?
/ practicing with my new mig Question ? #21
mig stands for metal inert gas. if you dont have a tank of gas you are not mig welding. Unless you are doing some really heavy welding i would not use .045. .035 is an all around good size .030 for really thin stuff
/ practicing with my new mig Question ? #22
why do you say if i am using 1/8--3/16 it will not give the best results? You are by the way correct on this size range as far as what the welder is ment for smaller too i believe. If it is ment for that size why would'nt i get good results practicing? I have been working on an old mower blade making passes.It is'nt that i dont believe it's that i dont follow what you are trying to tell me. thanks for the advice keep trying i'll get it soon i hope.
The sentence should read, If you are NOT using 1/8 3/16 in stock to practice with. Each wire size has a current range in which it will weld that matches the stock thickness and current required, there is overlap of the ranges. Some boxes of wire will have a chart showing the stock thickness and wire size. This all limited by the power of your unit.
Just because the weld bead looks good dose not make it strong.
If you are getting full penetration, you will see that the back side of the coupon is starting to melt through for a butt weld. For thicker stock and other joints you will have to V- grove and/or use small gaps, 0.030 wires makes a good gauge. What you want to see is a weld bead that looks like a stack of dimes.
yep just checked it out the wire it is 12ga and not 14ga so i will get a 20 amp breaker.Been buisy today went to Ellsworth Maine about 75 miles away and bought a used Porter Cable pancake compressor and while i was there i also picked up a Johnsered 2040 Turbo saw think i will give that one to my son.
/ practicing with my new mig Question ? #24
I just started learning MIG welding a few months ago when I sprang for a HF 151. Lots of spatter with their included FC wire. I added a gas bottle, some 75/25 and Lincoln wire and the spatter went to near zero. And that's with a rank amateur and a mediocre welder. So yeah, try it with gas.
/ practicing with my new mig Question ? #25
One thing that gets overlooked buying welders is duty cycle, some welders may have as low as 20% duty cycle and that means it needs to sit idle 80% of the time its hard to do much work with one of them.
Shield Arc mentioned it describing one of his toys and it is a big consideration if you plan on building anything that takes a lot of welding.
That may be part of the problem too the welder may just be shutting itself down to cool off?
/ practicing with my new mig Question ? #26
I've got a Lincoln SP125 Plus and I've only hit the duty cycle limit one time in about 10 years of infrequent use. I've probably put 4 or 5 rolls of wire through it. It seems the time you have repositioning yourself, cleaning, clamping and unclamping, etc gives it enough cooling time. It's been a non issue for me. I've got a 255 now so the little welder gets used only on the thin or outdoor stuff.
Kim
/ practicing with my new mig Question ? #27
I don't think duty cycle is that much of an issue for the average guy. But I never dreamed there are machines on the market with as low as 20 % duty cycle tho!:confused2: Personally I would do just about anything to avoid a Mig machine that didn't have 100 % duty cycle. I also think they are harder to come by.
I've been on jobs where I ran 70 + pounds of wire a day for months & months. But that was with 400-amp, 100 % duty cycle engine drives.;)
/ practicing with my new mig Question ? #28
Yup I had one it was a Solar 90 amp that's how I know what a pain it is to try to actually build something with one.
I used mine on automotive sheet metal when I was building wrecks and finally bought a bigger one its 100% at 250 amps and I can still weld sheet metal and everything else.
/ practicing with my new mig Question ? #29
An important point to bring out:
Nearly every welder is a 100% duty cycle welder at some point. Duty cycles vary with amperage output. It is also a tool that has often been skewed by marketing, especially in MIGs.
A Mig's duty cycle rating, is almost always rated at an amperage LESS than the maximum output of the welder in order to improve the rating. People are buying what they think is a 200 amp unit and they are, but with a duty cycle rating of may 8-10% at maximum rating. The actual duty cycle may be rated for an amp level as much as 50 amps lower than the maximum output. The "effective" range of output, where welding is practical is really overlooked, and often it is hard to compare apples to apples across brands. The only way to get a true picture of performance is to look at the amps where the duty cycle is given, and try to compare other units in that range.
But companies count on the ignorance of a customer to promote their product. I am not picking on Miller here,but for example... I get a constant request for comparing their 211 model against our 200 model.
They advertise 210 amp output....That's quite good for a small box welder. Ours is only 200 max output...which is a LITTLE weaker. They also advertise 30% duty cycle...but it is only at 150 amps. Ours is 35% not much more, but it is at 160 amps. Our rating at 150 amps is actually 40%. Our 60% duty cycle rating is at 135 amps, and 100% duty cycle rating is right at 100 amps. Miller rates their 100 amp level at 60% and there 100% is around 50 amps or so.
What most people don't realize that the average weld is at a much lower than the 200 amps. In fact, if you were to put an amp meter on it, I would say the amp level would top out at about 130 -160 amps or so for most short circuit welds on average with .030 or .035. So having a high end is great advertisement, but having a respectable duty cycle in the main range of use is more important.
My point being, when you look at duty cycle compare closely the performance at different levels of out put, if you can and consider the type of welding you will be doing. Shield Arc has welded in heavy industrial applications, where it was not an option to take a break. But in reality most MIG welders never get above a 60% duty cycle, even at maximum amps. IF you think you need more duty cycle, then simply get a bigger welder...
/ practicing with my new mig Question ? #30
I don't know if it was really all that heavy Mark? Splicing 36-inch x 300 pound I-beams. Well I guess you can't just throw them on your shoulder and walk off tho. :laughing:
/ practicing with my new mig Question ? #31
I think these were W14-inch x 311-pound beams. Something like 2 1/4-inch thick flanges.:D
/ practicing with my new mig Question ? #32
I'll bet you weld that out "quick a minute":laughing:
Seriously, how long to fit and weld out a joint like that???
/ practicing with my new mig Question ? #33
A lot of variables to that question. If at all possible we would try and weld everything flat, (roll it).
It's been so long now I think that job was in 1987. I would guess 5 to 6-hours, if everything went right.:rolleyes: :D
/ practicing with my new mig Question ? #34
Not as long as I thought it would take, we recently put in some 12" sch 40 steam main and that was about 3 hrs per joint, B31.1 of course.
/ practicing with my new mig Question ? #35
What is B31.1?
Did you do that with SMAW or GMAW?
We normally ran 5/64" dia. wire, and sometimes we would have the large LN-7, 8, or 9 wire feeders which will all take 60-pound coils of wire. Then we would go with 3/32" dia. wire. Either 5/64" or 3/32" dia. wire will really lay down the iron with 400 to 500-amps pushing it!;)
/ practicing with my new mig Question ? #36
What is B31.1?
B31.1 is an ASME pipe welding code. The procedure was for 1/8 6010 open root, 3/32 7018 fill & cap, all uphill.
And I am not a pipe welder but it was my project.
/ practicing with my new mig Question ? #37
That will separate the men from the boys. We run 1/16" Dual Shield for almost everything at the shop. We tried running a few spools of 5/64". Worked great doing build up in the rotators (have run 3/32" Dual Shield and 1/8" sub arc there too), but that is a challenge running by hand for someone like me (machinist who also welds once in a while). Our GOOD welders could get along OK with it, but it was a handful for me.
Kim
/ practicing with my new mig Question ? #38
Thanks for the info Kevin, I'm not up on pipe codes, or pipe welding so to speak.:eek:
Kim
Kim it's really not that hard. When splicing these beams we would generally use start, and run off tabs. Short piece of angle iron on each side of the flange works great. and a piece of flatbar on the web. When the splice is complete just torch them off and grind flush. With these tabs you can run hot and fast! ;)
/ practicing with my new mig Question ? #39
I forgot to mention that the amps run about 90 for that type of weld.
/ practicing with my new mig Question ? #40
I have used run off tabs several times. Then air arc them off. I'm sure a little practice with it would have helped. I just went back to using the 1/16" I was comfortable with.
Kim
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63276)
KNOW BEFORE YOU...
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
2018 International WorkStar 7400 T/A Lely 4,500 Gallon Septic Wet Vacuum Truck (A61568)
2018 International...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
