Forks 2000# vs. 3500# Forks
/ 2000# vs. 3500# Forks #1
Deere Dude
Elite Member
Beaver Dam Wisconsin then to Hohenwald, TN
John Deere 3720
I have a 3720 with a CX 300 loader and heard arguments both ways for heavier or lighter forks. Stronger vs. lifting capacity. If forks are heavier, you can lift less. If forks are lighter, they bend easier.
The question is; If you have a tractor approximately my size and you have either a light size or a heavy size set of forks, do you regret getting the one you have and wish you would have gotten the other size?
I had people with a 2000 series and heavy forks complain about the lifting capacity.
I am trying to decide what weight capacity to get. Depends on the responses I get here. Thanks
/ 2000# vs. 3500# Forks #2
Are you really ever going to lift anything like a ton? I bought a set of cheap clamp on forks and they're just what I need for occational lifting of gadgets and stuff.
/ 2000# vs. 3500# Forks #3
As long as the fork capacity is at or above the lift capacity of your loader you will be ok. Anything heavier just reduces the load you can carry.
I have a 3520 with a 300CX loader. My 1800 lb capacity, Everything Attachments forks handle everything my rig can throw at them. I have had them about four years now and have hit the limits on my loader hydraulics numerous times with no damage to the forks.
I'm sure I'll lift as heavy of a load as I can with that tractor. Some light stuff no doubt, but also at times I will max out the tractor I'm sure. That's just me.
/ 2000# vs. 3500# Forks #5
That's everybody, not just you.. but with forks on? A buddy of mine has a heavy duty set on a bigger CUT and he can almost move a cube of block with it. Max loads are hairy. Leave some safety margin and you're better off, unless you're moving stumps or something you don't mind dropping.
/ 2000# vs. 3500# Forks #6
I would recommend buying forks that are rated higher than the loader's breakout force rather than lifting force. I don't think 3500 lb forks weigh that much more than 2000 lb forks anyhow.:2cents:
/ 2000# vs. 3500# Forks #7
Very good point^^^^^
/ 2000# vs. 3500# Forks #8
Since the cx loader doesn't lift 2000lbs you'll be fine. I've got the horst 2000 lbs for my 300x and they're well built.
Matt:thumbsup:
/ 2000# vs. 3500# Forks #9
Are you talking about forks that mount to the bucket or a set up where you remove the bucket?
/ 2000# vs. 3500# Forks #10
I have a JD4320 (48 hp as opposed to your 43 in the next larger tractor frame) with a set of Horst 3700# forks. I use them a lot and like them. I am glad I went with these heavier ones. If you are going to use them a lot, I would suggest having some hooks welded on before you bring them home. Also add the pins and eyelets for a three point option and they will be even more useful.
/ 2000# vs. 3500# Forks #11
didn't understand the "breakout force" point...not interested in digging with my forks nor can I think of where I would want to curl a load I couldn't lift. My LA853 loader and my Bradco 2500# forks make a nice match and I can fork one-ton pallets off my pickup ...right at the margin and wouldn't want to give another few hundred pounds away.
/ 2000# vs. 3500# Forks #12
A 400x or cx lifts alot more than the 300x or cx so in your case the larger capacity is justified. Keep in mind they over engineer these forks so you don't have issues.
Matt
/ 2000# vs. 3500# Forks #13
You are probably right the the 2k lb forks would be just fine, but breakout force has a lot more to do with curl power of the loader than anything to do with digging. The breakout force for the 300CX loader is 3327 lb at the pivot pins and 2416 lb out at about 19" in front of the pins where the bucket lip normally is or about the middle of fork length. Remember also, when carrying loads on forks and driving over bumps, the dynamic shock loads can far exceed the actual weight on the forks.
All that said, the 2k lb forks are probably just fine. Has anyone said what the difference in weight actually is between the 2000 lb forks and 3500 lb forks? My guess is less than 50 lb, but I don't know for sure. I have a set of forks rated at 3500 lb, but they can be upgraded to 4500 lb just by changing out the actual forks that sit on the quick-attach bracket. The heavier forks are just made of slightly thicker steel.
Everyone has to determine how they will use forks and what the extremes of loading are. As long as someone is aware that their loader may have some forces above the lift numbers, they can make a more informed decision. My point is only that a loader with a 1-ton lift can certainly produce more than that in certain cicumstances. Will it matter? Probably not would be my guess.:)
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
207278 (A52708)
207278 (A52708)
UNKNOWN 500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
UNUSED KIVEL MINI SKID STEER HITCH ADAPTER PLATE (A62130)
UNUSED KIVEL MINI...
New/Unused Landhonor Quick Attach Pallet Forks (A61166)
New/Unused...
2021 Aquasport Boat with T/A Float-On Corp Boat Trailer (A61569)
2021 Aquasport...
