John deere x520 motor problems
/ John deere x520 motor problems #1
Johndeerex728
John deaf x728
Ok this is what happened me and my dad bought the red fuel stai ball and put about 3 ounces in it's 5 gallon gas tank started it up for about 10 mins and it was fine then it sat for a week or two got started again and engine was knocking at idle and full throttle can some please help me with what's wrong.
/ John deere x520 motor problems #2
I doubt the Stabil is the problem, how long did you run it with the knocking sound? If it is in warranty i would take it to the dealer to be checked out, no point in laying a hand on it yourself.
/ John deere x520 motor problems #3
Did the oil light on the dash ever come on?
Nope it did not.
/ John deere x520 motor problems #5
Did you figure out any thing more on the knocking noise?
Well I started it las night while it was 66 degrees out and he stared up fine no knocking which is good news but bad because why was he doing it before.
/ John deere x520 motor problems #7
I'm going to guess it was cold enough that the oil didn't flow. I'm also going to guess you or your father shut it down once you heard the knocking (which may have stopped in a few minutes or less).
The oil in the sump would flow easier during the warmer (66 degrees) temperature.
So, you might want to use a lower viscosity oil during the winter months.
WHEEL LOADER ARM BRACKET (A64280)
WHEEL LOADER ARM...
2013 Volvo BL70B 4x4 Extendahoe Loader Backhoe (A61572)
2013 Volvo BL70B...
2014 KUBOTA SVL75-2 SKID STEER (A64279)
2014 KUBOTA...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A64279)
2020 CATERPILLAR...
2022 EZ-GO ELITE...
