Need an idea for a strainer
/ Need an idea for a strainer #1
gsdavis1
Cleveland, OHIO
John Deere 855
I am going to add a front crankshaft pump for my loader install. I am thinking of using the existing tractor sump for the supply. The easiest place to tap into the fluid is through the drainplug. But I am unsure how to install a simple strainer here. It would have to be very small because space is very limited.
And the simpler the better.
Thanks for your input everyone.
Greg
/ Need an idea for a strainer #2
easiest not always the smartest....
think about these points....
1. What is the purpose with the reservoir? stock back up volume of oil, provide expansion space for oil, allow ENOUGH time for oil to release air, cool down, and sediment water and particles.
2. What is the purpose with the drain plug? drain above sediments, take oil test samples
3. How does "unwanted objects" or contaminants, get into the oil?? coming from the system via return line, through the fill cap when filling oil, through the air vent, condense water from air in tank
4. How can we prevent "unwanted objects" or contaminants from getting to the oil reservoir?? return filter, fill cap strainer, air vent filter....
If you do not prevent the cause of "head ace", you will always have "head ace". Above "treatments" prevent head ace, a suction strainer is like Aspirin, only has a purpose when you already have head ace.
Unless the inside of your tank is the source of "unwanted objects" or contaminants, you do not need a strainer. Just prevent "unwanted, objects" or contaminants get to the tank.
A lot of posted hydraulic problems this cold winter, has been related clogged suction strainers, due to high oil viscosity in combination with water contamination.
put it in the fill cap hole...
That makes the strainer idea even further away from reality...
cant be simpler than that
BTW, adding another pump into a current system....make sure you have a reservoir sized for the additional oil volumes you put in circulation....see point 1 above......
Stidham 2 Horse Trailer (A65640)
Stidham 2 Horse...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63689)
2019 Takeuchi TL8...
Allis Chalmers WD45 Tractor (A66285)
Allis Chalmers...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
60ft. Truck Auger (A65640)
60ft. Truck Auger...
2010 Kenworth T3 Class 7 Flatbed, 4x2, w Tuck-Under Liftgate (A63689)
2010 Kenworth T3...
