2520 mmm question
/ 2520 mmm question #1
castiman
oswego,ny
jd 2520,jd x530
I'm trading my 2305 in on a new 2520, on my 2305 I have the independent mmm deck kit. Putting the mower adjustment knob in the lock position is how you lock your deck up,so it won't bleed down. On the 2520 it doesn't have the mower adjustment knob, that I'm aware of. They offer the same kit for the 2520, can anyone who has one tell me if the kit comes with some sort of locking device, otherwise wouldn't the kit be useless cause I'm assuming it will bleed down.
/ 2520 mmm question #2
I believe you may have to order it with that kit. My 2720 came with it, and so I am not sure, but the 2720 and the 2520 is the same tractor.
I think if you use the PTO to lift the deck you won't need it!
Wooden
/ 2520 mmm question #3
If you order the independent lift kit on the 2520, I think it does come with an adjustment knob, similar to that of the 2305, that I've seen mounted on the left hand ROPS frame (left hand, meaning as if you were sitting on the tractor). Apparently this is supposed to "Lock" the independent lifting mechanism in the up position, as well as being the cutting height control. I have read numerous comments complaining that the cylinder does leak down when in the lock position, thereby not holding the deck firmly.
I have a 2520, I didn't like the idea of having to use 2 of the outlets from the SCV valve in order to power the mower lift cylinder, and the only way to get away from this is to add the JD kit that adds 2 more outlets at the SCV in order to keep all 4 lines to the loader connected, as well as the 2 lines required for the deck. With this set-up, you still need to change a control valve setting on the SCV when switching back and forth between loader and mower.
I didn't buy the independent lift for the mower, and use the mechanical system using the 3PTH to control my mower deck. This then leaves all 4 SCV outlets free for the loader, and saves the cost of the additional outlet kit, as well as the Independent lift kit.
When using the 3PTH as the mower control, JD does have a "deck lock up" kit, so you can lock up the deck, and still have the use of the 3 PTH, if you need it. The kit is kinda' expensive for what you get, (around $175) a couple of brackets and a pair of adjustable chains that you have to manually attach to the brackets, but it works, and I sure don't have the expertise to build one. A lot cheaper than the Independent lift, additional SCV outlets, and the labor to install it all.
For my needs, it was a lot cheaper to stay with the mechanical lift for the mower, and for the odd time I may want to use the 3PTH without having the deck also go up and down, I just attach the lock-up chains. Right now, I have my deck off, and front blade on, so the chains are holding up the deck lift arms. I have my ballast box attached to the 3PTH and have full control of the 3PTH, without the deck lifting arms also going up and down with the ballast box. And by the way, the chains don't leak down.
REV
/ 2520 mmm question
REV
Thanks,for the info. My main concern is having the 3point hitch going up and down with the mower deck. I'm going to have a quick hitch onto the 3point hitch and I don't want that riding close to the ground.
/ 2520 mmm question #5
If you are you talking about the "I" match hitch, at it's lowest point, it is well off the ground.
I have the 2" reciever hitch, that attaches to my "I" match, and I leave it on all the time. It just goes up and down with the deck. Doesn't interfere with anything.
REV
/ 2520 mmm question #6
My 2520 has independent lift, and yes, the height adjustment is to the left of the seat, on top of the fender. It's basically a knob attached to a cable that runs down through the fender and attaches to the lift mechanism so as to limit it's travel. I use it to lock the deck all the way up, or to lock the lift up when the deck is not attached.
I'm also glad I have the diverter valve so that I can switch hydraulic functions without switching the hose connections. That way, when I forget to lift the deck all the way up after attaching the FEL, I don't have to say bad words.
Here's a picture someone else posted of the height adjustment on the 2520/2720.
/ 2520 mmm question #7
REV
However, for me, sometimes I want to use the MMM 62D on my 2520 while i have a cultivator on the 3ph. For this, I use some chain to hold up the 3ph draft arrms so the cultivator does not hit the ground.
