Hyd pump overhaul???
/ Hyd pump overhaul??? #1
horticattleman
South Central Louisiana
CT335
SInce my old 425 is now "new" the last thing I have to re-do is the hyd pump. Are there seals to change, how hard, ????????
/ Hyd pump overhaul??? #2
The first question is which pump? Mine has three:
1. Variable output drive pump with tram pedal control
2. Fixed output PTO pump with solenoid control
3. Fixed output Aux PTO pump that controls the lift, tilt, steering and Aux PTO functions
Overhauling 2 or 3 should be relatively straightforward and inexpensive. Overhauling #1 is much more complicated and expensive due to having a charge pump, swash plates, etc. Terry quoted me around $900 to rebuilt mine at Tazewell a few years back.
/ Hyd pump overhaul??? #3
What symptoms are you finding that drives the rebuild of the pumps?
CAT930K (A58214)
CAT930K (A58214)
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
2010 Deere 318D (A60462)
2010 Deere 318D...
Wooden Bench (A61570)
2004 FRAC TANK 500BBL WHEELED (A60736)
2004 FRAC TANK...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
