Hyd pump overhaul???
/ Hyd pump overhaul??? #1
horticattleman
South Central Louisiana
CT335
SInce my old 425 is now "new" the last thing I have to re-do is the hyd pump. Are there seals to change, how hard, ????????
/ Hyd pump overhaul??? #2
The first question is which pump? Mine has three:
1. Variable output drive pump with tram pedal control
2. Fixed output PTO pump with solenoid control
3. Fixed output Aux PTO pump that controls the lift, tilt, steering and Aux PTO functions
Overhauling 2 or 3 should be relatively straightforward and inexpensive. Overhauling #1 is much more complicated and expensive due to having a charge pump, swash plates, etc. Terry quoted me around $900 to rebuilt mine at Tazewell a few years back.
/ Hyd pump overhaul??? #3
What symptoms are you finding that drives the rebuild of the pumps?
2022 EZ-GO ELITE...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
2006 MINI Cooper Convertible Coupe (A61574)
2006 MINI Cooper...
1996 INTERNATIONAL 4800 SPREADER TRUCK (A63291)
1996 INTERNATIONAL...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
