Pressure relief valve to ease quick couplings
   / Pressure relief valve to ease quick couplings #22
I have mentioned this many times before. You only need one QD fitting. a short hose, and a plug in the end of the hose.
When you remove the attachment from the PT, plug the adapter in to the matching QD. This will let any fluid that may expanded, seep into the adapter hose. This may cause only a few psi of air in the adapter. If the hot attachment ever cools down, it will suck in a little air. No biggie.
Could also use a needle valve on a tee before the QD to release pressure.
:thumbsup: Anybody listening?
... larry
   / Pressure relief valve to ease quick couplings #23
Larry,
I agree JJ's idea is great. Only concern would be if you have multiple implements at different locations or worse yet multiple operators that go care about your equipment or the next guy. Then the possibility of using "connect under pressure" QD's would make more sense.
Roy
... larry
My apologies to JJ, I somehow missed that simple solution when reading various forum threads. It would work great for the homeowner (where only 1-3 people use the machinery), provided that the adapter can indeed be connected with little force, to relieve the pressure. (I like this idea more than a 'pressure relief screw fitting'.)
I.e. my wife could use this home-made adapter that is kept on the tractor, relieve the pressure in the implement and/or tractor, and then make the QD connection between tractor and implement.
Heck, I would even ask Power-Trac to make me one and throw it in when taking delivery of a new machine...
Thanks for the feedback,
   / Pressure relief valve to ease quick couplings #25
Well here's one less thing to worry about: sitting in the sun won't increase the pressure in your hydraulic system. Unlike gases, fluids don't expand or contract with temperature.
Oh, boy, do you need to go back to class. Everything expands and contracts with changes in temperature...liquids, solids and gasses. Why do bridges have expansion joints? Why does concrete crack? Why do ice cube trays overflow?
You're confusing expansion and contraction with compression. Gasses can be compressed. Liquids cannot. That's what makes a hydraulic cylinder work differently from an air compressor.
   / Pressure relief valve to ease quick couplings #26
Liquids can be compressed.
   / Pressure relief valve to ease quick couplings #27
Liquids and solids can be compressed, but the pressure needed to affect a significant change is enormous. This is a quick quote from a wiki page:
The effect of pressure and temperature on the densities of liquids and solids is small. The compressibility for a typical liquid or solid is 10−6 bar−1 (1 bar=0.1 MPa) and a typical thermal expansivity is 10−5 K−1. This roughly translates into needing around ten thousand times atmospheric pressure to reduce the volume of a substance by one percent. (Although the pressures needed may be around a thousand times smaller for sandy soil and some clays.)
   / Pressure relief valve to ease quick couplings #28
PT,
for this to work you have to connect the length of hose when there is no pressure on the system. I.e. when you are removing an implement. If you don't the pressure will build do to heat and you will not be able to connect the hose the same as it won't connect to your tractor.
Does this make sense?
Roy
   / Pressure relief valve to ease quick couplings #29
I believe we discussed this much earlier in the thread. ;)
PT,
Roy
Ah, yes, thanks Roy! One 'dongle' per implement then, and perhaps an additional one on/for the tractor.
Cheers,
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A59231)
2009 Skeeter SL190...
2022 CATERPILLAR 299D3 XE SKID STEER (A60429)
2022 CATERPILLAR...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
