Pressure relief valve to ease quick couplings
   / Pressure relief valve to ease quick couplings #11
In reference to fluid expansion.
An excerpt from one of Brendan Casey articles:
The cylinders were extended to the internal stop and pressurized to 250 bar. The ball valve was closed and the rod-end port connection was removed. As the hydraulic oil and cylinder body started cooling down, pressure decreased slowly to zero, although no leaking could be detected at the rod-end port.
I explained to the engineers on site that the cause of their 'apparent' problem was the heating and subsequent cooling of the oil being supplied to the hydraulic cylinders during testing.
But they still didn't believe me and remained of the view that the problem was a result of leaking seals.
So to prove the point, I got a hot-air gun - normally used for packaging wrap and started to gently heat the hydraulic cylinder. As I expected, cylinder pressure started to increase.
Heat with a hot air gun, good technique. I have done that with erratic electronic components to isolated the component.
   / Pressure relief valve to ease quick couplings #12
   / Pressure relief valve to ease quick couplings #13
If hooking under pressure is a constant problem you buy QD's that connect under pressure. Depending on the size up to around 10,000 PSI. I won't lie and say they are inexpensive, but they are still available.
Roy
   / Pressure relief valve to ease quick couplings #14
The world of digital thermometers is sapping knowledge from our yungins :(
Ken
   / Pressure relief valve to ease quick couplings #15
Roy
Roy,
I haven't found to many QD's that will connect under full operating pressure. Some say up to 500 psi. Even the flat faced QD's.
   / Pressure relief valve to ease quick couplings #16
Roy,
JJ,
Here are two versions I found info on.
Snap tite version
The sun and the heat it generates is a source of life and energy for our planet. It's also the source of many headaches for the hydraulic engineer, one of them being thermal expansion.
While construction and utility equipment manufacturers experience the brunt of the sun's effects, manufacturers of skid-steer loaders may have the toughest challenge of all. Often, thermal expansion creates pressures of over 2000 psi, preventing standard quick connect couplings from connecting as designed. Compounding this issue was the decision made long ago to "key" the proper hose connections by using both a coupler and nipple on both the loader and attachment.
Herein lies the problem, to easily connect an attachment containing trapped pressure due to thermal expansion, both the nipple (male half) and the coupler (female half) would be required to connect while under pressure. Presently, users must remove or otherwise manipulate the coupling's valve to relieve the pressure, defeating the purpose of using a quick disconnect in the first place. Why should the user be forced to manually relieve the pressure and possibly damage the coupling, or endanger the environment with the subsequent spillage?
As if these demands weren't tough enough, the industry also mandated that they design a coupling that meets ISO-16028, an international specification for interchangeable, push-to-connect, dry break couplings.
Patented Design
Using the latest 3-D modeling software, Snap-tite's engineers designed and patented the Series CP74 coupling. While being able to connect to any manufacturers' ISO-16028 compatible design, either the nipple or coupler will connect to static pressures of up to 3625 psi.
The CP74 solution saves time, prevents damage and protects the environment while maintaining the interchangeable criterion of ISO-16028.
S70 Complete Coupler
SafeWay痴 S70 Series offers unique internal valving, combined with SafeWay痴 two-way sleeve feature, allowing one-hand connection under full system pressure. The body (coupling) half can be mated to either a ball valve or poppet valve ISO male tip (nipple). The S70 Series is used primarily with agricultural equipment. It is original equipment on full size tractors and front-end loaders. Use when connection and disconnection under pressure, without the use of tools, is desirable.
I suspect Parker/Pioneer & Eaton/Aeroquip also have models similar to these.
NOTE: I do not remember who makes or made the 10,000 PSI version but from memory I believe they where special for jack service.
Roy
   / Pressure relief valve to ease quick couplings #17
I found this on DHH web site.
Connect Under Pressure Couplers
ISO 16028
These no-drip, skid-steer couplers connect by hand under pressure without releasing any fluid into the environment. Available in 1/2" male and 1/2" female, these couplers are fully compatible with our standard ISO 16028 couplers.
Applications: Mobile equipment and attachment tools where exposure to the sun or temperature change causes pressure to develop due to thermal expansion or trapped fluid. Any application where static pressure can get locked into the system.
* Male coupler will connect under residual pressure up to 3571 psi.
* Female coupler will connect under residual pressure up to 1595 psi.
* Mating coupler must be without residual pressure.
* Steel construction with anti-corrosive plating
It seems kind of hard to find a definitive answer on things like connect under pressure.
   / Pressure relief valve to ease quick couplings #18
Amen on that JJ,
different companies have different specs "connect Under Pressure"
I think Parker and possibly others have a model with a lever like a ball valve on the QD to aide in connecting under pressure.
From memory I think some models of IH tractors had this feature also. possibly the "86" series like 1486???
Roy
   / Pressure relief valve to ease quick couplings #19
Are you sure about that? Then, why do we check the level of the oil when the engine is cold?
Also can you explain why a hyd attachment with QD's , will be hard to connect. but when the fluid is released, it connected OK.
I think we check the engine oil when it is cold so we don't burn our hands on the dipstick! :laughing:
Also, it gives the oil time to drain back down to the crank case. ;)
I agree that something happens to the oil and it almost has to be expansion, when you leave an implement in the sun. Oil does expand and contract. However, it is not very much. But the pressures are tremendous in a closed vessel.
   / Pressure relief valve to ease quick couplings #20
I used to do that, too, and also use chiller spray to cool components. However, today's electronics are becoming less and less able to troubleshoot on a component level. We have become board swappers. :(
Teak Wood Dining Table (A59231)
Teak Wood Dining...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2019 GALYEAN...
