(FOPS)FALLING OBJECT PROTECTIVE STRUCTURES
/ (FOPS)FALLING OBJECT PROTECTIVE STRUCTURES #21
Hmmm, Rick aka Mr. TiltMeter, mentioned FOPS as a opposed to ROPS, to provide protection in the woods and when using an FEL.
What do these things look like?
Are they four posts?
How do they attach to the tractor?
How much do they cost?
Thanks,
DanWhoIsWorkingInTheWoodsWithAnFEL
I sell FOPS certified steel canopies that attach to two-post ROPS structures. They are comparable in price to OEM fiberglass canopies.
/ (FOPS)FALLING OBJECT PROTECTIVE STRUCTURES #22
If you own a Deere call/google GR Manufacturing in Northern Alabama, they sell certified FOPS/ screens. They are not cheap but neither is ED visit/ your life.
I use one on my 4720 and it has saved me many times.
/ (FOPS)FALLING OBJECT PROTECTIVE STRUCTURES #23
Why should the pallet forks not be used with round bales if mfg. directions are followed - that is, the load is fixed in some way to the forks. Manufacturers have an obligation to provide FOPS when loaders are installed (unless an adequate cab is present) to prevent incidents as I had. Automatic load levelers would also reduce the risk of falling objects from pallet forks and should be required of all loaders with forks. If you think not, why not? FOPS and self levelers are not expensive and certainly worth it if I can reduce the risk or prevent the roll off type of injury I sustained. Many mfg.s (including Massey) don't even offer retro install kits for either self leveling or FOPS. Amazing that a Massey dealer would say that forks cannot be used for round bales when it no doubt supplies them for their loaders. If the load is fixed to the forks, why should forks not be used for round bales? If it can't be used safely with loads kept from shifting (round bales with a binder), then it can't be used to handle loads of any type.
/ (FOPS)FALLING OBJECT PROTECTIVE STRUCTURES #24
Thanks,
I have a Perry canopy on my Ford 4610 and it is FOPS certified. It's aluminum with noise supprssing material on the underside and the structure to attach it to the factory ROPS on my tractor.
All that FOPS certification means is that if a 50 pound object is dropped from X feet above the canopy it will not hurt the operator. It won't help you with falling trees or large round bales. Google Perry Canopy for more info.
/ (FOPS)FALLING OBJECT PROTECTIVE STRUCTURES #25
If the round bale is fixed to the forks why would you need a FOPS?
How is the manufacturer "obligated"? Some of us don't want or need self leveling and fops (or Rops).
Not expensive? Bales spears are inexpensive.
Where does this Massey dealer say this? Just because and implement or attachment is sold for a tractor or loader doesn't mean that it should be used for anything and everything and expected to be safe.
Again, if the round bale is fixed to the forks why would you need a FOPS?
:D:D:D
I started this thread 10 years ago.
And it has been brought back to life. :laughing::laughing::laughing::laughing:
I talked to my JD dealer 10 years ago and the did not have an FOPS for my tractor at that time. Guess I should ask him again. In the 10 years I have only had one near miss in the woods. And a FOPS would not have helped.
:eek:
I do not have to work so much in the woods at this point but a true four post FOPS would be nice.
Later,
Dan
/ (FOPS)FALLING OBJECT PROTECTIVE STRUCTURES #27
Because equipment, accessories and recommended usage methods fail. In my case, the bale was fixed to the forks with a heavy duty ratchet strap and when the lift arms unexpectedly and uncontrolably went up rather than leveling the forks the bale was virtually launched out of the restraint.
Some people remove ROPS and PTO shaft guards and some people won't wear seat belts. Manufacturers are "obligated" where possible and reasonable to protect and warn about obvious risks. That is why there are warning bells with seatbelts and why it is against the law to drive without using them. That is why manufactorers must install shields and ROPS and why dealers must replace or repair shields or ROPS if not in safe condition.
An after market hydraulic self leveling device costs less than a spear and spears that are recommended as OEM equipment for quick detach loaders are in fact very expensive. Also, in my incident, the bale would have likely come off the spear and land in the same place causing the same injury.
Loaders and their attachments are made as multi purpose or multi use equipment. The manufacturer, or dealer for that matter, should present its equipment safe for common usage and safe even for unanticipated uses. After all, the manufacturer cannot anticipate every possible use. A FOPS would prevent injury both from common and unanticipated usage. Bale handling in fact is a common usage. What else is a fork lift intended for except materials handling and if measures are taken that are consistent with manufacturer's recommendations for use, then why not move round bales with forks. Are you saying that there something inherently dangerous with forks when used in an acceptable and safe manner?
Again, recommendations for use by manufacturers can fail and manufacturers cannot possibly address every alternative safe use in terms of published safety recommendations. Generally it is safest to look to the end result or final common pathway in preventing injuries. In the case of PTO shafts it is PTO shields. In the case ROPS it is roll-overs which can occur under innumerable circumstances. In the case of FOPS it is roll-off or fall-off from loaders and their attachments. The bottom line is that FOPS will protect against nearly all of them and no more costly than ROPS which are now standard with tractors without cabs. FOPS should be standard with loaders. How can you argue against that?
/ (FOPS)FALLING OBJECT PROTECTIVE STRUCTURES #28
Isn't incredible that with all the accidents that occur with FELs that the manufacturers do not provide them standard with loaders or as after sale installations? FEL roll off accidnts are much more common than roll-over accidents, especially now that ROPS are standard.
I have checked multiple dealers and after market companies and have not found FOPS to be available. The only way to retro install one is to have one designed and manufactured for your tractor model.
/ (FOPS)FALLING OBJECT PROTECTIVE STRUCTURES #30
What you said is so obvious - the FEL related accidents without FOPS are actually common which stands to reason because in general with the tractors today (and with
RopS) it is pretty difficult to roll over.
What I can't believe is that manufacturers don't even supply after-sale or retrofit FOPS for tractors with loaders - not even an option. Perhaps this negligent attitude is best exemplified by Duffster who is our Massey Ferguson contributor who at best is complaincent and worse, seems to be arguing against simple ways to reduce very serious injury and death.
/ (FOPS)FALLING OBJECT PROTECTIVE STRUCTURES #31
I have no affiliation with MF.
You obviously got hurt by your poor decisions/actions and now want someone else to take responsibility.
/ (FOPS)FALLING OBJECT PROTECTIVE STRUCTURES #32
So, did the strap fail? If so, which direction was it wrapped around the bale in? Any pictures?
A properly sized and tensioned strap going around a pair of non-flip up forks (forks like this or this, not this) should not come off no matter what your loader does.
Last I checked, dealers they are not required to repair shields or ROPS that are broken or missing when they get a tractor in to repair it. Sell it perhaps, but not when they just work on it.
Also, there are stickers warning about things coming back over the top of the bucket on most (all?) modern loaders (most of them even show a round bale coming back).
Can you show some examples of prices of aftermarket self leveling devices?
Really? How far up will your loader roll back the bucket when all of the way up? There is a difference between a bale rolling backwards off of a set of forks and one coming off of a bale spear like this: New Quick Attach Hay Spear / Bale Fork - eBay (item 230565259271 end time Feb-17-11 12:51:59 PST). The first is possible, the second not so much.
Take a look at this B7500 and tell me how you would put a FOPS on it that would do the following:
1. Not be in the way of mounting and removing the loader
2. Be able to drop down for areas where there is low clearance (like the ROPS is in the pictures)
3. Not impede the operator from getting on and off the tractor
Aaron Z
/ (FOPS)FALLING OBJECT PROTECTIVE STRUCTURES #33
Every tractor with a loader has a FOPS, it's located just above the operators shoulders. Generally referred to as a brain. If used, it will prevent 99% of problems from objects falling out of the loader onto the operator.
/ (FOPS)FALLING OBJECT PROTECTIVE STRUCTURES #34
No, I want common sense protections supplied or at least available at the consumer level to prevent accidents. Where do you stand on product safety Duffster? So far you seem to be disinterested in safety and without a logical rebuttal to my points -
/ (FOPS)FALLING OBJECT PROTECTIVE STRUCTURES #35
Having been a tractor and implement dealer with a repair shop in the 1980s, I know that we would never let a piece of equipment out of the shop with unsafe guards or disabled shields without a release.
The strap was secured over the top of the bale and around the forks, side to side and did not fail. When the forks/lift arms reached the top of their range the bale strap was nearly horizontal to its starting vertical position and was catapulted out of the restraint. They were not flip up forks
I recently found a hydraulic control valve that can be inserted into the existing lines and will automatically adjust the bucket level. I don't have the webaddress at hand but will get it or you can google it like I did.
The lift arms are almost vertical when fully raised and after market bale spears that attach to the bucket or OEM quick detach spears in this case would be nearly vertical at full lift. With the weight of the bale the bale could easily come off, bend the spear or pull an attachment right off the bucket.
the Kubota you show has an approximate 1" pipe on the top of the loader verticals. this could be increased in size vertically almost in the same shape and then with a bar extending back on centerline to clamp to the ROPS with or without canopy. That is an approximation to what I have begun to have built and retrofit on my tractor which is a early 2000s major mfg. No OEM or aftermarket FOPS could be found. It would obviously stay with the loader verticals when removeing the FEL and could be unbolted from the ROPS and verticals if necessary. If top clearance is an issue then a cab wouldn't work either. I don't know, but I doubt ROPS on most tractors are ever lowered and I doubt there would be a need to remove the FOPS for the same reason.
I would be glad for the inconvenience of rarely removing the FOPS if it would save from possible paraplegia or death which is the most common result in roll offs.
/ (FOPS)FALLING OBJECT PROTECTIVE STRUCTURES #36
Clever and true - brain = FOPS, but what about that 1%. What about the innumerable distractions, momentary inattention, forgetfulness. Accidents do happen to the most careful, attentive and intelligent people. For the cost of a steel FOPS I would cover the 1% - its a lot less expensive than a new brain FOPS.
/ (FOPS)FALLING OBJECT PROTECTIVE STRUCTURES #37
This is a slippery slope. How far do we go to protect that 1%? Once we mitigate that risk, there will be a new 1%. I would compare this to the anecdote about the Boiling frog. We can't keep building things to protect everyone from everything that could happen. #1- It forces things on people that don't want/need them. #2- It continually raises the cost with minimal benefit. #3- It gives people a false sense of security. Over time, each one doesn't sound like anything all that significant, but over time you take a step back and realize that you turned the tractor into something completely different by making it "safer".
Some things in life are inherently dangerous. People doing these things have to accept that when doing these things. If you are going to operate a tractor, YOU are obligated to understand the risks. From rollovers to items falling out of the FEL onto you or someone else.
I am just not a fan of bubble wrapping everything. I take risks when I operate my tractor or my ATV. That is just a side effect of doing these things.
/ (FOPS)FALLING OBJECT PROTECTIVE STRUCTURES #38
I guess I could accept the logic of wvpolekat if the accidents we are discussing weren't so frequent and so devastating and also so preventable. Round bales became prevalent around 1970s and were primarily handled by FELS. the incidence of falling object injuries did not increase at a slow boil, but precipitously and they have increased with the increased use of FELs and round bales. I'm very familiar with traumatic accidents of all types and most of them are known, anticipated and accepted risks of using various forms of equipment. What should be proactively protected against are the unanticipated risks that can be prevented with relatively inexpensive measures. We see them with every type of equipment from cars to ATVs. People, of course, can make a choice if the safety measures are not mandated (safety belts, helmets, etc.) but ultimately everyone pays for trauma in one way or another through insurance premiums, product liability claims or injury. If you can fix it, why not? The risk-cost/benefit (accident avoidance) test is overwhelmingly in favor of doing so. The risk-cost/benefit of ROPS is a perfect example. Would anyone decline the installation of one on their tractor at a reasonable price? I think not. I believe in many states they are mandated so there is no choice.
/ (FOPS)FALLING OBJECT PROTECTIVE STRUCTURES #39
Have you found any instances of a round bale coming off of a bale spike (like the one I posted a link to earlier) and coming back onto the operator?
The main spike on those is generally around 3 feet long and does not come out easily when it is in the middle of a bale.
Talk about cheap insurance.
You could even make a mount to put a spike on your existing fork frame... Then the bale could not come off unless you wanted it to.
Aaron Z
/ (FOPS)FALLING OBJECT PROTECTIVE STRUCTURES #40
Mr. Pauchik I live near a major city with a great deal of crime. Shootings are a problem. The car manufactures are aware that a small percentage of customers will be shot at while using their product. Based on your logic we should require all cars to be armored.
I also have to ask, it sounds like you were injured when lifting a round bale of hay, I am sorry. What I don't understand is how did you lift a round bale to the full lift height of the loader fast enough to "catapult" it out of a restraining strap. That sounds like a rather violent way to operate the loader. Or were you operating defective equipment at the time?
MarkV
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
2026 Kearney 96"x 24' Gooseneck Trailer (A64119)
2026 Kearney 96"x...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2011 Dodge Ram 1500 Crew Cab Pickup Truck (A61573)
2011 Dodge Ram...
2013 Ford F-350 XL (A64119)
2013 Ford F-350 XL...
2017 Peterbilt 320 T/A Heil 28Yd Front Loader Garbage Truck (A61573)
2017 Peterbilt 320...
