Do TLBs make "bad" tractors?
/ Do TLBs make "bad" tractors? #21
Here is the list:
Snow moving. Have a plow to clear the driveway, but need an FEL to get the piles out of the way during winters like this or I lose access to my garages and my driveway becomes too narrow.
Tree/bush movement. Dig up larger bushes and relocate them. Dig out stumps from trees I cut for firewood.
Firewood operations. Move downed trees. Apply pressure to felling trees. Relocated pallets full of firewood from seasoning area to burning area. Tow around log splitter.
Flagstone patio. I need to build one.
Concrete patio: needs to go and something put in its place.
Pallet fork operations: load and unload ballast from plow truck. Firewood. Other general ops. This is where the loader specs of the TLBs shine to me.
Brush hog: I have about 4 acres to bush hog annually just to keep them from turning into woods.
Dirt work: maintain dirt bike/atv track.
Regrade a few areas around the driveway to aid in snow removal. I need to cut back some slopes to create room to push snow.
Fence: need to build a new fence around the pasture. Post hole digger rental.
Stuck vehicle: twice this winter I could have pulled my own truck/cars out of being stuck at my own house. Embarrassing, but truthful.
Trailer: relocate the trailer around the property more easily than the monster pickup.
Mowing: NO! Nothing will beat my 61" ZTR around my property.
This is pretty much how I wind up yearning after an L39. I keep looking at everything, and it seems best to just buy that. Buy it once and be happy. I have found a few nice used examples within driving distance with <500 hours for ~$25-28k. This is the same I would be spending on a 37hp L series in my area with T/L/B. The capabilities of the L35 just keep calling to me. I CAN move it around as I own a truck/trailer large enough already.
ac
The Kubota F models with a 72" front deck will eat it up in grass or in a parking lot. F models can do a few other tasks also but the ain't cheap.
/ Do TLBs make "bad" tractors? #22
All good points...
Bottom line is, you really need to know what you're going to do with the tractor, TLB or whatever.
Just reading the manufacturer's specs just doesn't cut it.
he nailed it! :thumbsup:
Neat. But I think I will stick with the ZTR and a tractor to handle the implements.
ac
/ Do TLBs make "bad" tractors? #24
I want to add one term to the discussion: Utility Tractor. As said before, a TLB is primarily designed to excavate with the BH, then load into a dump truck with the FEL. It does not lend itself easily to swapping implements, except for quickly changing BH bucket sizes and a roller/compactor for backfilling trenches. A Utility Tractor, on the other hand, is designed for versatility. It is a utilitarian machine, meaning it is designed to do many things fairly well, while not specializing in one or two things. Most of us have a UT, a CUT, or a SCUT. Utility tractors are not as heavy duty as TLBs, however, in their "utilitarian" design, it is far easier to change implements for the task at hand. A BX25 is not a true TLB; it comes with a BH, but it is in reality a SCUT. For totally specialized jobs, there are dedicated machines like ZTRs and tracked front excavators; these specialized machines are very non-utilitarian. A TLB is not a "bad" tractor; it is just not a utility tractor.
/ Do TLBs make "bad" tractors? #25
I have a Kubota L2950 with Woods 7'6" back hoe mounted on a sub frame w/fel I love it i dig couple of hunderd feet of ditches on my network of woods roads each year i have installed 20 or so culverts some for me some for others.I dug my foundation for our new home addition. and countless other things .In my situation life without a Back hoe would not be an option.If my rig burned to the ground today I woud buy brand new tomorrow and thats no joke. my Experience with track hoes get me a little over zellous wth my own rig but thats half the fun .Cound not live without one now ,no freakin way.
/ Do TLBs make "bad" tractors? #26
You had the wrong ones.
Not even. They are great machines, but they aren't multipurpose tractors. The OP needs to understand while looking at the weight capacities, etc., there are trade offs.
There's only one term I want to add to the discussion: Utility Tractor. As said before, a TLB is primarily designed to excavate with the BH, then load into a dump truck with the FEL. It does not lend itself easily to swapping implements, except for quickly changing BH bucket sizes and a roller/compactor for backfilling trenches. A Utility Tractor, on the other hand, is designed for versatility. It is a utilitarian machine, meaning it is designed to do many things fairly well, while not specializing in one or two things. Most of us have a UT, a CUT, or a SCUT. Utility tractors are not as heavy duty as TLBs, however, in their "utilitarian" design, it is far easier to change implements for the task at hand. A BX25 is not a true TLB; it comes with a BH, but it is in reality a SCUT. For totally specialized jobs, there are machines like front mowers and tracked front excavators; these specialized machines are very non-utilitarian.
I have dug through the manuals and procedures to pull the backhoes off a few tractors. From what I see, if you have a CUT w/ subframe backhoe, it is pretty much the same procedure as pulling the backhoe off an L series TLB.
Once the backhoe is off, there sits the 3pt hitch, same on both...right?
Yes the FEL is "stuck" on, but the bucket is quick release.
Am I really missing something with how the L series TLB is less "good" all-around? Or is it just that most can't justify/afford the extra cost and then they make up "reasons" the TLB series isn't as good as a utilitarian tractor?
ac
/ Do TLBs make "bad" tractors? #28
ac
I think that is pretty much going to depend on the user and use of the equipment. We have two hill farms and not being able to take the FEL off for use on our steep hillsides is unacceptable, so a TLB is simply out of the question for our use. There is daylight and dark difference between how our tractors handle with and without the FEL.
We have an older model Case backhoe we no longer use and when we need to dig something, we just go rent an excavator. I must admit I am tempted from time to time, to get a tractor with a backhoe, but it just doesn't make sense economically for us right now. I may at some time in the future and I will pick something which has the capability to remove the FEL to increase the utility of the machine.
/ Do TLBs make "bad" tractors? #29
ac
I think modern tractors have outgrown some of the older terminology. Some of the older really commercial rigs didn't have the BH that popped off quickly. Some of the newer tractors are quasi-hybrids between true TLBs and UTs. I would not consider any L a heavy duty commercial tractor; you surely don't see it digging up sewer and water mains down the center of six lane thoroughfares. Instead you see true TLBs that are yellow, built by Case and Deere (commercial Deeres are yellow, not green).
/ Do TLBs make "bad" tractors? #30
A regular ag tractor Kubota or otherwise is really not designed to move dirt day in and day out. A TLB is. This is because of the bigger GPM pumps, larger cylinders and mainly because of the heavy duty one piece no twist frame. It also depends on how often you really are going to use the tractor, a lot of guy put maybe 50-200 hours a year on their tractor...but if you are like me (1000 hours on L39 in 23 months and 500 hours on B26 in 12 months) then the heavy duty structure pays off. The TLBs do cost you quite a bit more up front but if you are really going to be running the tractor 6-8 hours a day, in my expirience the TLBs hold together well. Like I said before in this post I can go from digging a stump with the backhoe to pulling a box blade or shredding in about 15 minutes then I can go back to backhoe in about the same amount of time. I simply leave my backhoe off most of the time and leave the 3 point hitch connected with a quick hitch...so now it is like a regular tractor. I can switch from implement to implement in under 2 minutes...so I do not see the down side to this set up. Just my 2 cents.
Ryer
P.S. find the size tractor you think you will need...and buy the next size up or you will always wish you had :)
/ Do TLBs make "bad" tractors? #31
Seems there are individual ideas of what a TLB is. Internet search came up with stock exchange and computer designations so had to search for Kubota TLB. This is the results of what Kubota defines their TLB to be which I'm going to take as gospel since I have a Kubota BX25 (SubCompactUtilityTractor) or SCUT which Kubota lists as a TLB. The BX's are SCUT's or sub compact.....utility.....tractors and the BX25 is listed by Kubota as a SCUT TLB. It lists it's B's as CUT or Compact.....Utility.....Tractors and some B's are also TLB's according to Kubota or they sell them as CUT TLB's.
KUBOTA TLB
This is how I wound up on the L39. Thought a B26 would "work". Upsized a bit since it really doesn't cost much more in the used market.
I am hoping with good maintenance that it will do whatever I throw at it, and last a good long time.
ac
KUBOTA TLB
I basically was trying to discuss L39 vs L3700 or B26 vs B26xx. In other words, the machines listed under "Rural Lifestyle" vs those listed under "Construction".
ac
/ Do TLBs make "bad" tractors? #34
SCUT, CUT and utility tractors..... Multipurpose tractors. TLB's easy off FEL's and BH's and with PTO's and 3ph's. This being a Kubota owners forum then it seems to reason to me that the definition provided by the manufacturer Kubota would be the definition we use here and not what someone has decided they mean in their minds because that's what they've always called them. This is what Kubota defines their TLB's to be.
KUBOTA TLB
/ Do TLBs make "bad" tractors? #35
IMO....this thread has more in common with the two guys that (finally) pulled the swimming pool down with thier "SCUT TBL"...than answering the OP's main question...
/ Do TLBs make "bad" tractors? #36
avc8130
New Member
I am continuing my research and searching for a tractor to buy come spring. I have poured over specs and reviews. I have read many times that the TLB series make great...TLBs! I know their hydraulics are much more capable. Their backhoes are much stronger. Their FELs are not quick release.
The thing I can't figure out, is "do they make BAD tractors"?
Is the TLB series less capable with 3-point attachments? Is it the price premium that keeps them on commercial sites and out of homeowners sheds?
The extra lifting capacity (almost double for any given hp class) looks very useful. The extra backhoe strength and capability certainly couldn't hurt when the digging gets tough.
So what's the deal? Why doesn't anyone buy these residential?
ac
Seems as though some terms are having to be defined in order to help answer the original question. Seems you've been a big help.
/ Do TLBs make "bad" tractors? #37
sorry for the trolling observation....It was not meant to disparage the quality of the replies...
/ Do TLBs make "bad" tractors? #38
:D You are so much fun to debate. I love ya, but gotta play oppositional advocate here. These terms had a meaning before Kubota ever made or sold tractors. So on whose authority does Kubota get to change the meaning? I'm going to draw an analogy to cars.
Back in the old days, it was pretty easy to distinguish between a sedan and a pickup truck. Then along came panel vans, jeeps, full sized vans, and station wagons. Now pickups had separate cabs and beds, until Ford decided the '61-'63 F100 should have a unibody design. Then someone decided that pickups could be built on car frames and we got the Chevy El Camino, Ford Ranchero, Cadillac Mirage, and the VW Rabbit PU, all unibody designs. Were those things cars or trucks? Does a car make a bad truck; does a truck make a bad car? What if you're talking about one of those four vehicles? Now along come the minivan and SUV. What's a minivan; is it a little van or a big station wagon? What is an SUV: a car, a truck, a station wagon? Well, it's built on a truck frame, so for EPA mileage, it qualifies as a truck. Uh, oh, now we get the crossover, a SUV built on a car frame, so what is that? Oops, that's not enough, now we need to cross the SUV with a pickup, so we get the unibody Sport Utility Pickup in the form of the Honda Ridgeline, Cadillac Escalade, and Chevy Avalanche. Oh, we can't let the crossover be outdone by the SUP, so we need a crossover Sport Utility Pickup: the Subaru Baja. What is this thing in the pic below, what are the right terms? Is it a car, pickup, SUV, crossover, SUP, crossover SUP, all of the above, none of the above, or what?
I think there was a time when the terms TLB and Utility Tractor had distinctly different meanings, just like you could tell a sedan from a pickup and there wasn't a lot of in between stuff to muddy the water. The meanings of words change. Middle English is hard enough to understand, and Old English is unreadable to everyone except linguists who specialize in it. Heck, when I was a kid, the word gay just meant somebody was happy, and to say that someone or something "sucked" was an incredibly vile slur. My father would have slapped my teeth out of my head if he had ever heard me say that someone sucked. Before WWII, the word plastic was an adjective, a synonym for flexible; now it is a noun for a synthetic material.
I think that in the realm of big agribusiness and large scale commercial construction, TLB and Utility Tractor probably mean pretty much what they did in the post WWII years; in those days, family farmers used a utility tractor, never a TLB. In the realm of those of us who need Estate Tractors so we can pretend we are Mr. Douglas on Green Acres (tee, hee, hee), the waters have become muddied. I would agree with you though in this, makers of these smaller tractors have mixed and matched so many features on these little things that they almost have to apply terminology in a broader sense. You say you once taught at the college level. I would assume therefore that you have some knowledge of the field of etymology, the study of the origin of words and the evolution of their meaning over time. The meanings of words change. The place I am going to disagree with you is in who gets to decide what words mean (other than Bill Clinton). It seems that you imply that individuals do not get to decide what words mean, while Kubota does. I would posit that Kubota has never built a single piece of truly big commercial Ag or construction equipment, not the kind of stuff Caterpillar builds. I do not think it is inappropriate for Kubota to borrow the term TLB to describe a BX25, however I think my statement that a BX25 is not a true TLB is closer to being correct in the original context of the term.
So where does that leave us? I think we need to ask the OP to be more specific about his original question (which he has now done). Is he talking about a big Case TLB used to lay water mains in paved roads? If so, I would reply that this tractor is not a good choice to use as a utility tractor due to the time it takes to change implements (as well as the mass and size). On the other hand, if he is asking whether a BX25 is more difficult than a BX2360 when it comes to changing implements, the answer is that there is no difference. So, with all the kazillion options and sizes in today's market, rather than the original question, "Do TLBs make bad (utility) tractors," it is better to ask what most people here ask when they say, "Here are the specific tasks I need to do, on this much property, in this amount of time. What tractors come the closest to meeting my needs?"
/ Do TLBs make "bad" tractors? #39
truer words has never spoken then you tom_H. kudos for the :thumbsup:post.
/ Do TLBs make "bad" tractors? #40
I have a B21. It has a frame mounted backhoe unit that is easy to remove and put on after you've done it a few times.
When the backhoe is off, it's a great little tractor. Now the B21 has low PTO HP, so if you're doing much with the 3 PT stuff I'd look at a B26 or maybee bigger (L39?). I've run a small tiller and landscape rake with my B21. When I use the landscape rake to pull out the rocks in an area I've just tilled, it's great to have the loader on there to pick up the rocks.
The only downside is you always leave the loader on. I've never taken mine off, the "guess" is that removing it is a 3 hour process.
Due to the low horse power on the B21, I got a JD 4520 (50 HP on the PTO) so I could run a 6 foot rotary cutter. If I had a B26 I might have got a 4 foot cutter. With a L39 I could run a 5 or 6 foot cutter.
I dd not get the loader for the JD 4520 since I had the loader on the B21 TLB. Agree with other poster that having a backhoe is costly but very useful. the cost of the backhoe on the B21 is about the same as the loader on the 4520. I've also used a L39. I actually prefer the small size of the B21 for most of the utility and maintenance stuff I do. The small size is great for me. Again, the hardest part about selecting any tractor is knowing what you want to do. No piece of equipment is a jack of all trades, you need to intelligently manage the trade offs when you decide what to get.
So, to answer the OP, a TLB does not make a bad tractor. Asses your needs just like you would any other tractor (PTO HP, weight, width) and then realize you'll always have that loader sticking out in front. Also realize you'll only have rear PTO attachments. If all that is not a problem for your property and work areas, well, you're good to go and a TLB makes a pretty good tractor too.
Pete
Firestone Bolt On Duals 14.8-38 (A65640)
Firestone Bolt On...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
New/Unused CFG Industrial H12R Mini Excavator (A65583)
New/Unused CFG...
2018 Case 580N EP 4x4 Loader Backhoe (A64553)
2018 Case 580N EP...
SHOP BUILT TRI-AXLE LOWBOY TRAILER (A63291)
SHOP BUILT...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
