ford 4500 remote
/ ford 4500 remote #1
chuck172
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
can anyone help me figure out how to add a remote hydraulic line to my 1971 ford 4500 diesel TLB.
I'd like to install a hydraulic winch to the front.
/ ford 4500 remote #2
Check to see if you have the same 4 bolt rectangular hydraulic cover plate under your seat slightly to the front/right, as the Ford 3000 and 4000? If you do, you should be able to use our 2 line after market kit for $379 + shipping. Ken Sweet
/ ford 4500 remote
No plate, I just checked.
/ ford 4500 remote #5
4500TLB may not have a rear axle mounted hyd pump. You may have to install a diverter valve in the hydraulic supply line feeding the loader or backhoe valve.
/ ford 4500 remote
How bout if I just tapped into the backhoe's power steering pump lines for the mile marker winch. I'm not sure but I think the pump puts out 1250psi. I don't know if that's sufficient for their winches though.
/ ford 4500 remote #7
I've always thought that pimping oil from a steering circuit for any added function was a bad idea; a potential safety risk. But it's your tractor & your butt (hopefully).
/ ford 4500 remote
According to mile marker winches, taping into the power steering circuit is a great place to get winch hydraulics. In my case it may be the easiest.
/ ford 4500 remote #9
The P/S system is the only hydraulics available on the majority of vehicles that MM winches are installed on, therefore MM says it is a great place to tap into.
If your mind is made up, nothing else matters. Compare the pressure and flow demands of the MM winch to the steering and main hydraulic system specs of the 4500. Tap the system that meets the demands.
2024 HITACHI ZW95-6C WHEEL LOADER (A65053)
2024 HITACHI...
UM AWS-36 HEADER CART (A64278)
UM AWS-36 HEADER...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
2013 Caterpillar Warren Power Systems WCW84MH 8KW Portable Light Tower (A64194)
2013 Caterpillar...
(7) DONALDSON P600676 AIR FILTERS (A64276)
(7) DONALDSON...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2017 Ford F-150...
