Looking for tractor to purchase
/ Looking for tractor to purchase #1
schoolsout
Awendaw, SC
Massey Ferguson 1533
Hey, y'all....
We've got about 100 acres of mostly pines (planted for most part) and wanting to clear some land to make way for orchard and other trees as well as do some food plots. Have some high ground and also some low ground that stay wet when we get some rain.
I would like a front-end loader to help with miscellaneous stuff we will do. Filling in areas with topsoil and whatnot...
Budget is about $10k, but is flexible (to an extent)
Currently, a farmer buddy keeps some of the roads disced/cut, but so far, we only have access to about 15 acres or so. In process of getting some other access roads cut around perimeter and also some going through property to open up our possibilities.
I'd like 4wd and diesel, preferably.
I've had my eye on a Yanmar 3110 such as this one, but I really don't know much about tractors. I know my way around larger diesels (boats) and also own a diesel car so I feel fairly comfortable with minor stuff on engine. Also work for commercial truck dealer and our shop knows its way around hydraulics and engines...
Tractor Yanmar 3110D with Loader
also, what is "ROPS?" and any other suggestions on where to look? Good people to deal with? I'm in Charleston, SC
Thanks!
/ Looking for tractor to purchase #2
ROPS are roll over protection.personally for what your wanting todo you need a 50hp tractor.
I should clarify that we won't be trying to clear any land with this tractor.
Why do you think we need 50+ hp?
/ Looking for tractor to purchase #4
because you said you wanted to build roads through your place.but a 40hp would prolly do what your wanting.
yea, not going to build roads with this. There is a fellow down the road that will do some work for about $50/hour with his track hoe.
Sorry for the lack of clarification.
/ Looking for tractor to purchase #6
Then we're just guessing. Most major brands are great and you'll have few troubles. Like anything else, maintenance is good.
Mike
/ Looking for tractor to purchase #7
I think with your budget it will be hard but who knows.... CL is your best friend. Good luck on your purchase.
/ Looking for tractor to purchase #8
Hi
I`m here in Chas also, and on the south side...I deal with Stein out on 17 south....I would really check out the dealer , and then get that type of equipment....Stein handles Kubota...I use to use Deere, but the nearest dealer is in Walterboro....Tony
Hi
Our property is actually in Walterboro. I live in Awendaw, so I imagine we are both in God's country...you're just in God's Country South ;)
I am familiar with Steen and like Kubota products. I may ride down there on the next trip to our property.
/ Looking for tractor to purchase #10
what are your pine row spacings.. this will make a difference with what machine you buy.
for general maintenance, a 4wd in the 30ish hp range is a good smaller maneuverable tractor. if you want to pull any heavy implements, etc.. zi'd nudge up.. but you can alwaus get a good loader tractor in the 30hp range.. than later adda a big older 2wd 50-70hp brute to do real (large) work.. etc.
soundguy
/ Looking for tractor to purchase #11
Hey, y'all....
Thanks!
That Yanmar is a grey market tractor--parts availability can be a problem with these tractors, buy you can find Yanmar parts on the Web pretty easily. Yanmar diesel engines have a good reputation and you're fortunate to have access to shop facilities where you work if you need to tear into the engine/tranny/hydraulics.
Check out that 3110D--look for funny smoke (blue smoke could be valves/ring problem, white may be a coolant leak into the cylinders, black generally means problems with injector pump/injectors), oil/hydraulic leaks, works OK in all gears, pto works OK, 3pt hitch works OK. Get some seat time with the tractor to be sure you're comfortable with the ride and with the controls. I wouldn't worry too much about the hours on the engine. Tractor diesels are good for 5-10 thousand hours if the maintenance is done properly.
You'll be hard pressed to find decent used 30-40hp tractors with an FEL for $10K or less. So if this tractor passes your checklist, I'd jump on it.
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
Kubota L3901HST
Kubota L3901HST
PORTER CABLE AIR COMPRESSOR (A63569)
PORTER CABLE AIR...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
207277 (A52708)
207277 (A52708)
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
