Buck neg. battery terminal question
   / Buck neg. battery terminal question #1
CrashandBurn
Member
USA
2010 TYM 233
Would a Buck owner please look at their tractor and tell me where the neg. battery terminal is connected to the chassic.
I split my tractor and it is all back together but I'm not sure where the cable was connected.....it's not real long, so there's not too many choices...thanks
   / Buck neg. battery terminal question #2
I do not own that model but the entire engine and frame are the negative on almost every tractor. I would suggest the engine block because the engine is connected to the rest of the machine.
Craig Clayton
Craig Clayton
Thanks.... I fully understand that but the cable isn't long enough, I just want to be sure I put it back in the original location, where it worked for 31 years.
   / Buck neg. battery terminal question #4
Shucks any frame bolt that is within reach of the ground cable.
Sand the surface clean first to assure a good contact.
Again thanks, but there's NO frame....
   / Buck neg. battery terminal question #6
Here is a thought, did you by chance install the battery the other way around. The POS being longer would reach but the NEG being shorter might not reach the MYSTERIOUS spot.
Craig Clayton
   / Buck neg. battery terminal question #7
At the bottom of the instrument panel just left of the steering column. Put the ground cable on the battery first and point it towards the back of the tractor before you squeeze the battery in.
Thank you.......that's where I put it (about the ONLY place) I just wanted to be sure. I took several digtal pictures before I split it, but missed up under there.
C13 MOTOR (A50854)
C13 MOTOR (A50854)
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A49461)
2019 Fontaine...
1994 LUFKIN (A50854)
71056 (A49346)
71056 (A49346)
Brown BDH-750 Disc Harrow (A50490)
Brown BDH-750 Disc...
2023 FG INDUSTRY STE 35SR MINI EXCAVATOR (A51222)
2023 FG INDUSTRY...
