Need some FEL info please
/ Need some FEL info please #1
sacsr
Kinston, NC
Yanmar 187D Terramite T5C Bush Hog D4-10
Hey guys, I bought a fel this weekend and now trying to put together all the info I can on it. Looking at a picture this morning, I now believe they were put on a 180D (and sure others)....I am looking for model number, manufacturer, specs (length of some parts- the front part of the frame has been cut/changed and want to know what it was orginally), etc...
From all I can gather....we thought this was for a 25-30 hp tractor...but after seeing it on the 180D this morning....I am thinking it could have been on a smaller tractor.......
I have posted pics...I thought the bucket (measures 53 inches) was put on later ...but the picture I saw this morning looked to have the same bucket ....anybody that has the set up and is willing to send pics and measure a few things for me would be appreciated.
Thanks!
Scott
/ Need some FEL info please #2
With the exception of the upper crossmember that has the two steel plates welded below it (2nd picture), it looks just like the Yanmar YFL 800 on my 226d. Mine has neither the steel plates nor the upper crossmember on it. The lower crossmember has 4 steel hydraulic lines on it that run up the left loader arm (looking at it from the front). I have a 48" bucket on mine. The curl cylinders are 40" on center. I'd suspect it is a more heavy duty version of the YFL 800.
FWIW,
Keith
Kevin any chance you could give me a few measurements......
1) my spacing between the two main frames on top is 37"....actullay 37 " in front and about 36" in back......
2) the lower brackets on mine have been changed....moved...I am wondering what it should look like...and trying to figure if the length of the arms were cut....I will attach a picture of what I am talking about....tip to tip (front to back) how long are these lower arms??
Does your bucket look like this one?? top is curved back with a "lip"......
I am thinking this could go on several size yanmars....just trying to figure out which ones those are.
Also anyone who has a picture of who it attached to the frame (front and back) would be appreciative.
Thanks for any help you can give.
Scott
/ Need some FEL info please #4
For the record you beat me to this loader by 10 minutes! lol I called while he was talking to someone about it (you I see) I had dibs on it if you passed on it. anyway if you see it won't work for your model I would be interested in buying.
Smoody,
Will be glad to contact you if I decide not to pursue it further!
Yea...I missed another one locally 3 weeks ago.....40 miles from my house!!! And alot cheaper......had to drive alot farther for this one!
This one needs some work....I am probably going to have to repack 2 of the cylinders....saw they were leaking.......a few thinks welded that should not have been....pretty big bucket....53" ......but it looks really solid. Probably would go up to a 30hp without any problem....
My understanding is that these FEL's were added on in the USA and were probably relabeled as "yanmar fel's".....at this point I have found 2 now that look like mine and both came off yanmars built for the usa market....
I am going to get an education on this one....I want to do most of the work so I can learn how it all works......this is a new endeavor for me.....once it is completed...either going to buy a tractor to put it on and sell it as a package or just sell it by itself repaired.... will let you know if and when I do it....
I am afraid before it is all said and done....I will have more time and money in it than it is worth.....but that is part of the game....getting it done and still keeping it with in the markets value.
What ever I do to it...will try to document most of it for others to see.....I appreciate all those who have done other projects and put them on this site for others to learn from......I have learned alot that way!
Scott
/ Need some FEL info please #6
Scott,
Mine is also 37 in the front. 36 1/4 in the back. There is some wiggle room there. Mine is as wide as it can get in the back.
The lower arms...well, couldn't figure out a good way to measure it. So, from the center of the bucket pivot bolt to the center of the upper cylinder bolt is 35 1/2 inches. If the lower arms were cut/changed, yours should not be the same.
OK, I see that I measured the wrong thing. That U shaped arm is 38 1/2 inches back to front. 39 1/4 if you add in the front bracket that it is welded to.
My bucket looks pretty much the same except I have some pipes that were welded on there at some point in time (for a grapple maybe).
Hope this helps,
Keith
Keith,
Thanks!!!! This is exactly what I needed....now just need to compare the measurements.....good news from the picture is that most of everything seems to be there to work with.
Yea....I think I noticed you have the bolt holes on the side(ends) of the bucket like mine.....wonder what that was for??
Now what models does this loader fit on is the next question....
Again thanks for taking the time...hopefully I can repay the favor down the way.....
Scott
/ Need some FEL info please #8
Scott,
Glad to help.
I think you mistook dirt for bolt holes on the bucket. Mine doesn't have any.
As far as what it fits, isn't that dependent on the lower mount (that's in your bucket)? I can't guarantee that the bottom mounts are the same. I do know that this one is on a US model YM226D.
Keith
Yea....I looked at the pictures after I sent the response and saw you did not have the bolt holes.....there are holes on the sides, tops and even in the bottom of the bucket.....but it is the same style bucket so must be original.
Nice original 226 with the "factory" bucket you have there! I am a purist...I like things to be original...goes back to my buying and selling small motorcyles....I use to collect early 70's minicyles...always tried to find original pieces ....carries over to these tractors....that being said my yanmar has a bushog fel.....not a deal breaker....just like original equipment when I can find it.
Noticed your FEL was made in Canada......
Again thanks for your effort!
/ Need some FEL info please #10
Thanks for the compliment. That 226 does everything I ask it to...but it isn't completely original. When I got it, the PTO was not working. Danny, from Parker Equipment, bent over backwards trying to find a 53 tooth gear to go in it but when there isn't one to be had, you just can't get one. Anyway, I replace the entire PTO with one from a JD750. It bolted right in but the input shaft was 1/4" too long. My angle grinder took care of that.
That supports what others have said about Yanmar not actually making the loaders.
I'm glad to be able to help for once. I don't know a lot about tractors so it's rare that I can contribute.
Keith
Took it by a fabricator today to have him look it over...I was aware of some items that had been welded improperly where the bucket attaches....and I wanted to get it done right..the news was not good....wanted a good bit of money for what needed to be done..he found some things I had not seen.....not unfair...just alot of money.....I am going to take it to a buddy who I wheel and deal with....hoping we can work a deal that does not have as much $$$ changing hands involved.....bottom line this is not going to be a good deal for me.......I knew I was going to get educated on what to look for, what to walk away from, etc.....just did not need it to be this expensive :( It can be fixed....just will cost more than I care to spend...may have a front end loader for sale sooner than I planned......if so Smoody gets first dibs.....
Scott
/ Need some FEL info please #12
You might be able to tell which loader it is by the cylinder measurements....that is, if the ID tag on the left hand side is missing or painted over. I can see one in one of the pictures posted.
Yanmar contracted to have about 3 different series of loaders made from what I heard at the time. Yours looks like the last series and it went like this according to their advertising sheet.
YM140/47 =YFL575 loader w/ 1.75"x15" lift cylinders
YM186 =YFL650 loader w/ 1.75"x13" lift cylinders
YM180 =YFL675 loader w/ 1.75"x15" lift cylinders
220/226 =YFL875 loader w/ 2.00"x16.5" lift cylinders
YM276 =YFL1075 loader w/ 2.00"x24.0" lift cylinders
YM336 =YFL1575 loader w/ 2.25"x24.0" lift cylinders
All of that series of loaders looked similar and used a single lever control. Bucket cylinders on the three smaller ones were all 1.5"x14". Larger ones used the 1.75" cylinder. The 226 bucket cylinders were 14" long, the 287 and 336 used 1.75"x20" bucket cylinders.
These were very nice loaders and stout. The cylinder packings can be tightened with a ring spanner to stop leaks. That's actually a good thing. But like any of this style they will seep some. I can scan the adv. doc. if you need.
Enjoy! rScotty
Thanks for the info....need a bit of good news at this point....it is on my trailer at my buddys shop....I will not be back till Wednesday but will look at it then....I am thinking it is for the 336....I took a quick measurement to get an idea of the size of the cylinders and I am pretty sure they were 2" plus ........if you have more than what is in the thread above would love to see it. At this point I am collecting data.....by any chance did the 336 FEL have the 53" bucket??
Thanks!! Any help will be appreciated. I am either going to make this fel right and try to get a premium or I am going to stop where and I am try to get as much as I can of my money back......
Is it best to just go to my local hydraulics store to get the material to rebuild or anyone have a better suggestion??
/ Need some FEL info please #14
Well, one bit of good news is that they are really, really good loaders. Look at the pivots, the bushings, the way the frame mounts, and the cylinder construction. Plus just how heavily built that it is. Top quality stuff. Sure it's a hassle to put it together, but welding is cheap and you will get a ton of use out of the loader.
On the cylinder size, I didn't mean to confuse things. Hydraulic systems are measured by inside bore - like an engine. It's done that way to make the hydraulic pressure and force calculations come out right.
So to give a feel for it, I did just go out and measured the OD (outside diameter) of the cylinders on our YM336D. Cripes! It's below zero degrees! Now OD might vary with manufacturer, but normally it'll be very close to being consistent. These 2.25" lift cylinders have about a 2.625" outer diameter and a 1.5" diameter rod. The 1.75" bucket cylinders are about 2.125" OD and have a 1" OD extension rod.
Also not sure how we are measuring the bucket. Normally it is measured in the largest direction from the outside of one end to the outside of the other end. The measurement is based on the total width of the path that the bucket would cut out if you forced it into something like a snowbank. The YFL875 could be fitted with either a 48" bucket or a 60" bucket. The YFL1075 and YFL1575 only came with the 60" bucket. The measurement of the width of the arms on the YM336D's loader is 45" from the center of one arm to the center of the other. The arms themselves are 2.5" wide. So if yours is 53" wide it probably isn't for the 276 or 336....not that you wanted that anyway. Too heavy. from the photos, your bucket looks stock - though I didn't really look for welds.
Not sure what "material to rebuild" that you need from the hydraulic shop? Hoses? The cylinders probably just need the packing tightened, if that.
Hope this helps, rScotty
/ Need some FEL info please #15
Well I can't afford to drop a load of$ either on fabrication to get it right, what did the guy have it mounted on? If this loader came on the YM276 it might work for me?? I have a YM2001 and the closet US model to it is the YM276 I believe.
/ Need some FEL info please #16
Smoody, I'm probably wrong, but I was thinking the YM220/226 was the closest cousins to your YM2001.
I will measure today...but I agree...after looking a picture of a 336 with a fel...this one is not that big.....I am thinking probably more like a 226 maybe a276....inside dimensions (spacing) on my arms were 37" at front and 36 1/4 at back.....pretty much the same dimensions that Keith gave me yesterday. The bucket pivots but the pins were welded on the outside ends....most of what needs to be done is welding....I am thinking 2 cylinders need to be repacked....maybe one needs to be rechromed...but maybe not.......if I could weld (always wanted too) it would be work but would save me a good bit of money......top arm was welded on to frame as well...alot of backyard welding is what I would call it...I am hoping my guy today will help me out since he and I do a lot of horse trading.....
Best to go to my local hydraulic place for repacking these cylinders????
I measured the inside of the bucket side to side and it measures 53" ??
Thanks
/ Need some FEL info please #18
I am going by what Hoye sent me 3 years ago when I ordered an owners manual for my YM2001, the manual actually has YM276 on the cover of it, was told that was the closest match, would like to know for sure though..
sacsr did the guy tell you what he used it on?
/ Need some FEL info please #19
Well I'm sure Hoye knows more than I do about it. I was just looking at weight and horsepower, 220/226 seemed closer, but evidently not.
/ Need some FEL info please #20
Back in the US Yanmar days, we used to think of the YM276 and YM336 as being remarkable for being so similar in size and capability. The 336 was more popular world wide, but the 276 was very popular locally - especially with specialized contractors and at golf courses.
Because of their popularity, the Yanmar distribulor carried in stock a lot of parts for both. I did hear a few years back that front axle and PTO parts for the 276 were becoming more difficult to find. I haven't heard that about 336 parts.
rScotty
2013 International DuraStar 4300 S/A Dump Truck (A66736)
2013 International...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
2013 FREIGHTLINER CORONADO 122 SD (A67714)
2013 FREIGHTLINER...
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
Kelly-Creswell Model C Walk Behind Paint Striper (A66734)
Kelly-Creswell...
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
