Ballast Fluid in the front tires?
/ Fluid in the front tires? #1
Lt220
Dalton, GA
John Deere 3032E with rear hydraulics
Can anyone tell me if it is O.K. to fill the front tires with liquid ballast on a tractor? Has anyone done this to their tractor to achieve a heavier front end?
/ Fluid in the front tires? #2
That would be one way to get front weight. Should do no harm.
What are you using/doing that needs the weight? Just curious.
/ Fluid in the front tires? #3
Not sure this is true but I've been told that if u put fluid in the front tires of a 4wd tractor it will mess up the 4wd
/ Fluid in the front tires? #4
Improving the traction on the front end and reducing slippage would make it easier on the drive train, reducing shock loading incidents
/ Fluid in the front tires? #5
That's actually harder on the drivetrain.
/ Fluid in the front tires? #6
I had all 4 of my tires filled when I got my 3320 new in 2005. I've had no problems and I appreciate the added weight, although I admit, it's not a lot of weight.
/ Fluid in the front tires? #7
I think it would be harder on the drive train since most 4 wheel drives are designed with the front wheels turning faster than the rear.
/ Fluid in the front tires? #8
For most CUT owners, filling the front tires is not going to give you a lot of weight since the tires are so small. Some mfg. say not to fill front tires especially if you have a FEL as that load must already stress the axles due to underdesign. Most Ag type tractors have all tires filled since they need all the weight they can get for pulling soil engagement implements. If properly filled, you wont see any difference in handling or steering. You may see a little more lift capacity on the rear end, but I cant imagine how 100 or so pounds is going to help much.. There are tire capacity charts available all over the internet that you can consult to see just how much water each tire size will hold. Consult those and then determine if what you will get will be worth while. I cant believe that adding water to a tire would void a warranty as some have mentioned on TBN or cause excess wear on bearings especially given that the bearing are only carrying the load of what is above centerline of the tire (75% fill= 1/4 weight capacity on the wheel axle) IMO, IF you want to fill, go ahead, I would not worry about damage to the machine.
/ Fluid in the front tires? #9
Filled tires do not apply any static load to the axles. The tire carry it own load whether it is filled or not, the axles attaching to the tire only brings in the load of the tractor above which does not increase when you add fluid.
This is the big advantage of filled tires (or wheel weights) compared to other types of weights.
/ Fluid in the front tires? #10
My dealer recommended putting Rimguard in the front tires of the 2010 4320 versus suit case weights on the front because it's about the same weight, cheaper and less stress on the axles. Took his word for it so my fronts are filled with Rimguard.
/ Fluid in the front tires? #11
The biggest problem I would see is if you have a FEL with a reduced amount of air in the tire there would be less abillity for the tire to carry heavy loads. Air can compress where as water will not.
/ Fluid in the front tires? #12
Tires are never filled past 75% so there is always air in the tire.
/ Fluid in the front tires? #13
:confused: Why would the tire lose ability to carry just because theres water in it :confused2:
larry
/ Fluid in the front tires? #14
I put Rimguard in all 4 tires on my JD 3320. No issues in two years. I keep the fronts blown up to max. pressure from the manual.
Dan
Thanks for all the advise guys. I'm looking at purchasing a new 3032E in a month or so and was curious if I could add liquid to the front tires v/s using suit case weights. I will not be purchasing a loader at this time so I was wanting to add more weight to the front to help counter balance any implements that I may be using. Plus it should add more stability if all 4 tires were filled. I will talk to my JD dealer also. Thanks again. :)
PORTA POTTY (A67714)
Hoelscher 110 Bale Grapple (A64126)
Hoelscher 110 Bale...
2016 CAT 323FL EXCAVATOR (A67714)
2016 CAT 323FL...
2014 MAGNUM TRAILER (A68842)
2014 MAGNUM...
2019 Ford Transit Connect Passenger Van (A66736)
2019 Ford Transit...
