rake with blade to remove snow?
/ rake with blade to remove snow? #1
bellweather
Western MA
Kubota BX22
I have access to a 60" Land Pride rake with flip-down blade and gauge wheels. I was thinking of getting it for snow removal (along with FEL). What appeals to me is the fact that I can angle the rake/blade which I assume will push the snow off to the side. Any thoughts on whether this would be a good setup? Thanks.
/ rake with blade to remove snow? #2
Forget who it was, but he had good results with just using the rake... the flip down blade would be extra nice :thumbsup: (when you get it, post some photos, it sounds like a neat implement).
/ rake with blade to remove snow? #3
I've used a rake to move snow. It worked very well, especially when I clamped a full length piece of U-channel on the tines. It acted as a scraper and also kept the gravel from being lifted. Later on, I added a piece of 2x8 to the rig as a backboard to keep the fluffy snow from leaking through the tines. The channel + board deal allows you to have a rear plow that's wider than the rake actually is because of how much wood you want to acquire.
Necessity is the mother of invention.
great idea attaching a board! Do you use gauge wheels or just allow the board to float?
/ rake with blade to remove snow? #5
The tines of my rake get clogged up almost immediately, with the wet snow we get around here. It works almost the same as a blade. I don't have gauge wheels, but if I did, I'd set them to stir up a bit of driveway-gravel into the snow that remains after I've gone over with the rake.
/ rake with blade to remove snow? #6
I have a 72" rake that does a good job moving light snow loads. I like the combed finish a rake leaves on the snow compared to a blades smooth finish. Much better for vehicle traction.
What size tractor do you have? Just note a 60" blade on a 30 degree angle has a usable width of about 52". Make sure this is a good size match for your tractor.
/ rake with blade to remove snow? #7
JohnDeere3720 uses a rake...
/ rake with blade to remove snow? #8
I used to have a rubber cutting edge I bolted on the back of an 8 foot rake. I really thought it worked good, I never angled it though. I also had a 100 pound weight strapped on it for down pressure. This was on my JD 3720.
Covered Livestock Mineral Feeder (A66408)
Covered Livestock...
2022 EZ-GO ELITE...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
Pair of 480/80R36 Tires (A65640)
Pair of 480/80R36...
2022 EZ-GO ELITE...
