Snow clearing - Scotland
/ Snow clearing - Scotland #1
Miles Ambler
Kioti EX35M
Hi. I live at about 1000' above sea level on a farm in the Scottish Borders and every year we get snowed in. I'm about to sign for a new Kioti Compact EX35 tractor and it'll come with AG Tyres. Does anyone know how well it'll cope, with those tyres and a normal front bucket? The snow is usually heavy, wet and very deep, so a snow blower won't do it, but I'm worried about traction. I don't want turf tyres with chains if I can possibly avoid them.... Very grateful for any comments at all!
/ Snow clearing - Scotland #2
Hello Miles Ambler, welcome to TBN! Glad to see you posting. Hope you enjoy being a member of our community. :)
/ Snow clearing - Scotland #3
Chains + snow = better traction than with out.
Front bucket (I assume you mean loader) is probably the least efficient snow moving tool you can put on a tractor. It does work, but it takes a lot of time to move the snow.
Most of us over here in the states that have gone to chains for winter use do not ever see going back to a non-chain configuration.
/ Snow clearing - Scotland #4
The snow blower is the ultamite machine for removing snow. It clears a path , but yes it can only blow so much. I have had to use my blower and only remove 1 ' in width and the blower is 5' wide but I was in low range pushing through snow as high as my rear tires. This tire ( tyre ) ratio will relate to HP and tire size more or less.
Craig Clayton
/ Snow clearing - Scotland #5
Wet, heavy, deep snow you say. Bucket will work fine. If traction problems arise add some chains.:thumbsup:
For plows you have to have room alongside the road for the snow. With the bucket you can move it around. :)
Blowers may/may not handle your snow conditions. It's best to check the local area for opinions on how they work.:)
/ Snow clearing - Scotland #6
Welcome to TBN!!! Try using the tractor as is and if you don't have enough traction, ad some chains to the AG tires...
Thanks guys - all useful stuff. I'm coming over to Barrie, Ont. to see my family soon, so I guess I'll be able to find out how you all cope with REAL snow!
/ Snow clearing - Scotland #8
Hello Miles I live east of Barrie by 50 Miles. We are having an easy winter this year. If you want snow the US New England states are really getting it.
Craig Clayton
/ Snow clearing - Scotland #9
I have a Kubota MX5100 with Ag tires. Which is fairly close to the Kioti you are looking at. those are the best tire for snow clearing in my opinion. I have a 2.5 mile driveway that I have to plow constantly. I had R-4's on last winter and they were horrible.
I agree with the chian suggestion stated earlier. Also, be sure that the dealer fills the tires before you take delivery. Loaded tires really help..
I would also look into a 7ft rear blade if you don't want to go the snowblower route. The bucket works OK but the rear blade can be angled and will work alot better.
Thanks - that's helpful. I have a compressor so will fill the tires and keep them well-filled. I wonder if you can use a blade on the front loader arms, as a direct replacement for the bucket. It's just that I've read lots of messages that say that a rear blade is not very effective.
Some folks would say "just try different methods and see what suits you best", but the thought of spending all that cash when you guys are out there to advise me what doesn't work....!!!
/ Snow clearing - Scotland #11
Sorry, I should have been more specific. I didn't mean fill the tires with air, I meant fill the tires with fluid to add weight. it makes a huge difference in the snow.
Also, the rear blade will not work on the FEL ( front end loader) You can get a snow plow that would replace the front bucket but, you will need a 3rd function valve on the front to run the power angle for the blade , unless you get the manual angle blade. The manual angle blade is cheaper and works just as well. You would just have to get off the tractor to move the blade.
I get a ton of snow and I use the rear blade quite a bit. It does work well. If you get into snow that is so deep that the rear blade in no longer effective i think it is time for a 3pt. snow blower.
Sorry - I was being a bit dumb - I should've realised that you meant fluid, not air! Having said that, I have no idea how many folk in the Scottish Borders get their tires fluid-filled and the dealer will probably think I'm nuts. I'll give it a try, though.
All your stuff on the FEL/blade/manual angle is incredibly useful. Thanks a lot.
/ Snow clearing - Scotland #13
Be sure your dealer loads your tires with a calcium mix or even windshield wiper fluid, not just ordinary water. Obviously, the water will freeze and damage your tires. Most people only load the rears. Loading the rear tires also helps add weight which is super helpful when you are using your FEL . It helps balance the tractor.
I have even heard of loading the tires with beet juice.
You might want to do a search on here about loading tires.
I'll do that. Thanks again.
2019 GALYEAN...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
2022 Case CX145D SR Hydraulic Excavator (A61567)
2022 Case CX145D...
2025 GIYI GY-P45 Hydraulic Breaker Skid Steer Attachment (A61567)
2025 GIYI GY-P45...
1999 INTERNATIONAL4700LPX 4X2 BOX TRUCK (A59908)
1999...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
