Hydraulic PTO vs Mechanical
/ Hydraulic PTO vs Mechanical #1
8404
Gold Member
North Mississippi
Cub Cadet 8404 or DK 40 Kioti
I have a DK40 and have had no issue with the it in fact i consider it a step up from the mechanical pto. So now its time i was considering adding a second Kioti to my pack and was looking at the DK55 because of its larger size and comes standard with 2 sets of rear hydro remotes but then is see it uses a mechanical engaged PTO so whats up with this?? Im stepping up to a better,stronger more expensive Kioti but it leave out the Hydrauic PTO? why?
this is not a deal breaker but i does raise questions on which is the best set up for larger tractors. anyone know why KIoti did this with the DK55
you can clearly see the mechanical linkage for engaging the PTO in this pict. and the very usefull 2 sets of remotes
/ Hydraulic PTO vs Mechanical #2
There is generally a big HP advantage with the gear vs hydraulic PTO. Normally the gear PTOs develop nearly all the engine HP at the PTO. Some of the larger tractors have higer HP ratings at the PTO than drawbar HP. Hydraulics will have more loss and will require a large pump to drive a high HP PTO. Also an oil cooler will be required for high HP hydraulic PTOs. An advantage of the hydraulic is, they are sometimes reversible and are somewhat easier on shearpins. Surplus Center (tractor bynet advertiser) offers a add on hydraulic PTO complete with motor and a correct PTO spline.
/ Hydraulic PTO vs Mechanical #3
The "hydraulic" PTO on Kioti and most other tractors is simply an electro/hydraulic clutch to start and stop the shaft which is directly driven by the tractor flywheel (other than the gears used to match PTO speed on the engine to 540 on the PTO shaft. It is not turned hydraulically.
/ Hydraulic PTO vs Mechanical #4
the ones that are switched on by a solniod have been none to engage ruff and sheer the pins if you have that set up on your bush hog. With a manual you can feather it in. I love manual pto engagement. But it is getting harder and harder to find but most big tractors75-140 or so still have manual pto engaement.
/ Hydraulic PTO vs Mechanical #5
I have a dk55 and the pto is push button engaged, electro/hydraulic clutch. It's worked well so far and the engagement is very smooth but I don't run a brush hog. It works well with my snowblower.
Scott
I guess i am wrong about the 55s PTO.
Bellcon, what is the linkage on the left side of the PTO? the one in the picture
/ Hydraulic PTO vs Mechanical #7
Sorry I thought you were dealing with a hydraulic PTO vs. hydraulic clutch. I have a skid steer and probably should keep out of tractor discussions.
OK the DK 55 does have electric over hydraulic clutch in the PTO and im now guessing that the lever linkage on the left side of the PTO must be the switch between 540 rpms and 1000rpms. Im likeing this tractor better now
/ Hydraulic PTO vs Mechanical #9
I think you are right. I believe it's the linkage that switched the pto speed but I would have to look to be sure.
Scott
/ Hydraulic PTO vs Mechanical #10
I have a dk55, and that is a push button pto engagement. it can be harsh on shredder engagement. but has worked well for me. The connection would be to the 2 speed pto, as it has a 540 and a 1000 rpm position under the left foot in the cab. i use the 1000 on light mowing at reduced rpms sometimes.
/ Hydraulic PTO vs Mechanical #11
We have used PTO slip clutches for brush cutters / rough cutters to smooth out the start up with the Hydraulic-Engaged PTO. They do a great job of taking the "kick" out of the start up. We have used them on the DK45 and DK55 tractors with very good results.
/ Hydraulic PTO vs Mechanical #12
I prefer the foot clutch, especially when using a post hole digger. And, they are probably longer lasting as there is no solinoid to fail.
/ Hydraulic PTO vs Mechanical #13
Hi Michigan Iron,
Maybe you could help me out on this one. :thumbsup:
My small square baler and sickle mower start fine with the slip clutch. My Kuhn hayrake starts a little harder than I like. The PTO is tied directly to the gear box with no clutch. I have been wanting to add a slip clutch but with PTO shaft going through the main frame tube and to the gear box I haven't figured out how to do it. Normaly they seem to be at the gear box. I need it to pivot at the frame tube if I could fit one there. These are the best pics I could find.
By the way with the short wheel base of the DK45, this is one great combo for raking hay! With the 3 point mount I can lift and turn without crossing over the end rows. Great for point rows as well.
/ Hydraulic PTO vs Mechanical #14
i had a 2007 kioti dk55 and never did get use to that sudden jolt it gave a brushhog when i hit the button, i always thought that was the only bad design flaw of the tractor, that and the tiny loader bucket. but the push button pto sucks in my book. i sold the tractor and now have a 77 ford 3600 and a 64 ford 4000, old iron is hard to beat and its cheaper.
/ Hydraulic PTO vs Mechanical #15
Any electronics whizz's out there? Can't they make a solenoid that engages slowly or does it have to be a quick, on/off? It seems like the engineers should be able to ****** the clutch engagement so it engages more gradually. I'm considering upgrading my tractor and the sudden engagment is the only thing I don't like about the electric PTO set ups.
/ Hydraulic PTO vs Mechanical #16
Just idle down when engaging. I would never want to set a slip clutch loose enuf to slip on startup. Thats flirting with burning it anytime you run into a heavy load on the implement.
larry
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2016 MULTIQUIP DCA-25SS1U4F PORTABLE GENERATOR (A63276)
2016 MULTIQUIP...
15K PARTEK TRIPLEX PUMP (SHOP BUILT NONE TITLED) (A63569)
15K PARTEK TRIPLEX...
Hyster H65M Forklift (A64047)
Hyster H65M...
Agline ADM109 Disc Mower (A64047)
Agline ADM109 Disc...
John Deere 5090GN (A60462)
John Deere 5090GN...
