Built a Shrub Bucket
/ Built a Shrub Bucket #41
I have one from markham, pretty much as per the pic by JJ in 35. Pretty cheap (why I bought it). I haven't found it too useful, but I have a backhoe. Would probably play with it more otherwise.
One improvement I think would be to make the sides straight. Mine is wedge shape, with the fat end toward the FEL. I don't see an advantage to this design, and I think it makes a lot more resistance to digging.
I note the second batch of pictures JJ posted, #s 2 and 4, are straight, and they look to me like they'd be more useful for shrub digging.
Just circling back on this older posting..... The Tree Spade / Shrub bucket is still working fine, and as someone asked, I've found there are other uses for it to (since I'm basically lazy).
> Cutting a swale or ditch..... the bucket design is just right for cutting a narrow trench or drainage swale. Takes practice to get the right scrape angle and push speed.
> Picking up debris / bricks. Worked really well for moving a pile of used bricks. The full size bucket seemed to push the brick pile, while this bucket cut into the bricks and grabbed a full load.
> Laying gravel into a drainage ditch. Straddle the ditch and as you back up and tip the bucket it fills the ditch covering field drain pipes nicely without dumping gravel everywhere. BTW - I also used it to spread gravel on my Two-Track road across a field....the full size bucket dumped it across the full width...with this one I can dump right into a single track at a time.
/ Built a Shrub Bucket #44
I have been looking for something to transplant trees for sometime. I found this thread to be rather useful in my research. I am currently tweaking the given specs/plans and am having one fabricated. :thumbsup:
The problem I found with most stump/shrub buckets on the .net was they were built for skid steers and required an adapter to fit my 300cx loader. Which alone was more than the bucket.
I should have it in the next few weeks and will be eagerly awaiting putting it to use. I'll post results after getting a good feel for its usefulness.
Thanks for all the information and tips.
/ Built a Shrub Bucket #45
Wow, three years in three posts, look at how JJ's beard grew.. :D
And.. Jeeze, by a guy on his second post since 07, I feel like I'm in a time warp, welcome to TBN tratliff!
/ Built a Shrub Bucket #46
I have been looking for something to transplant trees for sometime. I found this thread to be rather useful in my research...
Great, looking forward to seeing your bucket... don't forget the photos :) and thanks for bring this thread up, since I guess I missed it the first time around :laughing: :thumbsup: :D
/ Built a Shrub Bucket #47
Thanks for the Welcome Jake98.
I don't have much experience with heavy equipment so I mostly sit back and read. Visit daily but rarely post (as you have pointed out).
/ Built a Shrub Bucket #48
That's just how friendly we are at TBN... :confused2: some people just like to post and post :(
/ Built a Shrub Bucket #51
...I am currently tweaking the given specs/plans and am having one fabricated....I should have it in the next few weeks.... I'll post results after getting a good feel for its usefulness...
Would love to hear how it turns out... either Positive or negative... Here's hoping for the positive :thumbsup: (oh, and don't forget the photos :laughing:)
/ Built a Shrub Bucket #52
With the snow and ice we have had in north Texas it delayed my bucket by a week. Well I picked it up on Saturday. First order of business was to prime and paint, that took most of the day. I decided to give it a try on Sunday morning. Mounting it to the 3120 was a dream. Fit like it was made by JD. Even my wife was surprised by the ease of assembly. My first tree transplant did not turn out so well.:confused2: I was trying to get the hang of things but using it to remove the tree gave me the experience I needed. I then proceeded to my second tree and within a couple of minutes had the tree upright on the bucket and moving towards its new home. All in all I removed 1 tree and transplanted 4 in one day. Started with smaller trees and progressively got bigger. My last tree was about 10' with a 4-5" trunk.
The one observation that I made is that it is very difficult to see where it is. In relation to a tree to transplant or a tree to place. Once I had my wife helping with the location of the bucket we could easily transplant a 6'-10' tree in 20 minutes.
I have not taken any pictures. We were so entertained by transplanting trees that we did not take the time to take pictures. I will get some posted in the next few weeks.
I have decided that my next project is a carry all. Something that will mount on the back of the tractor on the iMatch and carry tools and a 55 gallon barrel of water.
/ Built a Shrub Bucket #53
Well I was finally able to get a few pictures of the shrub/tree bucket and fabricate the carry-all. The tree bucket is working very well and I spent last weekend on the carry-all. It is still a work in progress but has given me some experience in welding. The carry-all mounts to the iMatch and has a 2" receiver on the back in order to pull my utility trailer.
/ Built a Shrub Bucket #54
Just wanted to bump this thread so I can find it easier! :)
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
2015 PETERBILT 320 6X4 T/A CNG GARBAGE TRUCK (A66091)
2015 PETERBILT 320...
2003 PETERBILT 379 SLEEPER (A59914)
2003 PETERBILT 379...
Unused 2023 Hustler Regener8r LM630 Hydraulic Chain Harrow Tractor Loader Attachment (A66734)
Unused 2023...
Unused 2024 Land Pride RCF2072 6ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2024 Land...
