Need educated on 3 pt backhoe attachments.
/ Need educated on 3 pt backhoe attachments. #21
Use the search function Willl, its your friend.
Been trying, went through all of Roberts threads that he started. Can't find it.
The list that comes up when I search for all posts he replied to is quite large.
I guess I need a link. :(
I can see quite fine. Which of those quotes were 'first hand' ?
/ Need educated on 3 pt backhoe attachments. #22
RichNJKubota, dieselsmith, tractorracer17, AndyMa, and Robert in NY all appear to be first hand accounts to me. Since I didn't search very hard, I'm confident someone more motivated could find plenty more. You know, I've never seen anyone who was maimed by getting tangled up in a rotating PTO shaft, but that doesn't mean it's never happened.
/ Need educated on 3 pt backhoe attachments. #23
So ar eyou guys saying that ALL 3pt. hoes have to possiblity of breaking the tractor in half or that only 3pt hoes without a subframe have that possibility?
from what I gather from these posts a subframe is tracotr spcific which I pretty much guessed and that MOST ( not all) 3 pt backhoes are universal fit to these subframes. Is this correct?
Forgive our dog and pony show going on in your thread.
Today, if you were to go to your local tractor dealer and purchase a new tractor with a backhoe, overwhelmingly, they will be selling you a subframe mounted backhoe. The reason is, over the years, there have been enough tractors damaged by three point hoes to warrant selling them this way.
Certainly, the odds are against a three point hoe damaging your tractor, but I would still advise you to purchase a subframe mounted backhoe. As an example, when I was purchasing the subframe for my Woods BH80X, the price difference between the subframe and a three point mount was approximately $800. To me, it didn't make sense to NOT get the subframe mount. Your mileage may vary.
/ Need educated on 3 pt backhoe attachments. #24
It's possible that it may be a good way to sell you a more expensive one, I'm thinking..
It's also possible that it's a way to keep from having to warrant broken tractors from the unsupported stresses.
I've seen broken tractors using subframe mounted hoes. Owners manuals of construction TLB's typically call for a complete inspection of all structures at 500 hour intervals and weld all cracks found - and cracks are often found. BH's inflict a lot of stress and damage even with a sub-frame. Surely, you don't think that REMOVING the sub-frame makes the tractor/hoe stronger?
/ Need educated on 3 pt backhoe attachments. #25
You see any stiches on my forehead? I try not to say totally stupid stuff.:D
/ Need educated on 3 pt backhoe attachments. #26
I might as well weigh in, too.
I purchased a Woods 3PH backhoe for my Kubota L3130 two years ago _from a Kubota dealer_ and he assured me I would have no problem with my tractor cracking in half or the backhoe's toplink breaking and crushing me. He said that was a problem on smaller tractors. I was willing to go the sub frame route, he had those, too, but I took it on his experience and suggestion that it wasn't necessary.
All anyone can do is listen (or read), weigh the info and do what we are comfortable with.
/ Need educated on 3 pt backhoe attachments. #27
Call up your color dealer of choice and ask if they warranty tractors with 3pt hoes. Most (if not all) no longer do. If it's not a problem, why?
I think the only risk is if you have a backhoe that is not well matched to your tractor. Most dealers will sell you a 3ph backhoe if it is properly paired to the tractor. They may not want to warranty one if you go off on your own and purchase the bh.
/ Need educated on 3 pt backhoe attachments. #28
What's the height issue with a sub-frame? If you're cultivating crops I would think that would come into play.
/ Need educated on 3 pt backhoe attachments. #29
Jake,
On my New Holland subframe BH, the ground clearance is reduced by about 4" with the subframe/BH off of the tractor. The center, rear subframe carrier plate mounted below the PTO shaft is where the clearance is lost.
Your other question about the 3pt function - with the hoe mounted, the 3pt is inoperable, hoe unmounted it works as normal. This is due to the way the hydraulics are plumbed. There is no room to use the 3pt with the hoe on the tractor anyways and probably unsafe if it could be operated.
Dave.
/ Need educated on 3 pt backhoe attachments. #30
Jake,
Dave.
Yeah, I figured you wouldn't want the hoe on in the garden.. but the sub-frame might stop a person from cultivating, is what I was thinking. (a reason to go with a 3 point BH)
/ Need educated on 3 pt backhoe attachments. #31
I have a 3PH backhoe that I have had for about 6 years. I don't use it a lot now but used it for most of the first 100 hours on the B7610 I had before. It doesn't simply hang on the 3PH, there is a small frame that bolts to the drawbar with large turnbuckles, similar to the adjustable top link turnbuckle, that go from that frame to the BH. Adjusted correctly you have the top link under compression rather than tension so unlikely to stretch bolts and/or threads in castings. This way the drawbar carries a good deal of the weight of the BH too.
I bought the BH from the dealer I bought the tractor from. I asked them about possible damage from the 3PH mount, having read about it on this forum. The only tractor they had seen damaged was one where a carrier had chained the BH bucket to a trailer when the BH had the transport lock on so the bucket was off the trailer deck then took off down a rough road. The bouncing of the tractor on its tires with the bucket chained down caused the damage. They did not 'know' of any tractor that had been damaged while digging witha 3PH BH.
If you tend to break things then a subframe is the better choice, IMO. If you operate with some finesse and don't just keep pounding on things until something gives then the 3PH style will give you years of problem free service.
This is my experience and my opinion based on that experience. I don't doubt that tractors with 3PH BH's have been damaged but so have tractors chained to stumps.
/ Need educated on 3 pt backhoe attachments. #32
Brandoro, I'll have to agree with you. I've had a small 3-point backhoe attached to my Kubota L245DT for several years now. I don't mistreat it because it clearly can put stress on the tractor. Of the pictures I've seen of tractors broken in half with backhoes, it appears most, if not all, were broken while driving the tractor down or across a very bumpy road or field. My guess is that most of those owners would have destroyed their tractors in just about any manner given enough time.
/ Need educated on 3 pt backhoe attachments. #33
I hear one of the best ways to break your tractor in half is to throw a chain over the middle and crank it down to a trailer.
/ Need educated on 3 pt backhoe attachments. #34
I should have bought a mini excavator instead for the money, mine is sub frame mounted very strong, I am an equipment operator, and operate several machines
2019 CHEROKEE TRAVEL TRAILER (A63569)
2019 CHEROKEE...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 PETERBILT 579...
DRILL CABINET SKID (A63569)
DRILL CABINET SKID...
2007 CATERPILLAR 966H (A63569)
2007 CATERPILLAR...
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
