Winch Modifications
/ Winch Modifications #141
The wireless part is relatively cheap - less than $30 using the atv wireless winch controllers I mentioned earlier. The expensive part is the $130 solenoid selector valve required. So it would cost $160 plus hoses and fittings.
Ken
/ Winch Modifications #142
Bob,
Does the winch specifically say direct drive, or is there a planetary gear set inside the drum?
One other recommendation would be to install a roller fairlead on the winch to prevent the cable from rubbing across the side of the drum. If not used, you would have to pull almost straight on.
Roller Fairlead The fairlead guides the steel cable during the winching process and prevents the cable from getting snagged in moving winch parts. An aluminum fairlead is recommended for use with synthetic cable.
Bob,
Does the winch specifically say direct drive, or is there a planetary gear set inside the drum? IT DOES NOT STATE ONE OR THE OTHER.
One other recommendation would be to install a roller fairlead on the winch to prevent the cable from rubbing across the side of the drum. If not used, you would have to pull almost straight on. I INSTALLED A FAIRLEAD
SEE COMMENTS IN CAPS
/ Winch Modifications #144
The last time I looked at a PT winch, it was nothing more than a winch drum attached directly to the shaft of a hydraulic motor. IIRC, the motor displacement was around 14-18 cu. in./rev.
I think power out will be the only option.
Just looking at it, that would be my guess.
I talked to Terry at Power Trac today about running the winch off of the main PTO. He says OK, but it will run fast. This way I could add a remote switch on a cord and be able to observe and control from a distance.
I have been working on eliminate the angle irons by making a plate. I will be uploading pictures soon.
/ Winch Modifications #147
Bob, do you know the cu in of that winch motor?
About how many rpm does the drum turn.
How fast can you reel in the winch from 100 ft.
Gravy says it's 14 - 18 cu-in/rev. I don't know the speed, but it's pretty fast.
/ Winch Modifications #149
You might be able to put a flow control valve on it to slow the flow down and therefore slow the feed rate down if it is too fast, but it would heat the oil up more, but you could open it up and close it down as needed.
/ Winch Modifications #150
What do you all mean fast. It depends on the amount of lever action that you give the hyd valve. Slow to fast.
If you knew the cu in of the motor, you can figure out the rpm, with whatever flow.
For example, 8 GPM, 15 cu in , rpm will be 123, and with 20 cu in, rpm will be 92
You can also slow down the engine.
Attached are some pictures of the new base bracket for the winch. With this and adding a new receiver pin hole, I can reduce the length of the assembly by about 3 inches.
I added a 5th hole in the base and into the winch backplate. I then welded a nut to this hole in the base. The male 2 inch receiver post is welded right on top of this (just covered it not actually welded to the nut). Just a little extra strength where the forces are greatest.
Well I just tested it out and it works very well and is easy to use. I have the following options.
1. I can set the valve at the back to reel, stop, or unreel and then at the drivers position use the aux PTO to engage it.
2. I can lock the aux PTO to down (must be down only) and operate it from the back.
3. I can disconnect the valve in the back and operate it with the aux PTO in both directions from the drivers seat.
It is a lot easier to use now since I can watch the winch cable and operate the controls. J_J, I timed the reeling in starting with the cable fully extended. It took about one minute. The cable is supposed to be 50 feet, but I did not measure it. It seems plenty fast to me and while I did not measure it the engine speed did not seem to have a big effect. I don't understand that, and it could be an illusion.
Again, thanks to all for the many comments, suggestions, efforts and patience. I really did not expect to do this much, but I am a lot happier with the winch than before.
So now that is done, what are you going to winch? :laughing:
Mostly the Power Trac 422. Also logs out of the swamp. I live in a swamp, well some of it is a swamp. I get stuck occasionally. If the truth were known, I really don't need a winch all that much. This is probably the most frivolous attachment that I own. I have a hand powered boat winch that works pretty good. But, you have to crank a while, drive the PT a little and repeat.
Value of the winch, somewhat useful. What I have learned priceless!
/ Winch Modifications #156
JJ on my 425 if you use the quick attach valve you can control that by how much valve you give it , but on the aux valve when you flip the switch it is fully on. Slow the rpm down on the engine might help with the speed if in fact that is an issue. May not even be an issue though.
/ Winch Modifications #157
Way to go Bob. Nice job !! Glad it all worked out for you in the end.
Go Swamp logging !!!!!:D
FAZ
I consider the aux pto and quick attach valve to be the same thing. The PTO is the other system with higher flow and on/off only by switch. Sorry for any confusion this has caused.
/ Winch Modifications #159
The aux PTO and the quick attach are the same connections/valve, I believe. The PTO is the high flow PTO circuit.
Ken
/ Winch Modifications #160
I knew you could get it done. Don't worry about confusing me , I stay cornfused all the time anyway.
2018 Chevrolet Silverado1500 Crew Cab Pickup Truck (A61573)
2018 Chevrolet...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
Three (3) John Deere 6000-Series Hood Guards (A63116)
Three (3) John...
DRILL CABINET SKID (A60736)
DRILL CABINET SKID...
ATS ME18 Mini Excavator (A64047)
ATS ME18 Mini...
1990 CASE 580K LOADER BACKHOE (A64047)
1990 CASE 580K...
