Snow Pushing snow
/ Pushing snow #11
I recently bought a new JD2520, and the primary reason was to get the FEL, and hopefully be able to push snow without having to use chains. It just wasn't cost effective to add the loader to my previous tractor, (an older Yanmar 27hp 4wd) so I opted for the new one.
I also have a JDX495, (My primary lawnmower even though I did get the 62D for the 2520) for which I had the quicktatch front hitch and 54" blade, that I used to plow snow. In the deal, I had the dealer swap out the hitch I had on the X495 for the one that would fit the 2520.
I really have never tried to move snow with the loader, as I, like you, was also told that the blade does a much faster job. I can say that it does work very well, but as another poster has said, my 2520 could easily handle a wider blade, which would make the job that much faster and easier. Too bad JD doesn't offer a wider unit, I would buy it in a minute. I do have the loader "at the ready", so if I do get too much snow around, with nowhere to put it, I can switch out the blade and mount the loader pretty quickley. The best scenario I think, is to have both front blade & loader. The blade is faster, but can't move the "BIG" piles that easily.
I did purchase a ballast box, for added snow pushing traction, (which was suggested by other forum members) and have found that it was a good investment, it does make for a lot of added traction. I have the R4 tires, which some are not thrilled with for pushing snow, but I did not want to have to use chains as I did on my X495, and have found that so far, it all works pretty good. Although I do have a pretty flat area I have to clear.
My actual driveway (about 300') is paved, and I can easily run the full length with the blade angled and clear a path through 8-10" of snow. A few runs down the center and each side and I'm done. Unfortunately, my parking area directly in front of my garages is gravel, and it's a lot slower clearing the snow here uness I want to splatter stones all over the lawn, and have to rake 'em up in the spring. Thats a real PITA. I'll have to save up and pave the whole thing I guess. Sure would make plowing a lot easier.
I find it a lot easier to "grade" my gravel parking area with the loader rather than the blade. I just crank the bucket itself down where the front edge will grade the gravel while backing up. To me it works much better than my blade, leaves a far smoother surface when I'm done. Must be the added weight of the loader that helps.
REV
/ Pushing snow #12
I have a 60 inch snowplow on my ATV, and my 2520 would push 3 times as much, so that 54 inch blade is just way too small in my opinion. I get bored with the 60 inch blade on my atv, I can't imagine a small blade on a slower moving tractor. I often plow at 20 MPH with the ATV. :laughing:
/ Pushing snow #13
I too agree, you will want something bigger. I was in a similar situation as the previous owner would use the FEL on the drive. After I saw the scraping damage it did to the asphalt I knew this would not be the best approach. Once we took possession of the house I purchased a WR Long 84" plow that mounts to the loader arms. I also opted for the the urethane cutting edge which is very gentle on the driveway. Very satisfied with the setup.
/ Pushing snow #14
If I were to go with a 3rd party blade, I wouldn't give up hydraulic angling for a wider blade. Yeah, the tractor will handle bigger. But, it should be very very fast. So, unless you are plowing huge areas, the JD blade is a very sweet setup. In general, for snow falls under 12" without a huge winter buildup, a front mount blade will be faster than just about anything. I wouldn't want to move snow with a loader. That seems like a real PITA.
6" or less snow and I can plow five or six 100' drives in about an hour with my little 425 using the 54" blade. It's very fast and precise. And it's one tough little bugger too. I've used the heck out of mine for 17 seasons and just this year had to put a new cutting edge on it. If you are worried about drive damage, get a rubber edge. For stone, just add a piece of slitted PVC pipe to the bottom edge of the blade.
/ Pushing snow
Some good wisdom from all of you - thanks.
OK, so which aftermarket blades also work with the hydraulics and/or have the whole set up together like the 54" JD blade? Under $1,500 to $2,000?
/ Pushing snow #16
I bought a 54" blade for a 300 series and had a bracket fabbed up and had longer hoses made. I'm into it about for about $600. That's about half of what new would cost.
/ Pushing snow #17
Agree but I'd rather have both,longer blade and full hydraulics. If you are looking at third party options check out the wr long setups. They have a varity of widths available with hydraulics.
/ Pushing snow #18
I have the jd 2320, 54 inch blade with both rubber and hard edge and 600 feet of 11 foot wide asphalt driveway. The 54 incher is the biggest from jd.
I wish the blade were wider, but it really doesn't make sense if it were. Look at the math. The first pass is just off center with the blade at 90 degrees to the driveway. On the return the blade is angled to the right and you use nearly a 50 percent overlap to prevent spillage of snow to the left. So essentially you are clearing a 36 inch path. On the second round trip you again use a generous overlap and tidy up the right and left side of the driveway. So in two round trips I clear the entire 11 foot width.
If the blade were wider, like 70 inches I could plow in three passes (one and a half round trips) but that would leave me at the far end of the driveway and I would still have to come back.
If you get the JD 54 incher, be sure to get the rubber edge and two sets of bolts (long and shorter you paid for them). Also set the plow handle so that the springs activate for snow plowing. The skids should have the rubber just touching the asphalt. Sure the rubber will wear, but that's the cost of doing business.
/ Pushing snow #19
Check out wr long. I paid 2,500 shipped for the 84" w/hydraulics and the urethane edge. The blade alone in a manual setup was 2k. Te smaller blades should price out in your range. I ordered mine from Iowa Farm Equipment and it was drop shipped direct from the mfg in NC. Send me a pm if u want their contact details.
/ Pushing snow #20
Check at the MF or Kubota store. I believe they both have front power angle blades where the QA clamps on a front bracket approx 13" x 6" x 3/8"
2014 CATERPILLAR 140M2 AWD MOTORGRADER (A62129)
2014 CATERPILLAR...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
2017 Versatile 260 (A60462)
2017 Versatile 260...
UNKNOWN TANK MANIFOLD (A60736)
UNKNOWN TANK...
(12) SKLP SK-LJB-12 Polyethylene Roadbed Protection Pads (A60463)
(12) SKLP...
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
