Hydro vs Power Reverser
/ Hydro vs Power Reverser #1
Red Horse
Bolton, MA
Deere 655ZTrak, Deere 4720 Cab, 400 X LT 155
Hey guys-looking for an opinion. After freezing my butt off plowing in the last two storms, I'm thinking at my age maybe I should spring for a Curtiss Cab for my 3320. Then again, if the right opportunity presented itself, should I spring for a cab tractor?
Having said that would I get another hydro or go for a power reverser? I've had a 755 and the 3320 hydro and they have been trouble free. But I hate the slow loader hydraulics-at least with P'Reverser you could throw it in neutral, hit the throttle and improve your loader cycle time.
Sure would be nice if Deere could engineer a driveline disconnect on a Hydro like on a big machine so you could speed up loader operation but I guess that is wishful thinking.
Any opinions?
/ Hydro vs Power Reverser #2
I guess I don't understand-the throttle is independent of the hydro controls...you can be sitting still and have the throttle all that way up.
/ Hydro vs Power Reverser #3
I am a big fan of the reverser tranny. I guess I don't understand the slow hydraulic statement. Set the hand throttle to desired operating rpm for hydraulic function. Select range for appropriate ground speed. Do the rest with the hydro.
Guys- 10-4 on running the tractor at higher RPM to get the desired loader response and using less hydro-pedal. That to me though is not a good alternative. If you are used to running TLB's or loaders etc, you have a drive line disconnect button so your loader speed is independent-that's what I'm talking about. Now I understand there is a new hydro option that has a foot throttle and a forward /reverse lever on the instrument panel-like a power reverser-but guess what?? They put the brake pedal on the right side and no individual brakes!!! Not something I would ever want.
/ Hydro vs Power Reverser #5
Red Horse,
I am familar with this joystick switch to disconnect the drive train but it isn't needed on a hydro tractor anymore. Raising the rpm's on the hydro tractor is likely better for the engine anyway. This doesn't seem to increase fuel consumption much either. I might add no worries about letting your finger off the button and running into a dump truck either. I did that about twenty years ago.:mad: It was my dump truck too.
/ Hydro vs Power Reverser #6
I think you may be running your machine improperly. If you read the manual, I'm almost sure it says to operate at full throttle, or nearly full throttle all the time. This will give you the hydraulic performance you want. Control ground speed with the hydro pedals.
I have a PowerReverser. There are times when I prefer it to a hydro, but they're few and far between and they most certainly do not include hard core loader work. I got a deal on a new machine that had been on the floor too long to suit the dealer. If not for that deal, I would have gone hydro. Five years later I sit back and look at the $1000 I saved and wonder if it has been worth it. I would like a hydro better, but not enough to trade.
/ Hydro vs Power Reverser #7
The 3000 series have independent implement pumps. The cycle speed on the loader would be independent of the tranny type so going away from hydro in the same tractor would not get faster cycling. As for the tranny itself to each his own but here in the mountains, almost no one goes prt over hydro. The auto hst of which you speak was a rare John Deere flopand I hear not continued.
John
/ Hydro vs Power Reverser #8
If you want to get a John Deere factory cab tractor in the 3020 or 4020 series, the E-Hydro is the only option available. Having used a 4720 cab tractor for loader work, I really like the hydro. It makes loader use so fast.
John
John, Not quite sure I understand your point. I do believe the PS and implement pumps are on the same drive and they are engine speed related in terms of output- for example my loader (300CX) has a lift cycle time of about4+ seconds at 2000 RPM and about 7 seconds at 1000 RPM.
And as for other suggestions (Jeff's) that I could get the results I want by running the engine at high RPM and regulate ground speed by running in A range or with just less hydro pedal pressure, for sure I could. However, IMO, high RPM's equate to wear-piston travel or however you want to describe it. And there is no need for it. Ive got a 500 lb weight block, ballasted tires and the thing loads just fine at say 1600 or so. Again, in my opinion, some sort of driveline disconnect with the ability to override the hand throttle would be a nice feature.
I do think a power reverser would give me that option but I thank you all for your comments- and Leroy, as you point out, its a moot point because if I did go for a cab tractor, hydro is the only option.
thx
/ Hydro vs Power Reverser #10
I may be the one who does not understand the question well. I cannot see why just not setting the throttle a few hundred RPM higher would not solve the problem. I understand the reservation about running the engine faster than needed for other things to get the loader speed you would want but my thoughts on this are:
1. One does not use the loader all the time and adjusting the throttle up for certain uses seems pretty easy to do.
2. These engines run well and are meant to run fairly high RPM's. My experience with the 3 cylinder Yanmar is that the economy is actually a bit better at near max throttle than when running slower throttle and I seriously doubt it would significantly hurt the longevity to run it a bit faster
3. Even with the RPM trade off, the E hydro, in my opinion, has revolutionized the JD compact tractor and in my area it is quite rare to see one without it. My friend and neighbor has had both a 4410 and now a 4320 with ehydro and he retired the first to get the second with over 5000 hours on it. His new machine has over 2000 hours on it, I think, and he has run them both at near FT when doing loader work. I would say 5000 hours is pretty good service both from the tranny and the engine and about all he does with his is loader work.
John M
/ Hydro vs Power Reverser #11
Might as well give up, John. There's a huge segment of the contributors to this forum that will never accept that these small diesel engines are designed to run at full throttle. It's been that way for the 5 or 6 years I've been a member. Apparently the manufacturers and engineers don't know what they're talking about. :D
/ Hydro vs Power Reverser #12
I run mine faster than I used to but my 110tlb fel is so fast I have a hard time controlling it above 1800 rpm. On the 4520 I use the auto throttle most of the time and can leave the engine throttle at 1200 rpm. Wish the 110 had the upgraded cruise that the 4520 has.
You are correct that these small diesels are made to run at faster rpm's than the older engine designs. I suspect too much low speed idling causes more problems than some people know.
/ Hydro vs Power Reverser #13
+1 The engines that are used in the JD 4x20 machines are also in skid-steers, generators, pump power packs, etc. - many applications that run WOT most of the time they are running.
/ Hydro vs Power Reverser #14
Hey guys-looking for an opinion. ........Having said that would I get another hydro or go for a power reverser? I've had a 755 and the 3320 hydro and they have been trouble free. But I hate the slow loader hydraulics-at least with P'Reverser you could throw it in neutral, hit the throttle and improve your loader cycle time.
Any opinions?
I see little to no difference in FEL function (speed) with my JD4300 and engine RPM.
I'd not think twice about going with hydro tranny. It is similar to the old decisions of stick shift vs. hydro tranny in the trucks/cars years back. If you like an extra hand free, then go with hydro. Leave the RPM up and get R dun. :)
/ Hydro vs Power Reverser #15
Guys-........... Now I understand there is a new hydro option that has a foot throttle and a forward /reverse lever on the instrument panel-like a power reverser-but guess what?? They put the brake pedal on the right side and no individual brakes!!! Not something I would ever want.
Then stick with Deere. They have individual brakes useable along with the hydro pedals forward and another for reverse. :)
Should have no complaints then. :D
/ Hydro vs Power Reverser #16
I use my P/R 4120 for snowplowing over the winter. One thing I really like about the P/R transmission in the extreme cold is that it is ready to go at startup no matter what the temperature is. This morning it was -10 and there was no "sluggishness" at all in the transmission. I knocked out the 3 ft drift at the end of a driveway in under 2 minutes and had the tractor back in the barn in 5 minutes. Surely a hydro transmission would have not been close to warmed up in that time (I did have the block heater on for an hour to warm the engine). I know that my lawn tractor (hydro) is very adversley affected by cold temperatures and gets very sluggish when it is cold. There is no way I would want to deal with that over the winter. Unless you are going to keep the tractor is a heated garage, I would recommend going with the P/R for winter use. The multiviscosity hydraulic oil JD puts in the machines these days is a lot better than the stuff used years ago, but the loader hydraulics are still noticably slower in the extereme cold temps. For me at least, loader cycling dont slow me down nearly as much as a sluggish transmission would.
/ Hydro vs Power Reverser #17
Wolc,
The oil in your hydro mower is actually thinner than the oil in your P/R, unless you run Low-visc in your tractor. The trick is pressure and volume. Both the loader and the hydro rely on high volume and pressure, whereas the P/R uses <200psi to fill a relatively small piston. Great transmission.
/ Hydro vs Power Reverser #18
I love engines that agree with my inner Ricky Bobby.
/ Hydro vs Power Reverser #19
LOL. Drive it like you stole it.;-)
/ Hydro vs Power Reverser #20
Oh I do. Everyone knows to stay the **** out of my way when I'm behind the wheel of anything.
During the last snow/ice storm down here, I was doing powerslides with tractors. Fun times. :D
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
CHEVROLET C-40 FLATBED TRUCK (A63291)
CHEVROLET C-40...
2025 32in Bucket Mini Excavator Attachment (A66734)
2025 32in Bucket...
2004 INTERNATIONAL 4300 4X2 S/A  UTILITY BODY (A66091)
2004 INTERNATIONAL...
2015 LONESTAR PRESSURE WASHER TRAILER (INOPERABLE) (A67714)
2015 LONESTAR...
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
