Another Welder Cart
/ Another Welder Cart #1
lostcause
Maine
Since everyone loves a new welder cart build, I figured I may as well put mine up. In my shop floor space is always at a premium, so whenever I build something it has to be as small as possible but still do what I need. Because of this, I wasn't going to find a commercially made cart that would be just what I wanted, so it was time to build one.
I knew I waned a drawer for small item and consumable storage, and I don't have a brake (yet), so I decided the easiest way to get one was to cannibalize an old metal desk. I was able to get one for nothing, but even if not, you can often find an old metal desk in your area on craigslist for anywhere between free and $50. Since it was a whole desk, I now have four more drawers and slides stuffed in the attic for the next bench/cart project. Once I had a drawer to build around, I was off to the races. The pieces I used were not always design choices, but what I had around, plus whatever I could scavenge.
Here's a selection of pieces off the racks along with some cannibalized pieces from the desk.
Top and bottom shelves.
Overall frame put together.
It rides like it's on wheels.
The desk gets put to good use - the top shelf and the drawer are set in place.
Formed up some bottle racks for the back and hacked up an old trailer wheel into some cable wraps. There's also a place to put a rod guard full of electrodes in the bottle rack support.
It's together and functional for now. I need to build a holder for the spool gun, and I need a pull handle for the front of it. I also want to get a couple of rod guards for tig filler and build a similar bracket to hold them on the back. Hopefully I'll find the time to disassemble it and paint it once I get the little details finished too.
/ Another Welder Cart #3
Looks like a great job you did:thumbsup:
Now, get some green paint on it:D
/ Another Welder Cart #4
Great job on the cart. I like the use of old stuff in it, nice thinking. Is that a Syncro180 on the bottom? I have one and enjoy using it. It seems to have a ton of power in DC stick mode.
it's actually an econotig. i bought it used this summer along with the 60cf argon bottle on the back of the cart. i have barely used it so far, but i've always wanted to spend some time getting the feel for tig, plus i wanted dc stick capability. it doesn't have any adjustments to speak of, and it only puts out 130a-165a, but that's enough for pretty much anything i need. very few of us need to weld thick stuff on a regular basis unless that's what you do for a living.
/ Another Welder Cart #6
Nice job on the cart Lostcause.
I noted a couple of things though. First, aren't you afraid your Millermatic might slide off in those high speed turns??:D
I don't don't see the beverage holder on there yet. I must have missed that.:laughing:
I certainly know how you feel about building something and putting it to immediate use before it can get a coat of paint......Been there, done that.
Nice to see you feathered your welds too.
Great job...
Glenn
/ Another Welder Cart #7
Nice job. I wish I had a scrap pile to work from. Well maybe when I retire and am home full time I can pick up some miscellaneous material to have on hand for tasks like yours. Again, great job.
Great job...
Glenn
funny thing you mentioned about it falling off. i had the same worries. right now gravity is working for me, but just in case the laws of physics take a day off, i'm planning on bolting it through the bottom of the welder to the top shelf.
i really do want to paint it soon because with the mix of rust, mill scale, white paint, two shades of green paint, and freshly sandblasted metal, it does look kind of bush league.
the desk and the wheel were the only true "scrap" pieces used. in the past i was able to buy steel at cost through a previous employer. i didn't want to trouble them with nickle and dime orders, so whenever i needed to buy steel for a project i would always order a bunch of extra material - particularly light angle and channel. it was pretty cheap to buy a bunch of stuff to have on hand. most of that was bought ten years ago at a cost of $0.15 to $0.25 a pound. tubes were expensive at $0.35 a pound :) when i have to buy steel now i cringe at the $0.75 to $1.25 per pound prices i get quoted. most of what i have has a slight coat of surface rust on it because i moved about three years ago and it spent a summer outdoors while i worked on a shop at the new place. it's all still new steel in random lengths, it just needs a little wire brushing or sanding before painting.
/ Another Welder Cart #9
Very nice job on the cart. I know putting in the drawer was a bit of work because I did the same when I did my cart but It sure is handy to have that extra space.
You just can't buy them to match your shop so building them is the smart way to go. That will last you a lifetime. Good stuff :thumbsup:
after plowing i went out in the shop and made a pull handle and a holder for the spool gun. i'm not sure i'm content with the rack for the gun - maybe i'll think of something else. other than that i just need to finish welding the sheet metal for the top to the frame (i ran out of wire). maybe i'll pick up some paint tomorrow too.
/ Another Welder Cart #13
I guess this is a good thread to pile on with our weld cart pictures.
This is a cart that I built for my Tombstone and MIG. My intent was to make the center of gravity as low as possible. It moves around in the shop quite easily. I've added a few things to it since this picture, but this is a pretty good representation of it.
You'll have to look hard in the middle picture for the SECOND shop buddy. One of the shop buddies is easy to spot.
BTW, the OP's cart and the others in the thread look great.
i hate to be the one to tell you this, but i think you've got a rat problem :D
/ Another Welder Cart #15
:thumbsup: on the cart and the use of the desk drawer. Funny how the detail of making a holder for the gun takes thought... I still don't have mine sorted out.
/ Another Welder Cart #18
lostcause,
Nice job, but where is the place for that plasma cutter?
/ Another Welder Cart #19
mb diag,
I like the 4 wheel swivel casters, as it gives better mobility than with 2 fixed and 2 swivel. Do they have locks?
Now, all you need is a small, but sturdy work table welded to the side of it.:laughing:
Lost,
Have you thought about mounting the drawer on ball bearings? I have been thinking about adding one to mine to keep my cons in...I have just been trying to figure out the best way to do it.
Lost,
when i cut the desk apart i kept all of the tracks for the drawers, so i just used them. i thought about ball bearing slides, since you can buy them at any home improvement store now, but i figured that matching the lengths would be hard, since desk drawers are a little longer than kitchen drawers. with the cart loaded the whole thing must weigh somewhere around 400lb, so the cart stays in place when opening the drawer, and i already have it pretty full - tig torch & cable, rod holder & cable, foot pedal & cord, 10lb spool of wire, 1lb spool of wire, couple boxes of tungstens, some gloves, case of beer, quart of tequila, pint of raw ether... not that i need all of that in my welding cart, but... sorry, couldn't resist the fear and loathing reference.
as far as the best way to mount it? well, i looked back at 4shorts cart and it looks like we had the same thoughts - mount it however you can, and then mask it from view with side panels. i welded some flat bar and angle tabs to the front and back of the cart and bolted the drawer tracks to them. i have a 1/4" carriage bolt front and rear on each track and so far it seems to have no issue with the weight. my tracks look to be about 14ga steel bent into a c shape. once everything is installed, just add some decorative sides to cover the hardware. i did have one advantage of course, i started with the drawer so i was able to build the cart in the exact size around the drawer. i guess your alternative would be to make a drawer that fits the cart. if i hadn't been able to come up with a desk i was going to consider a small multi-function sheet metal tool. i'm sure if i had a slip roll, shear and brake, i'd find all sorts of uses for it.
2019 Honda WDP30XK3AT 3in. Diaphragm Trash Pump (A66734)
2019 Honda...
16 FOOT TRASH TRAILER (A67714)
16 FOOT TRASH...
Unused 2024 HLA MB48 48in. Bucket Skid Steer Attachment (A66734)
Unused 2024 HLA...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
2014 CHEVROLET CAPRICE CAR (A66091)
2014 CHEVROLET...
2007 Chevrolet W4500 Landscape Dovetail Flatbed Truck (A66736)
2007 Chevrolet...
