New to me JD 1070
   / New to me JD 1070
Hey guys, thanks for the hearty welcome and kudos! I have to say that I'm quite impressed with this tractor. I'm very familiar with most things landscape related (z's and anything that is has to do with grass) but a compact tractor is a bit of a learning curve. I love a new challenge so this will be a nice project. I have a tendency to dive in 200% when it comes to modding my equipment so stay tuned. I also must concur that mine has the high range reverse lockout as well. I'm thinking about looking at disable it as it seems like that wouldn't be too hard to do. I've got two snows under my belt with plowing and the second range works well. On the long stretch of drive I shift into the third range but it's not really all that necessary. It is, however, a pita when stopping and trying to back into my barn and it drops to neutral. Overall I have to say the tranny is quite smooth for a gear drive. I'd love to have a full hydrostatic setup but I'll take the 1070's build quality over this feature for my current needs anyday.
I also like that we have a small cult following! Long live the 1070 club! Lol :) To be honest, there haven't been any surprises. Its quite straight forward and extremely easy to work on. So have I sorted all the "must do's" to ensure a long life with my 1070? Thanks again and I'm happy to be part of the family.
   / New to me JD 1070 #13
Been awhile since I ran my 'ol 970... but, only 8mph? So, you can't go as fast in high range/reverse as high range/forward? IIRC - my operator's manual mentioned the unavailability of high range and reverse; although my 970 had reverse in all 3 ranges, too.
AKfish
Duh.... my bad! Of course, it's only gonna travel 8mph - it's in 3rd gear - not 9th! Brain stuck in Hydro. :confused2:
AKfish
   / New to me JD 1070 #14
Here ya go with the plow installed, more to come.
Great looking tractor...you should enjoy it for years to come!
   / New to me JD 1070 #15
That thing is a cream puff. Gorgeous.:thumbsup:
Thing is, it looks ready to work more than anything.
Enjoy the machine.!!
   / New to me JD 1070
Thanks guys! I'm going to drain the hydro and front axle tonight getting ready for the next snowstorm tomorrow! More pics to come.
   / New to me JD 1070 #17
What is "Fluid Film" never heard of it?
Since it's 18 years old, I would put new cores in the valve stems and carefully check any rubber parts, especially hoses.
Very Nice machine, did you get with the property?
   / New to me JD 1070
Thanks Kenny for posting the link. If you've never tried fluid film you have no idea what you are missing. The stuff blows away any other lubricant/ protectant going. I use it on everything and its made from lanolin so its totally biodegradable. As for the hoses, I checked them all over and they are still in good shape. I did have to replace one this summer due to a pinhole leak from a piece of brush and I purchased a couple extras just in case. I may just replace them all to be safe. I'll also do the valve stems, that is a good idea. I'm planning on swapping the rears to widen the stance and get some additional stability so I'll do this at the same time. I did work a deal in conjunction with the house. Couldn't pass it up when I saw the low hours on it :)
   / New to me JD 1070 #20
If you have other needs for rear hydraulic connections, I keep 2 extra short hoses on hand that hook up to the 4 loader fittings. Yes it means you disconnect the loader circuit, but you already know how easy it is to remove the loader (don't even have to leave the seat).
For examble: a hydraulic top link for a box blade, tongue and header control for the hay mower, dump for the cement mixer, and of course the angle and lift of the snow plow. You can buy the fittings at TSC.
A rear view mirror straps (via hose clamp) to the exhaust pipe very nicely. I also added some rear work/spot lights for those evening snow and hay collection jobs. I put a switch on one of the lights that fires up both of them separate from the tractor headlights and amber blinkers.
My machine was delivered by a JD ag-line service rep who apparently was familiar with the reverse lockout removal. He also liquid loaded the rear tires which is a big help in winter. Mine needed a battery and cables and also had a problem with the voltage regulator terminals (not the regulator but the things that plug into it). Something got too hot.
My dealer told me to NEVER weld anything when its connected to the tractor (like some of the hay or plow attachments). Its tempting and I've heard all the talks about disconnecting the battery and keeping the ground clamp close to the work, but I've been faithful about that with this machine.
BTW: you missed a small dirt spec on the right rear wheel inside flange just behind the air valve. Otherwise it looks pristine...:D
2012 MACK PINNACLE (A50854)
2012 MACK PINNACLE...
DODGE PICKUP BUMPERS (3) (A50854)
DODGE PICKUP...
2022 FREIGHTLINER M2 24FT BOX TRUCK (A51222)
2022 FREIGHTLINER...
2017 Claas Jaguar 860 Forage Harvester (A51039)
2017 Claas Jaguar...
JLG 1255 Telehandler (A51039)
JLG 1255...
2019 John Deere 8295R MFWD Tractor (A50657)
2019 John Deere...
