anyone with this problem please advise
/ anyone with this problem please advise #1
kac6261
john deere tlb 110
Just wondering if anyone has a John Deere tlb 110 and experienced the engine on but the machine won't move. Everything else works the bucket and loader. Starts right away and in A,B, or C range, which I thought that was odd when the brake was already disengaged. Will not go forward or back.
/ anyone with this problem please advise #2
I would check for any loose wires under the machine. Especially around the hydro pedals. Do you have a code flashing on instrument panel?
/ anyone with this problem please advise #3
The only time I have had something even remotely similar is when I had the ABC selector between gears.
Checklist on page 97 of your manual.
/ anyone with this problem please advise #4
I have a 110, but have not experienced that issue. I took a look at the Technical Manual, and one of the first steps in troubleshooting was to test the seat switch.
Give that a look and let us know. Good luck.
/ anyone with this problem please advise #5
After checking your seat switch, look for a flashing light when you press the hydro pedal. The 110 TLB has the e-hydro transmission. Check the flashing light code against the operators guide troubleshooting section. You probably have a potentiometer out of calibration.
/ anyone with this problem please advise #6
She's resolved this problem (another thread). Turns out she wasn't heavy enough to engage the seat safety switch. Her husband tried it and it worked fine.
Here's a link to that thread.
/ anyone with this problem please advise #7
Roy,
I for one, appreciate the update and the link to the other thread. I might have wondered what ever happened??
Thanks
/ anyone with this problem please advise #8
Roy,
Thanks
Thank you...I wish folks wouldn't double post as it does add confusion...no way to stop it though.
1988 23ft Stealth Craft Boat w 22ft Boat Trailer (A61574)
1988 23ft Stealth...
KUBOTA KX033-4 EXCAVATOR (A65053)
KUBOTA KX033-4...
UNUSED WOLVERINE HYD AUGER (A64281)
UNUSED WOLVERINE...
5ft. Wooden Cowboy Statue (A61574)
5ft. Wooden Cowboy...
2022 EZ-GO ELITE...
2020 HYDREMA 922GHM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA...
