3pt hitch hauler
/ 3pt hitch hauler #1
fbenevento
Eldred PA
Massey 2615 4wd
/ 3pt hitch hauler #2
Just build one. I built mine from a TSC carryall frame. All total it cost about $200.
/ 3pt hitch hauler
i find the dump bed on the hauler pretty attractive...seems to be pretty versitile. making one out of a carry-all did cross my mind but it wouldn't dump...
/ 3pt hitch hauler #4
You could lower it to the point where the top link pin is free. Remove the pin then lift your 3ph. It will dump. Not as convenient. But it might work for you.
/ 3pt hitch hauler #5
You can dump it manullly to a point, but if you have a hydraulic toplink (which I do not have) it is a lot easier...
/ 3pt hitch hauler
yeah i don't have a hydraulic top link either.. 1 of the reasons for this would be for hauling wood. i gave thought to the carry-all with plywood or something building a box.. but most only had a 1000lb capacity.. this thing has a 2500lb capacity plus the dump.. and its a 6x4 box.. even without dumping.. i'd bring it up full and set it down on a stand.. and take it off..
idk.. i will probably get one.. i just wish somebody here had some alternatives or experience with this..
/ 3pt hitch hauler
radman. ty very much for that post those are some GREAT improvements. i wonder what that load of dirt weighed.. after seeing your post i am feeling alot more confident about buying it!!
i do wish i had some welding tools to make the same changes. but i'll make do till i get somebody to do them. thank you very much.
/ 3pt hitch hauler #9
you already have a dump box on the front of your tractor. Spend your $ on the welding equipment.
/ 3pt hitch hauler #10
If you buy the tools, I'll come over and borrow them :thumbsup:
/ 3pt hitch hauler
well well stokkeland. they let anybody on here! i thought it was your turn to buy..?
/ 3pt hitch hauler #13
Here's mine on a TSC Carryall. Just built over a pallet on the bottom forks. The back opens up either half or all the way.
/ 3pt hitch hauler #14
I made my TSC carry-all a hand-dumper.
/ 3pt hitch hauler #15
Not sure if you can make it out in my avatar or not, but I've got a box blade on the back of my B7800 with the rippers turned backwards to provide a cradle for a piece of plywood (rear gets supported by the blade) to form a bottom for loading the box blade up with firewood. And if you look further back you'll see I'm towing a truck hood with wood on it. Of course, the loader bucket is also filled! My early days of handling firewood.:)
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
EZ Flow Mod. 300 Gravity Wagon (A66408)
EZ Flow Mod. 300...
John Deere Starter Wheel Weights (A65640)
John Deere Starter...
