Ok whats wrong with this pic
/ Ok whats wrong with this pic
And when I sell a tractor I spend an hour or two going over the tractor pointing out inportant grease fitting and check plugs so all my customers are aware of this.
/ Ok whats wrong with this pic #22
Well maybe he cleans it alot? with a giant water hose:D... Everyone wants something for nothing...
Lol that's true. I do try to b a stand up guy. We are a small dealer and like to know all our customers on a first name basis. Luckily we are n a small town and that makes it easy. But here in the last few yrs we have been getting more customers 2 to 3 hundred miles away so hopefully. We r doing something right.
/ Ok whats wrong with this pic #24
Its a MF1532. There are shipped from Japan but as soon as they reach port and are unload Massey goes threw them and finishes assembling them. When I receive them I have my guys go over with a fine tooth comb which involves pulling the plug on the bell housing and checking for water.
That clears that up well for me. Thanks.
Maybe a casual visit to the guys place to look over the pond?
I did some part-time work for a local Deere dealer, and they had a small CUT (4100) in for a busted rear end casting. Back and forth and finally Deere replaced the casting. I was asked to deliver the repaired tractor.
When I unloaded it, I could see the large elm tree stump, the long chain still on the stump, a good number of cement blocks, and the tire marks. Pretty obvious that he was getting a good run at that stump trying to jerk it out. The stump near the size of the 4100.
He didn't tell the dealer about that part, but I think they knew or had a pretty good idea that it was abuse.
/ Ok whats wrong with this pic #25
The tractor is 2 and half years old and the customer says he uses it everyday.It has 120 hrs on it, not alot for everyday use. I for one think its been under water. What do you think.
I keep staring at these pics and I don't see what everybody else sees... IMHO, the owner has a very good warranty case..
IF it had been underwater, unless he drove it thru a swimming pool, where is the mud/sediment that would have been stirred up by the front wheels that would have driven in first?
Where is the "high water" line in the housing that should be there if it was submerged?
There appears to be a gasket on the engine adapter plate, did IT fail? Was it installed correctly from the factory?
Living in East Texas myself, I can actually see where with the right set of circumstances, this could happen without owner abuse. The high humidity levels, being left outside, the always changing weather from 80 degrees and sunny one day to 35 and raining the next, and intermittent use could cause "thermal cycling" of the air space inside the housing area.. it would just hold the moist air in there and form the corrosion... Is the clutch plate overheated and/or burnt up? OR is the hard shifting due to the release bearing seizure/clutch splines seizing up?
Not saying it DID happen, just saying I could DEFINITELY see where it COULD happen.
/ Ok whats wrong with this pic #27
I don't know PoorMan, A couple of cliches: If your walking down a path and hear hoof beats behind you, you probably think Horses, .......not Zebras! If it walks like a Duck, 'Quacks like a Duck', it's most likely a 'Duck'! Granted, thery're other reasons for that moisture/water, but you've gotta factor in the probablities.........~S
/ Ok whats wrong with this pic #29
...but you've gotta factor in the probablities...
I am not so sure you do.
If 95% of the time this would result from water immersion and only 5% of the time from normal use and exposure, out of 1000 tractors you would have 50 with this problem from normal use.
50 sounds like a lot of customers to deny justified warranty service to.
/ Ok whats wrong with this pic #30
I would have to say the water was in the bellhousing for quite a while. That isn't surface rust. I would guess the water was in there for months or longer. Some of the rust has pitted and that takes a long time to happen. It also appears the bellhousing is sealed with a gasket, so how could water get in. Arround the starter possibly. If that is the case could the water gotten in from pressure washing and had no way to get out.Does the owner regurally pressure was it. Or being left out side could rain find its way in. Don't start doubting your customer quite yet. He may be being truthfull.
Bill
/ Ok whats wrong with this pic #31
He is your customer, and you want to keep him.....Why not just ask him what he thinks did this? If his response is evasive or you sense something is not right, then you will be the better person....If not then some warranty work should be in order, or at least a sharing of the parts to make things right....Frankly I don`t see how any water would have gotten in other than condensation.....If it had been me and I drove the tractor into deep water, I would have gotten immediate service...Tony
/ Ok whats wrong with this pic #32
What about the old tractors that have sat around for years with all kinds of weather changes. Id check out the pond
/ Ok whats wrong with this pic #33
Bill
... or sitting under a tree where the sprinkler waters it every day all summer..
/ Ok whats wrong with this pic #34
My two cents.....
Tractors have a thousand nooks and crannies for stuff like dirt, water, seed, fertilizer, leaves, small twigs, oil, grease, etc, etc to get trapped and settle into. IF that tractor had been submerged to the point that it filled the bell housing with water, there would/should be evidence of rust/small sediment/mud/ in other places where you probably wouldn't normally find such things. For instance, if you unbolted a bracket loose or a body/fender piece and found such evidence underneath it (in places that pressure washing wouldn't normally reach) that would help support the theory it had been submerged (imho).
If no evidence, then all the rust might have been caused as suggested by poorman (post #25). Everyday use (as stated by the customer) can cause a lot of condensation inside it from the constant heating and cooling in a humid environment, especially if a gasket or seal had failed for whatever reason.
I commend jlsmith for giving his customers the benefit of the doubt, and taking them at their word, but as he stated, he shouldn't have to pay for a customers careless accident that messes up a tractor once it's out of warranty. Will be interested in knowing the outcome. Just a wild thought here but maybe you could chat with his neighbors (and maybe the local tow companies) and see if they had pulled that tractor out of the pond?? :laughing: IF he stuck it, he had to have gotten help from somewhere!!!! ;)
/ Ok whats wrong with this pic #35
But "Curly" ,........That's like 'Fun with Numbers!' Agreed that if this is a re-occuring situation, there may be a design problem, but I didn't pick upon that in the Original Post.
~S
And Kebo~ Daily use, should also heated the internal parts enough to boil/evaporate a lot of that moisture out. I think it was 'dunked' ~S
/ Ok whats wrong with this pic #36
My guess is he bought too small of a tractor and decided to water it to see if it could grow. :laughing:
What it looks like to me is he drove through something pretty deep. I don't know how the drain works on this tractor. I don't think it was parked in water for any length of time since there is no water line. But clearly water hit the flywheel and was sprayed all around inside the bell housing.
This is a little off topic but kind of applies. A few years ago I wanted to update the list of cell towers on my phone. I went down to the Verizon store to do it. There was a girl in front of me who's phone died. The guy asked her if she got it wet, she of course said no. The guy removed the battery cover and showed her the sticker underneath. It's printed on litmus paper. If it gets wet it changes color. Even when the guy opened up two other phones just like hers to show her how it should look she kept saying it didn't get wet.
If the guy can't be honest with you about his tractor then I guess you take the high road and live with what ever he chooses to do. If it's not covered I would be upfront with him as to how much it will cost and the options, say just cleaning things up and getting them working again vs. fixing it right for years (unless he feels the need to keep driving through deep water) of service.
/ Ok whats wrong with this pic #37
my opinion waranty work is for manufactured defects not water in a bellhousing that sounds to me like a insurance claim. that is why so many big manufactors are going broke because every body wants waranty work when it sound be an insurance claim. i would see if they have insurance on the tractor and if so have them file a claim if not they should eat it.
/ Ok whats wrong with this pic #38
whodat526 said:
my opinion waranty work is for manufactured defects not water in a bellhousing that sounds to me like a insurance claim. that is why so many big manufactors are going broke because every body wants waranty work when it sound be an insurance claim. i would see if they have insurance on the tractor and if so have them fill a claim if not they sound eat it.
I agree 100% that does not look like a manufacture defect.
/ Ok whats wrong with this pic #39
Could rain water be getting in from the top side?
Do most change fluids and filters at 120 hours?
/ Ok whats wrong with this pic #40
I had an old Chevy station wagon years ago that had water dripping from the bell housing. Turned our to be a leaking freeze plug on the back side of the engine block. Couldn't see it until I removed the flywheel.
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
Bobcat Skidsteer (A60352)
Bobcat Skidsteer...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
Case SV280B (A60462)
