looking to buy
/ looking to buy #41
This morning at temps around 35* I started the tractor without the normal glowing time, to see if in fact this position of the switch is glowing the plugs, and it must do... because I turn to start the tractor right away and it took about 6-7 seconds to start and a large puff of smoke came from the exhaust,
so it will crank and run but takes longer to start, typically as I said before I would turn the switch on for around 10 seconds and then on to start and it would start right up in a matter of a couple turnovers, so I'm thinking my assumption of this type of ignition switch has the glow on the on/run position:thumbsup:
what did you find out Carey?
/ looking to buy #42
My first failed attemts were my fault probably, cause im use to it catching on the first or second stroke, which is instantly after i let the compression release go, so being use to this i let the key go after the normal split second of cranking after i release the compression release lever. so i never cranked it really for more than 1 or 2 seconds with it after the compression release. Had i not let it go im sure it would have cranked the first time.
/ looking to buy #43
I'm confused:confused:. Your profile says you have a YM1700. If so, you do not have glow plugs, other than TS, and it is, (should be), active only in the TS switch position.
/ looking to buy #44
DND just ran out before it Rains again over here. Yes I showed power to the TS when I Ran my Decompression or in Start 10.5 V. And 12.3 in Acc. I thought I would but wasn't sure. Still CRS. sometimes :confused2: getting better though.
Carey
/ looking to buy #45
I might have confused my self here on this statement, of corse it is TS not glow plugs, I must get a manual some day and read up more on the terms used for the technical parts of my tractor:D
and about the TS position which way are you saying suppose to activate or heats what ever it heats;) in order to start the engine? there is simply No turning my switch to the left either.
/ looking to buy #46
Do you have a clutch safety switch? (It interrupts the cable to the starter unless the clutch is depressed.) If you do have the clutch safety switch - put the transmission in neutral then turn the key to Start with the clutch engaged. This should send power to the Thermostart but not to the starter. After 10 ~ 20 seconds release the clutch to allow power to the starter too.
/ looking to buy #47
Are you sure about that? I never tried it, but I can't see it in the schematic . Unfortunately, I have neither the tractor nor the manual handy.
/ looking to buy #48
i dont think any of these yms had this feature? I know i have accidentially cranked it in gear for a second befor i realized it. Luckily it was still strapped down to the trailer and did not go anywhere but about 3 inches (i think the front strap had been loosened already, but cant remember).
/ looking to buy #50
FWIW the YM2500 has one also.;)
Carey
/ looking to buy #51
Proved me wrong, i guess yall cant run over your self starting the tractor while off of it?
/ looking to buy #52
YM2001 has clutch safety switch as well. Can't start the tractor at all off it, unless you hold the clutch down far enough by hand to disengage the safety switch, still not recommended.
/ looking to buy #53
I was going to say that I'm sure my 1700 doesn't have the clutch safety feature although have heard of what your talking about California, on other tractors, I usually when putting my tractor up I'll shift it into neutral drop the bucket and box down, lock in the e-brake and then shut it down and turn the switch off and I do this religiously, although one time I was working on connecting the hydraulic line to the reservoir having to move the shifter out of my way, when I was through I went to start the tractor and luckily for me the loader bucket and box scrape was down to stop it enough for me to realize it was in gear, as I said this tractor can start up very quickly after the 1st initial start but I didn't give it a chance, and really should be a safety device such as you mentioned on any tractor, Heck there is one on my wifes Cadet lawn tractor,
/ looking to buy #54
you could always add the safety feature to any yanmar im sure. anyone done that?
/ looking to buy #56
I doubt thats a big sales part for the money Maybe in texaco. Here's a cheap and easy fix. Connect the wires together :p I ALWAYS SHAKE My GEAR SHIFTER To Make sure it's in Neutral. And With Good parking brakes applied it shouldn't move or even start for that matter.
/ looking to buy #57
Safety Start Switch. Left-center in the schematic. Black/white wire tracers. It is a solenoid the size of a golf ball mounted above where the clutch rod goes into the bell housing, and the clutch linkage includes a tab to push the plunger up.
Maybe it's just on US Yanmars? I thought it was in the UTDA spec.
/ looking to buy #58
No no no guys, I suspect ALL Yanmars were all born with the clutch safety switch, (some have been by-passed), just never heard of the thermostart being activated in the start position when the clutch is disengaged, (switch open).
/ looking to buy #59
YM1900 does not have a clutch safety switch. Doesn't show one in the electrical diagram. The only safety item this tractor has is the operator and sometimes I am not sure about him:D
/ looking to buy #60
Sorry normde, it is not my intent to try proving your wrong I'm sure you know way more than I do when it comes to Yanmar tractor, :cool:
its I'm just trying to come up with a logical answer for both of us, I cannot argue the fact that my ignition switch might have been replaced in the past, only that I know it will only turn one way, ( to the right ) and that it will start faster if I let it sit on run for 10 seconds before attempting to start it,
here is something I found from Hoye tractor parts, this is to be an ignition switch diagram for my 1700
2005 INTERNATIONAL PAYSTAR 5600I HYDROVAC (A67714)
2005 INTERNATIONAL...
2005 CATERPILLAR TH460B TELESCOPIC FORKLIFT (A65056)
2005 CATERPILLAR...
Unused 2022 Continental Belton Auger Tractor Attachment with Bits (A66734)
Unused 2022...
1991 American Pride APE2-6 Electric Cart (A66738)
1991 American...
2018 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A67714)
2018 INTERNATIONAL...
CLARK FORKLIFT (A63291)
CLARK FORKLIFT...
