Brother having tractor problems need suggestions.
/ Brother having tractor problems need suggestions. #1
kub32guy
north eastern Pa
kubota L3240 Dt
About seven months ago my brother came up to PA to visit,(he lives in Mississippi). While here he bought a 80's International 244. It ran very well when he was here, but line coming off the injector pump was leaking, looked to be a o-ring. He took it home and fixed the leak, but every since it has been running very rough if he can get it to run at all. I suggested bleeding the system. He said he tried cracking the lines at the injectors, but it didn't help. He also said he tried a "bleed screw" on the injector pump, but no luck. So this is why I asking if anyone out there has any dealings with this model tractor and has any suggestions. By the way, it has a Mitsubushi engine in it.
/ Brother having tractor problems need suggestions. #2
My guess is it still has air in it. Takes quite awhile to bleed air out. Also, there are some hidden filters in some fuel lines. I would start all over by removing the fuel line from the injector pump and verify he has good flow. If he does go though the bleeding process. Tell him to remove all filters and fill them with clean fuel and preferably replace with new fresh filters. Then look for a bleeder screw on the filter housings. Some tractors have hand primer pumps on the injector pump itself to aid in the bleeding. Last resort crack the injectors as you told him to do.
The info I have provided is general. I have no familiarity with that tractor so take it for what its worth.
Chris
/ Brother having tractor problems need suggestions. #3
I agree that it sounds like it is still getting air in the fuel line. I would have him go back to the last thing he fixed and start looking there. I changed a fuel filter and my tractor started running terrible. Traced it down to a leaking fuel bowl O-ring that letting air into the fuel mix. Maybe he installed the wrong size O-ring??
/ Brother having tractor problems need suggestions. #4
My first thought was also that he still has an air in fuel problem. Since the leak he fixed was caused by an O-ring, that means it was on the suction side of the pump. If he doesn't have a good fit on the O-ring or it's not the right size, he could be sucking air there.
Mark
/ Brother having tractor problems need suggestions. #5
TraderMark has my vote because you stated that the injector lines were bleed, so by the process of elimanation the O ring line is either suction or return. Fix that again then worry about the air. But once it runs that means it is pushing fuel through and very quickly the air will be purged.
Craig Clayton
Thanks guys, I am going to give him a call with your suggestions. I'll keep you all updated.
/ Brother having tractor problems need suggestions. #7
G'day can you show us a pic of where he fixed the leak is it possible that something may have not been put back together properly? If it is running then
they will usually bleed the air out themselves. Not trying to be smart just throwing up an idea
Jon
Jon
I called him yesterday, he was at work. I directed his wife to the site so he could read the suggestions when he got home. Still didn't talk to him yet. I am also trying to get him on the site, he is a little computer hard-headed.
/ Brother having tractor problems need suggestions. #9
Might try calling Bill at Valley Power . He has a toll free number and can help you with this particular engine.
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
2012 WESTERN STAR 4900 SB MID-ROOF SLEEPER (INOPERABLE) (A63569)
2012 WESTERN STAR...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2011 Bobcat T650 Compact Track Loader (A64047)
2011 Bobcat T650...
John Deere 6125R Tractor (A64047)
John Deere 6125R...
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
