PTO powered bandmill
/ PTO powered bandmill #1
tuolumne
Gold Member
Danby Vermont (soon)
I have posted a similar thead in a DIY bandmill forum, but TBN sees way more traffic and I have always valued the input from here very much.
I am looking to build a sawmill to turn my pasture/field clearing project into saleable (and usable for me) product to help support our homesteading efforts. I do not intend to have this be a portable sawmill at this point. I am looking to build something that looks like a Linn Lumber cutter head as on many home-built mills, but fixed rather than moving. Help me explore why are others not using this power option on small mills. This will be a horizontal bandsaw mill, not a circular saw.
For me, it seems simplest to power a stationary cutter head from my tractor PTO and thereby avoid another engine to maintain. Also, I have 37 HP available and I think I could maintain acceptable torque at lower RPMs to save on fuel and noise. Tractor hydraulics would also then be availabe for future carriage drive motor, hydraulic turner/clamping system etc. I could have a gearbox in the carriage that moves up and down within normal limits of 3PH movement for the drive shaft. Why haven't I seen others doing this? Please add to my pros and cons (or refute them!) I will edit this post to keep all pros and cons current at the top of the page. You'll notice that most of my cons have an argument noted afterward, so you can see that I am personally biased.
Pro:
-Already have an engine with lots of HP and hydraulic function.
-Stationary cutter=stationary sawyer.
-Log weight on moving carriage is enough to preven vibrations/fixed cutter head wold be more stable. Likewise, band carriage is fixed to rails.
-Log load and board stacking on same side of machine
-Variable band speed using engine rpm depending on log, moisture etc.
-Saw under shed with engine outside for fumes
-Sawdust all in one pile
Con:
-Longer rail bed to accomodate moving carriage for logs (more steel): seems simple enought to build, It would need to be about 22' long for a 9' carriage to handle 13' logs with a bit of cantilever and works in CAD so far
-Sawdust will be headed toward tractor with drive wheel on that side; it could be directed a bit I imagine; better than scattered along the whole rail on the operator side like most portable mills.
-Band always running? I could rig a switch to the operator area from the tractors' "operator presence" to kill the PTO in an emergency.
-Tractor must be disconnected to load logs; perhaps 8 at a time on a loading rail. I need a break from sawing anyway.
Thanks!
/ PTO powered bandmill #2
Wow- sounds very ambitious! Don't know anything about mills, but I'll be watching this post (I have a lot of trees I'd like gone on my land...). Thanks in advance for future updates. WBB in NH
/ PTO powered bandmill #3
I buy quite a bit of lumber from a local farmer who has a circular saw mill which he runs off a 60 hp Ford tractor. Even it doesn't seem to have any too much power, as I noticed the rev's dropping while he cut 12" boards off a pine log the other day.
The pros:
A pto-driven circular saw mill is fast and seems to run for quite a long time without significant maintenance.
Fuel cost per hour to run the mill is significant, but for low-value logs it's a cheaper way to turn them into lumber than the labour-intensive band mill.
The cons:
It takes up a lot of space and equipment. Two tractors are needed at a minimum, one to run the pto and another to handle the logs. Both are over 60 hp, but this is a farming operation where there's no shortage of power equipment.
This mill isn't very accurate. The precision control of board thickness is a major plus for a band mill.
A fixed-location band mill would require much less power than a circular-saw unit.
Another local mill has a home-made resawing unit set up much as you describe, driven by a 40(?) hp Massey-Ferguson. The pto shaft gets in the way and is a safety factor, in my opinion, though the narrow kerf saw has been a profit generator for many years for Ralph Oosting of Smiths Falls, Ontario.
The other mill where I take my black walnut is an early Wood Miser gas-powered band mill set up inside a shed. Its owner does an excellent job of sawing, though production is slow and thus it's quite pricey for low-value stuff like basswood.
If I wanted a personal mill and had access only to one tractor, I'd look until I found a Wood Miser owner ready to retire and buy the thing. It's safe and precise, if not overly productive. "Two outa three ain't bad."
...The pto shaft gets in the way and is a safety factor, in my opinion...."
Said to a fellow who got tangled up in a PTO shaft once! All activities will take place on the opposite side of the mill from the tractor.
Also, as I clarified in the original post, this is to be a horizontal bandsaw mill. Most portable versions run something from a 10-30 HP dedicated engine on the size mill that I am considering.
/ PTO powered bandmill #5
Lindsay's Technical Books at one time they had a book on the old type of saw mill
but if your going to try that I think I would consider building a normal type of band saw mill, and then just use Hydraulics to power it, yes a few hoses would be needed, but it would save a hole lot of problems in redesigning the unit and you remove the hazard of the PTO shaft, if your tractor does not have enough Hydraulics to operate it then consider a PTO powered pump, but then you can make a entire Hydraulic operated unit,
one of the considerations I had when I built mine was how heavy a log is and I built mine on the ground, (it sets flat on the ground) so logs do not need to be lifted, just rolled, on to the bed,
with Hydraulics you have a valve, and no need of a clutch, of any type, and there are a lot of plans out there, little to engineer, or redesign.
below is what I built nearly 20 years ago, no it is not hydraulic powered, but would be simple to power it with a hydraulic motor of the proper type and RPM.
put up a line with a few rings on it so the hose does not get tangled,
you can see how the bed is on the ground,
I have looked at the hydraulic option a good bit. This would involve a number of extract components that would raise the price over the PTO option.
Now that I think about it, the PTO switch on my JD3520 is electronic. It seems feasible that this could be switched from the sawmill operator station and have a pigtail to plug into the tractor.
/ PTO powered bandmill #7
Except that the RPM of the tractor will have to be reduced before you engage it, and brought back up after it's running. It would however work as a good emergancy kill switch.
This has always been my practice with the wood chipper. With my rototiller, I have turned the PTO on and off while at full RPM. Is this a problem? The rototiller seems to have almost no startup load when it is out of the ground. Like the rototiller, a bandsaw would have a very small startup load compared to a wood chipper. What is the reason behind this practice?
/ PTO powered bandmill #9
That is NOT good for the PTO clutch!
From the manual:
Engaging Rear PTO Only
1. Sit on operator痴 seat.
2. Stop machine motion and push all PTO engagement knobs to the disengaged/off position.
NOTE: The starter will not crank if the rear/mid PTO knob is pulled to the engaged/on position. If the operator leaves the seat with the engine running and the rear/mid PTO engaged, the safety interlock system will stop the engine and all implements.
3. Reduce throttle setting to 1500 rpm.
4. Move the PTO selector lever to top/rearward position for rear PTO only.
5. Pull the rear PTO engagement knob to the engaged/on position to engage the rear PTO.
The instrument panel PTO engaged light will illuminate when the rear PTO is engaged.
6. Adjust the hand throttle lever forward to the desired speed for implement used.
NOTE: The PTO marker on the tachometer indicates engine speed for a standard 540 PTO.
Disengaging Rear PTO
1. Adjust engine rpm to low idle.
2. Push all PTO engagement knobs to the disengaged/off position to disengage the rear PTO.
The instrument panel PTO engaged light will go out when the rear PTO is disengaged.
/ PTO powered bandmill #11
What is the layout configuration that you are thinking about for the tractor PTO and horizontal cutting bandsaw?
By this I mean would the log be parallel to the rear axle of the tractor or would the log be perpendicular to the tractor rear axle?
When you say stationary, do you mean that the sawmill will only be operated in one location or that the sawmill will be portable and operated in different locations but that once it is setup the bandsaw will be stationary?
The log will move parallel to the rear axle of the tractor. I would mount a right angle gearbox on the saw carriage. I intend the mill to be used just at my home, possibly in an open shed. (built from home milled lumber of course)
/ PTO powered bandmill #13
Do you have a sketch of what you have in mind?
Have you operated a bandmill sawing logs, or a circular mill sawing logs?
Been around a Belsaw mill or operated one?
Just getting an idea where you are at. Wish you well with this plan.
Here is a quick AutoCAD of where I'm at. I just a quick line trim and turned off hidden lines to give a sense of where things are. Lots of details are missing! The log would ride on the carriage towards us. The tractor would be stationed on the left and plug into the gearbox shown. The operator, log loading and board removing would happen on the right.
/ PTO powered bandmill #15
If I actually had any trees worth sawing, I would definitely buy a swing-blade mill, such as the Lucas sold by Baileys. This is the type of mill that uses a ~16 inch diameter circular saw blade, and the blade can swing 90 degrees. So the husk (engine and gearbox and blade assembly) travels down the track one direction, then the blade swings 90 degrees, and the husk returns up the track. Each round trip produces one plank. One person operation, but productive enough to keep three guys busy. They are WAY more productive than bandmills of the same horsepower, very accurate (no wavy boards due to heating up and expanding bandssaw blades), and of course the circular blade is tougher than the bands so you spend no time changing bands that dull or overheat. The blades are about $150 each, have five giant carbide teeth, can be sharpened right on the machine with the included sharpener which also sharpens your chainsaw, are completely rebuildable (all new teeth brazed on) for about $50, and can last a lifetime. I have run this mill for days at a time, and seen bandmills run, and there is no comparison in simplicity and productivity (how does 900 board-feet per hour sound!?). They are available used for around $5500, on an on-line sawmill exchange website which I can't seem to find right now. Or new from Baileysonline.com of course, for about twice that.
Bailey's - Complete 6" Lucas Model 618 Portable Sawmill Package
Be sure to watch that first video on that page, it says it all.
/ PTO powered bandmill #16
The problem I see is to move the log will require sturdy carriage and rails of twice the length of the log. You will need quite large space in your shed. You will be better of it the log is stationary and the band saw moves. You will spend less material if you install shaft (in example square tube or rod) long as the mill than build beefy carriage. At 540 rpm imbalance shouldn't be big problem. Also doing it this way the mill will not have to be positioned parallel to rear axle but in line with PTO shaft. I think it would simplify the saw especially if the band runs vertically. To move the saw along the log I would use electric winch (in example made of an electric drill) because its speed is easily adjustable.
/ PTO powered bandmill #17
I built a stationary mill a few years back(linn mill)its a160 an i power it with a 12 hp motor works great.good luck with your project.I am cutting lumber for a boyscout camp I am building on our property an also timber for a timber frame addition ill be adding to our home.
My mill pictures by falcon6667 - Photobucket
Army Grunt
/ PTO powered bandmill #18
Looking like a good basic plan.
Wondering about your previous experience with sawing logs, with log carriages, and with bandsaws. Any hint for us? :)
None. Well, I've milled a bit of lumber with a chainsaw following a 2x4. I also have a 5' sled for my woodworking bandsaw that I've used to mill lumber up to 12" diameter or so. We're looking to scale up a bit!
/ PTO powered bandmill #20
Then my advice would to at least get more information/experience/knowledge about the carriage systems used on circular sawmills. More info on what makes a bandmill tick-tock would be a good investment as well. Just so you don't have to reinvent the "wheel".
I think your plan has merit. But I can see some headaches too. But you may have all that covered in your final plan.
UNUSED ATS EPC40 ELEC.PLASMA CUTTER (A62131)
UNUSED ATS EPC40...
DURA-CAST PRO-LICK TANK (A62131)
DURA-CAST PRO-LICK...
UNUSED RAYSKY RM87-96 MOBILE TOILET (A62131)
UNUSED RAYSKY...
2024 John Deere 8R 370 Tractor (A63109)
2024 John Deere 8R...
2013 Bomag BM-211D Vibratory Soil Compactor (A61567)
2013 Bomag BM-211D...
207283 (A52708)
207283 (A52708)
