Easier winter starting ?
/ Easier winter starting ? #1
WilliamTO-35
Northeast USA
1955 Ferguson TO-35
My neighbor had an early to mid 1970s John Deere diesel tractor. It may have been a 4030, or similar model of around 80 to 90 hp. In the winter, it was a bit hard to crank and start, as are many diesels. My neighbor swore that he could make it crank faster and start sooner by turning the steering wheel back and forth just a little while cranking. He thought that it somehow unloaded the power steering pump a bit and lessened the load on the starter motor. Is that a known phenomenon, or just his imagination ?
/ Easier winter starting ? #2
I never heard of that one. I would think it would make it worse. JD did/does have a de-stroking kit for their tractors which made starting easier.
/ Easier winter starting ? #3
Your neighbor's starting theory doesn't ride well on the "logic train" - IMO.
Working the steering wheel back and forth would place a load on the power steering pump and therefore increase the drag on the starter - making the tractor harder to start.
It would be a nearly identical situation of pulling back on the hydraulic lever to elevate the loader bucket at the same time as engaging the starter to fire the engine!
Bad, bad - battery math!
Much better to install one of those big, circulating tank heaters - all 1200 watts worth!
AKfish
/ Easier winter starting ? #4
If the fellow believes and the tractor starts what the heck.:D
Some of us may prefer other Starting Aid methods.:thumbsup:
/ Easier winter starting ? #5
I have a hard time understanding how anybody could even turn the wheel on a P/S equipped tractor with a dead engine, especially in cold weather. Quite an imagination, but if he imagined it worked, that's all good.
/ Easier winter starting ? #6
I had a 1969 gas 3020. Yes, it is true. Turning the wheel while cranking does make it turn over faster. Not twice as fast but noticeably faster for sure. I think it has something to do with by-passing the hydraulic pump.
Maybe a Deere mechanic will help explain.
/ Easier winter starting ? #7
The reason this actually works is due to the closed center hydraulic system. As soon as the engine starts cranking, The hydraulic pump attempts to build 2300 psi. When the oil is warm and relatively thin, the load on the starter is not that great. When the oil is cold it is a different story. Turning the steering wheel opens the circuit to steering motor and bleeds off some of the pressure, causing engine to crank faster.
/ Easier winter starting ? #8
I learned something today.:thumbsup:
In my area, percolators are the standard for cold winter starts.
/ Easier winter starting ? #9
Well, I learned something! Thanks.
I was just about to try it on my JD 110TLB - guess with an open center hydraulic system it would just bog my starter down.
Always pick up something on this site - that's why I keep comin' back!
(What happens if the engine doesn't fire right off and the hydraulic line and steering cylinder are filled? System start building pressure?)
AKfish
/ Easier winter starting ? #11
Thanks for sharing that with us...I really never understood (or cared about) the difference between open center and closed center hydraulic systems, but your information made me research that. I never log into TBN and log off again without learning something new in the meantime, which is why I enjoy the forums so much.
213120 (A64276)
213120 (A64276)
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
1995 Kenworth W900 Studio Sleeper (A62613)
1995 Kenworth W900...
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
