rpeter
Hate to say it but I kinda agree with Duffster. If you have small kids then you can not leave it unsupervised.
I'd like to keep it running if I run to the store or something but I guess it is not out of the question to shut it off etc.
The tractor lives in the garage therefore no one can climb on it and drive away.
I wonder if I could leave it running in the garage and hook up an "extended" exhaust to route the exhaust outside.
Too much work lol. After talking with the wife it looks like we will be looking into a whole house generator with an auto transfer switch. I'm still going to keep the PTO generator as it will work well if I have to power the welder away from the house.
Thanks everyone and Merry Christmas!
Is this a serious question?![]()
There. You fixed it.
2 things I will never understand....Liquid in tires and a pto generator for a house.??
Call me whatever you want. I will never understand those 2 things.:confused2:
There is a caveat with a PTO generator. Unlike many dedicated household generators, a PTO generator doesn't have load sensing to throttle up the tractor engine when more power is needed. So if you have kids turning everything on at once, the furnace igniter and forced hot water pumps, the dryer, dishwasher, freezer, washer, AC, and the well pump, you're going to get a massive dip which won't do your appliances' motors, or your electronics much good. What I would recommend with a PTO generator (or even a cheaper stand-alone generator without that load sensing) is a smart UPS/power conditioner that can store power in batteries in the unit and deliver a level and smooth cycle of power whenever you get spikes in demand.
Like I previously said.you have 2 parts to secure. 1 pto shaft and generator. 2 controls on tractor.
Shouldn't be a problem with a properly shielded PTO. If you are that uneasy about an unsupervised running tractor then the tractor shouldn't be running unsupervised.
There is only one right answer. A tractor is not designed nor intended to be left running unattended. If you need something to do that, buy something designed to do that, like a stationary generator with the appropriate safety features.
Really?
You should tell that to the thousands around here that use their tractors for real work.
