Pole barn ceiling advice
/ Pole barn ceiling advice #11
I used 29 guage in 26' sheets. Joists are 40" OC & metal is perpendicular. I have 4" rigid foam on top. MikeD74T
/ Pole barn ceiling advice #12
I would use OSB personally. It would add strength to the structure and won't sag. Plus I think it would look better.
A decent 29 ga will have a similar strength as a 7/16 OSB.
29ga spanning 8' without purlins?????? Says who????
I personally would not want to do it. 4' MAX for purlin spacing.
ME!
We do it all the time. All of the name brand buildings that I have seen do it as well. Works very well.
/ Pole barn ceiling advice #13
ME!
I know I wouldn't want to be up on a roof walking around with 29ga spanning 8'.
Just to be clear, are we talking about the same siding??? I know some of the stuff you see on commercial buildings has MUCH larger ribs, thus allowing it to span further. I am taling about your everyday run-of-the-mill ploe barn siding. And the commercial style also usually comes in thicker guages.
/ Pole barn ceiling advice #14
We are talking about ceiling use not the roof. And no you can't walk on it.
Yes, just the standard 29 ga "barn tin".
/ Pole barn ceiling advice #15
Well now that makes a lot more sense. Just as long as you dont have to walk on it while insulating, it would be alright.
/ Pole barn ceiling advice #16
We just take a 10' plank or two to walk on.
/ Pole barn ceiling advice #17
I put white metal in my shop on the ceiling and walls in '94. Still looks like new today, other than some dust. At that time, metal was the best buy.
I am also having it put in my new shop. Back then it was called "cover sheet". The protective sheets they put on top, to prevent your siding from getting scratched during shipping.
Today they call it "liner panel". I'm thinking it is running me $1.39 per sq. ft. But knowing it will be a one time deal,and no maintenance, worth it to me.
Also using this insulation Insulation for Less : Prodex : Reflective Insulation : Pole Barn Insulation : Metal Building Insulation : Bubble Insulation About 1/4" thick, double foil faced. I will be getting the 4' wide rolls, and using button fasteners to hold it just enough, until metal is fastened over top. I was told it had an insulation value of 15. something.., and it does..., but only under a roof, and in reflective purposes.. On walls, and ceiling 5. something..
Still.., should do as well, if not better than the 1 1/2" styrofoam I have in my old shop ceiling, and cut to fit between wall purlins. The waste oil furnace uses approx. 450 gallons of used oil per year, to keep the shop a comfy 65コ.
2009 FREIGHTLINER CASCADIA (A60736)
2009 FREIGHTLINER...
Kubota Snow plow with subframe
Kubota Snow plow...
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
1988 FRUEHAUF TRAILER OPERATION FUEL TRAILER (A60736)
1988 FRUEHAUF...
EXCAVATOR QUICK DISCONNECT (A58214)
EXCAVATOR QUICK...
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
