Battery Tenders......
/ Battery Tenders...... #1
Shmudda
Gold Member
Western Pennsylvania
Kubota BX24
I'm looking to purchase a battery tender for my BX24. I know there are some out that will cook the battery because they never shut off based on the battery's charge level. I don't want one like that!
I'm looking for one that will monitor the battery and then automatically cycle itself off and on based on the battery's level of charge.
What suggestions do you have?
Thanks,
Craig
/ Battery Tenders...... #2
You might want to look at a "Solorgizer", they are pretty slick (the military uses them). Mine is solar and requires no power which is great for use down at the barn (where there's no power) and they also make ones that plug in.
They are a battery maintainer vs a charger. Basically, they keep the battery charged and desuflinated which makes them last up to 3 times longer. You can get them on ebay for waaaay cheaper than the online sellers...
/ Battery Tenders...... #3
Battery Tender Is the brand Name you want, been using them for years on My Harley and both of my Kubota's.I start them in December and run them till about April, they work great and never over charge.
DevilDog
/ Battery Tenders...... #5
I second the motion on the Battery Tender brand- use one for my boat/ atv / tractor, as needed. It will save any battery that's able to be saved- and ones that can't are dead for good and need to be replaced.
/ Battery Tenders...... #6
Wallyworld had the 1.5amp charger/tender Schumachers on sale for $20 last week, may still be, check in their battery department. Deltran also makes a great tender. Most of these monitor the battery and supposably 'do no harm'. I have one running on all my summer vehicles all winter, and believe in them.... Especially on the two big honker batteries in my Dodge/Cummins....
/ Battery Tenders...... #7
I bought a few from HF for lawnmowers and spare cars etc and so far they have been fine and on sale they were less than $4 regular $7-8 I think.
/ Battery Tenders...... #8
Make sure you get a "float" charger and not a "trickle" charger. Trickle chargers source a small amount of current constantly, and can overcharge a battery if left on too long. Open-circuit voltages should be somewhere around 13V to 13.5V.
The little $10 HF 200mA float chargers (that are often on sale for $5) work quite well - charger I have a half-dozen of them running on batteries in storage (including one on my Kubota L4200) right now.
JayC
/ Battery Tenders...... #9
I will third the Battery Tender brand. I use one on everything I don't start every few days.
-Bill
/ Battery Tenders...... #10
JayC
Yup exactly right those are the ones I refer to the HF Chicago electric power systems item # 42292. I happen to have a box right here to look at they are working real good so far a good value seems like for chinese junk!
/ Battery Tenders...... #11
I use the same ones, they've worked for me for years! They are not going to charge a "dead" battery overnight, that's not what they're made for, but they keep them "up" without overcharging! Also have a couple of John Deere "push mower" chargers that do the same thing, made very similar to the HF ones. ~~ grnspot110
/ Battery Tenders...... #12
DevilDog
X4 end of story...
/ Battery Tenders...... #13
i also just bought a bettery tender (brand) for my '10 polaris sportsman. it seems to be doing the job extremely well. i recomend them whole-heartedly
/ Battery Tenders...... #14
The Battery Tender "Plus" I've been using for a couple years on my late wifes Crown Victoria. .... paid about $50 for it thru a catalog source. Then I bought a Schumacher from a different catalog source....paid $42 for it. Yesterday I saw the Walmart Schumacher for $21. Now, you all say HF has something for $5. What a spread! :confused: Anyway, I use the Tender and the Schumacher by rotating them between two automobile and two tractor batteries ( I bring the tractor batteries into the garage for the winter....but have to reinstall them as needed).....I always do things the hard way.:eek: Oh yeah.....I saw a "Kubota" labeled maintainer at the dealership .....it was $60. They are all made in China.....where else!:(
/ Battery Tenders...... #15
I rotate one Battery Tender Plus amongst 3 bikes, 1 plow truck, and 1 tractor. Occasional charging is really all that is needed. I've been doing it this way for years with excellent results.
/ Battery Tenders...... #16
x5 for Battery Tender brand. Got the jr. model around $25. Put the ring connectors on the batt, ran the 2 prong plug outside the batt compartment to right in front of the cab. Hook up the tender and put it on the tractor step so I don't forget to unhook it. Has LED light that tells you if you are hooked up right, batt is below 80%, or if a maintenance charge is going in.
/ Battery Tenders...... #17
Battery Tender brand seem to be better built with larger gauge cables and come with permanent battery connectors and clip on style connectors. I use these for my tractors (permanent battery connectors) which are in a barn. For the classic cars and motorcycles in the garage I use cheaper Schumacher and Sears models.
/ Battery Tenders...... #18
Another vote here for the Battery Tender brand. I have 4 of them and I am looking at getting a fifth. Eventually, I'll have one for each piece of equipment. No more rotating.
/ Battery Tenders...... #19
Hey guys merry christmas,
My wife got me this for my two atvs.Ive got a couple questions i cant find answers to in the instructions.
1] It has screw mount holes on it to hook it to something.Can i bolt it upside down to the ceiling in my atv shed?
2]It says dont mount it above your battery.Does that mean dont put it near or on top of ,or can i not do a ceiling permenent mount?
3]it says plug in the 110 volt plug last? WHY?If this is the case ill need to put a switch ahead of the outlet in the ceiling
Ijust thought having it perminant overhead the atvs ,with some hooks to hang the cords on would be convienant.It came with battery clamps or quick disconnects,ill use the latter,for a perminant connection for the machines.She bought it new on an ebay site,i have no idea how much.Now i have to buy her one for her two atvs for her birthday:thumbsup:note alot of women want girly things ,MELINDAS passion is her atvs:)
Any advice on a nice perminant install is wanted
ALAN
/ Battery Tenders...... #20
1) Probably not a good thing to mount it that close to the ceiling because it gets hot up there in the summer.
2) They want you to keep it away from the corrosive enviroment near the battery which is not good for electrical/electronic stuff..
3) Probably they don't want you to create sparks near the battery. Most 'Jump' instructions tell you to connect the ground somewhere away from the battery last.
Merry Christmas...!!!!!
JOHN DEERE MX6 ROTARY MOWER, 3PT (A63291)
JOHN DEERE MX6...
207282 (A52708)
207282 (A52708)
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
6R BEDDER (A63291)
6R BEDDER (A63291)
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
