How to secure tractor while operating PTO generator
/ How to secure tractor while operating PTO generator #1
manganos
Close to Petersburg
Mahindra 2516
Well today was/is the first time I've had to use my PTO generator. My question is how in the heck to secure it from theft or personal injury. I'm more worried about a neighborhood kid coming by and screwing with it and getting hurt more then anything.
Any thoughts would be appreciated!
/ How to secure tractor while operating PTO generator #2
A fence with a Doberman inside it would work.
/ How to secure tractor while operating PTO generator #3
One of my international trucks was an old fire truck (pump truck). Since it would run to pump water and is a standard they welded a piece of pipe to the gear shift and made a bar that would drop onto the pipe only when in neutral. They didn't have to worry so much about someone messing with it.
As for a tractor, I'm not sure what you could do unless you have a cab you could lock. I would say it's another reason to have a stand alone generator. I assume you are home so you don't have to worry about a kid pushing the throttle wide open and causing electrical damage to your house. I guess you could make a way of locking things like the gear shift on neutral and maybe the FEL.
Good suggestion. The power is still out and I had to go to work so I turned the tractor off. The last thing I need is to get home to no power and having to bleed injectors HAHAHAHA.
You might be right about that. My German Shep was very territorial. My pitbull is territorial towards other animals. Thank goodness she seems to be good with people.
/ How to secure tractor while operating PTO generator #9
Those are all great guard dogs. But my Aussies are pretty protective as well. And they're also smart enough to put more fuel in the tractor when it gets low... :D
/ How to secure tractor while operating PTO generator #10
With the neighborhood kids in mind, I can understand your concern for an active PTO running unattended. Having the tractor in a fenced in area would certainly lessen the chance of a curious little one to wander into harms way. Aside from that.....maybe a proavtive discussion with the neighborhood parents explaining to them the scenario and potential dangers involved could make a difference.
/ How to secure tractor while operating PTO generator #11
Hook a fence charger to it. Wrap the grab handles in tin foil and heat them up. Did that to the trash cans many years ago when I lived in town. The kids quit dumping them. (Back when trash cans were metal)
Dan
/ How to secure tractor while operating PTO generator #12
Is this a serious question?:confused:
Thanks for the suggestions. Yes it is a serious question. I don't want to leave the tractor unattended if the power is out etc.....
I'm afraid a child will bump the tractor in gear, get hurt by the PTO etc....
/ How to secure tractor while operating PTO generator #14
The harder the access, the older the kid that finally defeats it....If there is no one home why not just shut it down.....
How do you stop someone from climbing on and driving away?
I'd like to keep it running if I run to the store or something but I guess it is not out of the question to shut it off etc.
The tractor lives in the garage therefore no one can climb on it and drive away.
I wonder if I could leave it running in the garage and hook up an "extended" exhaust to route the exhaust outside.
/ How to secure tractor while operating PTO generator #16
Manganos....I was wondering the same thing with my tractor and PTO generator...I would like someone to comment and give us feedback on what would be wrong with running the tractor in the garage as long as we had an extension clamped to the end of the exhaust and routed outside...With a diesel tractor I don't see the harm but I'd sure like some opinions especially from the safety police around here..:)
/ How to secure tractor while operating PTO generator #17
I find it hard to beleive that there is that much concern about it being driven away.
That said why not just chain the back wheel together or get one of those steering wheel clubs?
By securing it I also meant keeping people/kids away from the rotating PTO. I had a friend who lost a leg, arm and half his face by getting his clothing tied up in the PTO. He had 40 years of tractor experience. I have two small children and while I've lectured them countless times about safety etc it only take one "ut oh".
I expected some good answers to my question. Not questions about my question. Shrug.
/ How to secure tractor while operating PTO generator #19
Shouldn't be a problem with a properly shielded PTO. If you are that uneasy about an unsupervised running tractor then the tractor shouldn't be running unsupervised.
/ How to secure tractor while operating PTO generator #20
Theres probably no sure fire way to secure the tractor and generator in the way you want short of keeping it in a locked building.
2015 FREIGHTLINER M2 4X2 S/A 26FT REFRIGERATED BOX TRUCK (A59914)
2015 FREIGHTLINER...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
2018 Kenworth W900 Ext. Day Cab (A62613)
2018 Kenworth W900...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
2026 Electric Tricycle (A64194)
2026 Electric...
