truck info wanted
/ truck info wanted #42
I don't think Petes and Kenworths have crew cabs do they? Or can you put seat that are leagal in a sleeper?
You can readily find 330-335 Petes, T300 KW's Freightliner FL's and M2's, and IH's with crew cabs marketed to the horse crowd. Power wise, they are going to have 8.3 Cummins, C7/3126 CAT's, Mercedes, and DT466's. Not the HP builder suggested. Expect to pay.
If you can live with a sleeper outfitted with with a seat, the market is in your favor. Single axles sleepers are far and away not as easy to find as tandems but they are out there. I don't know if you want an auto or a stick but the auto is also going to be more scarce.
Also, you can get a lot of truck for your money if you step from the Class 6's to the Class 7's.
/ truck info wanted #43
If you're going to pull a heavy load, do it the White way. As most everyone has said, you need to look beyond a pickup. A Ford F-450 pickup is rated at 33,000# GVWR but it won't be enough truck for your weights. You're in the International 4900, Ford F-650, Chevrolet 6500 territory. Lots of used beverage trucks equipped with air brakes and fifth wheels. If you bought a truck with air brakes you can use an air/electric brake controller for use with trailers with electric brakes.
That's one honey of a White. Congrats on the restoration.
/ truck info wanted #45
No offense, but I'd take my Duramax any day over the CAT C-7 in that freightliner:laughing: . 7 litres is not enough for the kind of load the OP wants to pull.
You need at least a 10L mill for towing a 30K trailer without struggle. trust me. You'll get bitten by the HP bug and with you had an M-11, N-14, etc.
I pull a 25,000lb trailer with my 4800. I have a DTA466 factory modified to 250HP and then tweaked even more by me up to at least 275HP and I wish I had more.
/ truck info wanted #46
Mostly, I was pointing out the cost of admission and following up on my previous thread on what's out there.
My FL70 has a 3126 (the C7 predecessor for those who don't know) and it does just fine with a gross in the low thirties. One of the trucks I drove delivering pole barns was a Pete 335 single axle, C7 8spd pulling a tandem roll off for delivering trusses. As I recall, the GVCW it was licensed for was around 56k. It would "wimper" at the smallest of hills.
I don't care for M-11's but that N-14 pulls and gets good mileage. So does the C-12 CAT.
Here is one all set up, plenty of seats with belts, a drop down sleeper berth, plenty of HP with an autoshift.I would not want it if my use involved farm or job site use. Great for the road though.
/ truck info wanted #50
I don't know much about big trucks but had a friend buy a Pete several years ago and got the tandem converted to a single axle for free by letting the shop keep the tandem stuff. He told me older tandem tractors were near worthless compared to a single. Worth thinking about????
/ truck info wanted #51
YES. The best choice for a heavy hauler is an old road tractor. They have lots of HP and comfort compared to a medium duty. If I were going to pull a 4 car wedge, I'd get a S/A road tractor.
/ truck info wanted
I just found a company on the web that make a crew cab Pete.
Caterpillar 966G/972G Wheel Loader Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar...
1987 International 1954 Elliott ECE 3-65H Telescopic Boom Lift Truck (A61573)
1987 International...
UNUSED WOLVERINE 3PT QUICK TACH (A64281)
UNUSED WOLVERINE...
2351 (A64281)
2351 (A64281)
2003 Chevrolet C7500 Flatbed Truck (A62613)
2003 Chevrolet...
2015 ISUZU NPR 4X2 16FT BOX TRUCK (A59912)
2015 ISUZU NPR 4X2...
